Full Enclosure
marenyi(at)gmail.com
PostPosted: Mon Oct 05, 2009 7:05 am    Post subject: Full Enclosure Reply with quote
I am wondering how you go about putting a full enclosure on a firestar II and what benefits does it have, as well as what downsides are there. If you have a jump seat can you still get into it with a full enclosure. Is there a place to buy the enclosures?
Thanks everyone. I hope to be a proud Kolb owner very soon (pending answers to these questions)
Eric M.
dalewhelan
PostPosted: Mon Oct 05, 2009 8:45 am    Post subject: Re: Full Enclosure Reply with quote
Yes on the getting in
Your passenger will be warmer
you would build the windows
Dale Whelan
503 powered Firestar II, Luscombe 8A
Projection, A simple and interesting Psychological concept
zeprep251(at)aol.com
PostPosted: Mon Oct 05, 2009 3:38 pm    Post subject: Full Enclosure Reply with quote
Eric,
The full enclosure is made of fabric and clear vinyl I think.Got mine from Kolb .It velcro's on.With a little foam gasket between the wing and upper windshield support it closes up pretty good.Bt don't try to go fast,it pressures up on the inside and I had it blow loose on the right side and tail back far enough that the prop put a slice in the vinyl window before I could yank it back into the rear seat.
G.Aman
WillUribe(at)aol.com
PostPosted: Mon Oct 05, 2009 4:40 pm    Post subject: Full Enclosure Reply with quote
Hi Eric,
Here some pictures of the full enclosure installed on my FireStar II. The rear clear cover is not installed completely so you can see it's not stretched. It protects you from the elements and keeps you warmer in the winter. The down side is your adding more weight, need to undo the Velcro on of the rear cover to pull start the engine and slows you down a little. Yes you can still shoe horn a grown up in the jump seat. I ordered my enclosure kit from Kolb. I fly with the full enclosure in the winter and remove the rear cover in the summer.
Hope this helps,
Will Uribe
El Paso, TX
FireStar II N4GU
Will's FireStar
Kolb FireStar II
In a message dated 10/5/2009 9:06:30 A.M. Mountain Daylight Time, marenyi(at)gmail.com writes:
Eric M.
f="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
 Filesize:  39.96 KB
 Viewed:  10382 Time(s)
 Filesize:  44.4 KB
 Filesize:  40.58 KB
PostPosted: Mon Oct 05, 2009 4:50 pm    Post subject: Full Enclosure Reply with quote
Thanks Will, that does help a lot!
Do you know if there is a cabin heater made for the enclosure? I would imagine it wouldnt be too hard to fashion one. I was talking to another guy today who said the enclosure acts almost like a greenhouse and keeps you pretty warm in the winter, but I never asked him about the heater.
Eric
On Mon, Oct 5, 2009 at 8:41 PM, <WillUribe(at)aol.com (WillUribe(at)aol.com)> wrote:
[quote] Hi Eric,
lcottrell
PostPosted: Mon Oct 05, 2009 5:05 pm    Post subject: Full Enclosure Reply with quote
Eric,
I bought my full enclosure from Kolb, and it included the fabric and clear vinyl as well as a full sheet of Lexan, a hoop for the top of the enclosure, two side rods for the back of the Lexan and an aluminum rod for the center of the windshield.
While I used it for years and even incorporated a heater for really cold weather. I did not feel that it was as suitable as it could have been, and my enclosure has morphed to this design. I also found that the vinyl part that fully enclosed the rear of the cockpit cut my speed down by 5 to 7 MPH. I also found that there was not much noticeable difference in temp. as far comfort was concerned. I no longer use the vinyl part, a silk scarf and a rag wool hat over my headset, a Chili Vest with a pair of gloves and I am good down to 24 degrees so far. Not real interested in experimenting further in that direction.
Larry C, Oregon Firestar II
 Filesize:  114.13 KB
 Viewed:  10380 Time(s)
 Filesize:  132.56 KB
 Filesize:  130.23 KB
PostPosted: Mon Oct 05, 2009 5:21 pm    Post subject: Full Enclosure Reply with quote
Eric,
I never needed a heater but I know of one who installed one. Talk to John H about the Chilly vest or look it up in the archives.
Hope this helps
Will Uribe
El Paso, TX
FireStar II N4GU
In a message dated 10/5/2009 6:50:33 P.M. Mountain Daylight Time, marenyi(at)gmail.com writes:
Eric
Hi Eric,
 Filesize:  38.7 KB
 Viewed:  10378 Time(s)
 Filesize:  41.25 KB
 Filesize:  45.9 KB
 Filesize:  53.8 KB
 Filesize:  30.66 KB
PostPosted: Mon Oct 05, 2009 5:24 pm    Post subject: Full Enclosure Reply with quote
Larry, you said "I did not feel that it was as suitable as it could have been, and my enclosure has morphed to this design" but I dont follow you as to what design you have morphed to? did you send a picture that I didn't get?
Eric
On Mon, Oct 5, 2009 at 9:02 PM, Larry Cottrell <lcottrell(at)fmtcblue.com (lcottrell(at)fmtcblue.com)> wrote:
[quote] Eric,
PostPosted: Mon Oct 05, 2009 5:25 pm    Post subject: Full Enclosure Reply with quote
Larry, Nevermind, it took my email a while to show them, I see what you meant now!
Thanks!! Eric
On Mon, Oct 5, 2009 at 9:24 PM, Eric Marenyi <marenyi(at)gmail.com (marenyi(at)gmail.com)> wrote:
[quote]Larry, you said "I did not feel that it was as suitable as it could have been, and my enclosure has morphed to this design" but I dont follow you as to what design you have morphed to? did you send a picture that I didn't get?
Eric
[quote] Eric,
ulflyer(at)verizon.net
PostPosted: Tue Oct 06, 2009 7:14 am    Post subject: Full Enclosure Reply with quote
Anyone got a photo of the enclosure to see what it looks like installed.
jerb
At 04:37 PM 10/5/2009, you wrote:
[quote]Eric,
G.Aman
