Gig Giacona
Posted: Fri Oct 02, 2009 11:05 am Post subject: RAC Position Sensor for Flaps |
I'm using a RAC POS-12 to send flap position to a Dynon 180.
Has anyone else installed one of these? I'm trying to figure out a spot to mount it?
601XL Under Construction
gfmjr_20(at)HOTMAIL.COM Guest
Posted: Fri Oct 02, 2009 1:02 pm Post subject: RAC Position Sensor for Flaps |
Gig--
I mounted mine just behind the control arm of the flaps. I formed a piece of aluminum that is riveted to the floor and has a slope on it such that the control rod with clevises (from Radio Control Model shop) is mounted in a straight line from the sensor to the upper part of the flap control arm. You will need to find the sweet spot that will give you the complete range you are looking for.
good luck
George May
601XL 912s
[quote] Subject: RAC Position Sensor for Flaps
Date: Fri C 2 Oct 2009 12:05:39 -0700
--> Zenith-List message posted by: "Gig Giacona" <wrgiacona(at)gmail.com>
W.R. "Gig" Giacona
http://forums.matronics.com/viewtopic.php?p=266104#266104
Hotmail: Powerful Free email with security by Microsoft.w'>Get it now. [quote][b]
Posted: Fri Oct 02, 2009 1:25 pm Post subject: RAC Position Sensor for Flaps |
Attached are pictures of Mike Sigman's and Ron Geese's installations.
-- Craig
13.02 KB |
8128 Time(s) |
11.54 KB |
8128 Time(s) |
18.12 KB |
8128 Time(s) |
78.08 KB |
8128 Time(s) |
69 KB |
8128 Time(s) |
rgeese
Posted: Sat Oct 03, 2009 6:35 am Post subject: Re: RAC Position Sensor for Flaps |
Gig--The photos of my installation that Craig posted works very well. I set it up as a "proof of concept", and it worked so well I put finishing touches on it and left it. It is made with model airplane clevises and wheel collars, and actually measures the movement of the limit switch arm. It is adjustable to fine tune the movement of the sensor arm. I'm not flying yet, but I don't foresee any problems with it.
Posted: Sat Oct 03, 2009 7:47 am Post subject: RAC Position Sensor for Flaps |
You would have to adapt the design a little if you have the new style flap
motor. But the basic concept would carry over nicely.
-- Craig
Gig Giacona
Posted: Sat Oct 03, 2009 9:27 am Post subject: Re: RAC Position Sensor for Flaps |
Thanks much all. Especially for the pics.
