frank.goodnight(at)att.ne Guest
Posted: Sun Oct 04, 2009 11:01 am Post subject: Firestars & gusts????? |
Decided to pratice takeoffs and landings today , in gusty conditions.
Firestar 2 (at) 725lbs
Runway heading 13
wind 170 (at) 14k gusting 20k, gust were rather closely spaced.
DA 2400 ft.
My goal was to touch down within 50 yards of my selected touch down
point and feel
safe and in compleat control. I couldn't do it. I was really pushing
it to stay within 100 yards.
I only did 6 landings because I felt like I was at or maybe exceading
my skill limits.
As I am planing 2 rather long X countrys this spring, one to Utah &
one to Sun&Fun, I'm
sure I'll run into rough weather and I need to pratice for it.
MY questions to anyone who flys a firestar are , what do you think is
a reasonable limit for
the firestar regarding gusty conditions and crosswind components?
I realize that each pilot has a different skill level, I,m trying to
raise mine up to what the airplane can do, but I don't want to push
hard enough to get in trouble. any thoughts will be appreciated
and helpful.
Frank Goodnight
Firestar2 HKS 55161
Brownsville , TX
Posted: Sun Oct 04, 2009 12:11 pm Post subject: Firestars & gusts????? |
| Quote: | I realize that each pilot has a different skill level, I,m trying to
raise mine up to what the airplane can do, but I don't want to push hard
and helpful.
Frank Goodnight
Hi Frank G/Gang:
Capability of any Kolb and its pilot, to me, is what that pilot feels
comfortable with.
That is how I approach the capabilities of my mkIII and the other Kolb
models I get to fly occasionally.
Many times, when I get caught in bad weather conditions, my mkIII
demonstrates it is a better airplane than I am a pilot.
I learned to fly Kolbs by flying frequently, almost every day, pushing the
envelope more each time I flew. Flew in all kinds of wind and weather
conditions. I learned a lot. Some good and some very bad. The bad part
was my fault, not the airplanes'.
BTW: I also practiced a lot of dead stick landings. Wish I could execute
them now as good as I could 20 years ago. The reason, I don't practice
nearly enough.
Looking forward to seeing Frank G at Monument Valley, May 2010. Hope I get
there early so I can watch Frank land and see the big ass grin on his face
when he taxiis up to the tie down cable.
Experiencing my second dust storm in Moab. First since John W, Boyd Y, and
I rode one out at the airport a few years ago.
Moab, Utah
_________________ John Hauck
Titus, Alabama |
dalewhelan
Joined: 11 Nov 2008 Posts: 105 Location: USA ARIZONA fountain hills
Posted: Sun Oct 04, 2009 10:32 pm Post subject: Re: Firestars & gusts????? |
Frank, I have done 17kts at about 45 degrees without problems but not without attention.
I also glt hit by 20 MPH at 90 degrees and stomped on the brakes to stop a ground loop damaged the nose.
I usually do wheel landings in crosswind although I have heard people argue for 3 pointers in crosswind.
Flew today with 20+ winds, only one crosswind takeoff, a bit sloppy, all else into the wind
_________________ Dale Whelan
503 powered Firestar II, Luscombe 8A
Projection, A simple and interesting Psychological concept |
John Bickham
Joined: 10 Jan 2006 Posts: 170 Location: St. Francisville, LA
Posted: Mon Oct 05, 2009 8:41 am Post subject: Re: Firestars & gusts????? |
Hey Mr. Frank,
Not an expert, just passing on my experiences.
I too had done some crosswind and higher wind condition practice prior to my trip to MV.
I have to build up to that point and stay proficient to be be ahead of the plane. Practice, practice, practice is the only way I can maintain that skill level. If I take the easy path of light wind flying, I have to make myself go out and start again.
I was a faithful three point lander until my trip out west in some pretty stiff conditions. I got converted to three point landings quickly. Found it easier to wing low and wheel land in the conditions you describe. I found that you can stick it on the runway with a little more speed and rudder authority. Kinda need to have decent brakes that you can finesse. Not sure if you have that on your Firestar.
One additonal thing to consider that I neglected in my practice for the long XC's. That would be tailwind landings. As you know, MV (UT25) is one way in and one way out. It really got my attention after a long day of flying from Vernon, TX to MV and arrive with the wind blowing in the wrong direction. When I flared, I thought I was going 90 mph. Weird feeling and unusual visual cues. Consider putting that on your list when you get more comfortable.
I also learned how to "B-52 takeoff and land" at the higher density altitudes. Of course, some of that I learned the hard way!
Need to fly, but raining most of my off-days lately.
Practice your shortfield stuff too. Maybe you could join us for the Nauga Field Fly-Around the first weekend in December. Love for you to join us.
http://www.airnav.com/airport/LS35
Above all, please be careful.
_________________ Thanks too much,
John Bickham
Mark III-C w/ 912UL
I know many pilots and a few true aviators. There is a distinct difference that I have the greatest respect for. |
Posted: Mon Oct 05, 2009 9:10 am Post subject: Firestars & gusts????? |
Hi John,
Nauga Field in early Dec. sounds like it MIGHT be doable. If I can get
in enough X country
practice, and my skill level improves enough so I can be confortable
on that long a X countrty.
Also I've got to talk with John H about how to camp. Haven't done that
in about 30 years.
Thanks for your advice, I think you hit the nail pretty much on the
head.
Frank Goodnight
Firestar2
Brownsville, TX.
On Oct 5, 2009, at 11:41 AM, John Bickham wrote:
Hey Mr. Frank,
quickly. Found it easier it wing low and wheel land in the
Need to fly, but raining all my off-days lately.
to join us.
Thanks too much,
John Bickham
Mark III-C w/ 912UL
http://forums.matronics.com/viewtopic.php?p 66623#266623
John Bickham
Posted: Mon Oct 05, 2009 3:20 pm Post subject: Re: Firestars & gusts????? |
Mr. Frank,
First....
| Quote: | | I was a faithful three point lander until my trip out west in some pretty stiff conditions. I got converted to three point landings quickly. |
Should have read, "I got converted to wheel landings quickly."
Second...
Don't stress too much about the camping gear except for the intermittent stops. If you fly the Firestar that far, we'll take care of anything you might need once you are here. You kinda get adopted once you are here. Jimmy Y may be able to help out in between .
Important to be comfortable with short fields over obstacles (trees). Nauga is Kolb friendly but it will get your attention if you are used to landing on long runways with clear approaches.
John Bickham
Mark III-C w/ 912UL
WillUribe(at)aol.com Guest
Posted: Mon Oct 05, 2009 5:58 pm Post subject: Firestars & gusts????? |
Hi Frank,
I have landed my FireStar in some bad winds. One time Dave Rains and I were landing in Apple Valley, when on the base leg, the automated wind shear alert came on over the radio. While taxing very slow the tail on my FireStar came up because of the gusting winds. When we got to parking we needed the assistance of the ground crew to hold the FireStars so we can get off the tie them down. When we walked into the FBO the heavy iron drivers couldn't believe we were flying in that wind everybody else was grounded.
This was one time my Kolb far exceeded my skill or someone with greater powers was looking over us.
Another time after I landed in very gusty winds I was opening the hanger doors when the wind started pushing the FireStar back. I almost lost it had I it not been for someone who came over and helped me put it in the hanger. Check out the wind sock on this picture after we had just landed.
Regard,
Will Uribe
El Paso, TX
FireStar II N4GU
In a message dated 10/4/2009 1:01:51 P.M. Mountain Daylight Time, frank.goodnight(at)att.net writes:
| Quote: | --> Kolb-List message posted by: "frank.goodnight" <frank.goodnight(at)att.net>
Runway heading 13
DA 2400 ft.
point and feel
my skill limits.
one to Sun&Fun, I'm
and helpful.
Frank Goodnight
Firestar2 HKS 55161
Brownsville , ======================== the lities 7-Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site ===================================================
27.58 KB |
9007 Time(s) |
Jimmy Young
Joined: 24 Nov 2007 Posts: 182 Location: Missouri City, TX
Posted: Tue Oct 06, 2009 2:43 am Post subject: Re: Firestars & gusts????? |
| Quote: | | Don't stress too much about the camping gear except for the intermittent stops. If you fly the Firestar that far, we'll take care of anything you might need once you are here. You kinda get adopted once you are here. Jimmy Y may be able to help out in between |
Frank,
Yes, I plan to fly to Nauga Field in December, and you're most definitely welcome to RON at our place here in Angelton, Bailes Field (7R9). I'm planning on going to Nauga, and we could fly together. I am close to the halfway point for you so it would work out well, and would be a lot of fun. We'll stay in touch.
Jimmy Y[/quote]
_________________ Jimmy Young
Missouri City, TX
Kolb FS II/HKS 700 |
