Posted: Sat Oct 03, 2009 3:47 pm Post subject: Mounting engine |
Easy question:
Is it posible without too much effort to mount the engine without using the taperred cylindrical bolt substitutes?
Getting ready to rent an engine hoist and can see not being able o get the engine mounted unless I have these in my bag of tricks.
John G.
Lew Gallagher
Posted: Sat Oct 03, 2009 3:58 pm Post subject: Mounting engine |
Hey John,
Our engine aligned very easily just using the final bolts. I use an engine leveler between the hoist and the engine to get the angle just right. I did find that typically three of the four went in with no problem, the the fourth took some jiggling. Eventually we found which three made the fourth easier. With the engine leveler set, and the pattern followed, we can put it on and take it off with ease.
Later, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
Kelly McMullen
Posted: Sat Oct 03, 2009 4:48 pm Post subject: Mounting engine |
I don't know what they rent for, but these days they go for about $130
at Pep Boys, etc.
On Sat, Oct 3, 2009 at 4:46 PM, John Gonzalez <indigoonlatigo(at)msn.com> wrote:
| Quote: | Easy question:
John G.
A&P/IA, EAA Tech Counselor
KCHD |
coop85(at)verizon.net Guest
Posted: Sat Oct 03, 2009 7:39 pm Post subject: Mounting engine |
I had the same positive experience, only used the final bolts on two airplanes. A little jiggling and head scratching to get things lined up right but certainly doable.
Marcus
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Lew Gallagher
Sent: Saturday, October 03, 2009 7:57 PM
Subject: Re: Mounting engine
Hey John,
Later, - Lew
----- Original Message -----
To: RV 10 group (rv10-list(at)matronics.com)
Sent: Saturday, October 03, 2009 7:46 PM
Subject: Mounting engine
Easy question:
John G.
http://www.matronics.com/Navigator?RV10-List | 01234567890
MauleDriver(at)nc.rr.com Guest
Posted: Sun Oct 04, 2009 6:16 am Post subject: Mounting engine |
I used the final mounting bolts. Very easy. Just don't try it with
the prop on it.
I used the 2 ton harbor freight hoist for <130$ on sale plus the load
leveler. Their smaller hoist would work too. You know you have the
right setup when you get this kind of warning (see photo). I too would
suggest buying one if feasible. The HF hoist folds up to take very
little horizontal space. It's great for mounting/demounting the prop
and avoiding another rental.
I left the engine suspended (with safeties) for about 6 months at one
point. That appeared to damage the jack and had to replace it for a few
more $$$. So rentals can make sense.
Bill "dreaming of evenly spaced cu's from horizon to horizon" Watson
Kelly McMullen wrote:
at Pep Boys, etc.
> Easy question:
> Thanks
> John G.
916.9 KB |
3540 Time(s) |
871.35 KB |
3540 Time(s) |
jim(at)CombsFive.Com Guest
Posted: Sun Oct 04, 2009 6:46 am Post subject: Mounting engine |
John,I mounted my engine by myself in about 20 minutes. No need for any special bolts. Now an IO-360 is a totally different animal!Jim Combs (N312F - 120 Hours)Do Not Archive-------------------------------------------------------------------------------------------------------------------- [quote][b]
