Heel brakes or ???
Goto page 1, 2, 3, 4  Next
albertakolbmk3
PostPosted: Thu Oct 01, 2009 3:58 pm    Post subject: Heel brakes or ??? Reply with quote
Just wondering what most people are using for brake levers... heel, hand etc. on MKIII. I have heel brakes but have mixed feelings. I find that they are spaced so close together and sometimes get in the way.
Tony B.
Kolb MKIII C
Rotax 582
C Gearbox 3.00:1
WD 66" 3 Blade Prop
elleryweld(at)aol.com
PostPosted: Thu Oct 01, 2009 4:11 pm    Post subject: Heel brakes or ??? Reply with quote
I have heal brakes on my Mk3C that I feel the levers are to short and I cant get enough pressure on them to get good braking power with the 800-6 Tires I have on it now I am going to extend the pedals if that doesnt cut it I will make toe brakes next
Ellery in Maine
Dana
PostPosted: Thu Oct 01, 2009 4:27 pm    Post subject: Heel brakes or ??? Reply with quote
I have heel brakes on my UltraStar and I feel it's the perfect setup. The
levers connect to Hegar cylinders driving Black Max brakes.
-Dana
Mr. Cole's Axiom:
The sum of the intelligence on the planet is a constant; the population is
growing.
rickofudall
PostPosted: Thu Oct 01, 2009 4:47 pm    Post subject: Heel brakes or ??? Reply with quote
I have heel brakes on my Mk III with Azusa brakes. Hate the things. The brakes are adequate for the job, the heel levers make them  difficult to use. They will NOT be on the aircraft next spring.
Rick Girard
On Thu, Oct 1, 2009 at 7:22 PM, Dana Hague <d-m-hague(at)comcast.net (d-m-hague(at)comcast.net)> wrote:
[quote] --> Kolb-List message posted by: Dana Hague <d-m-hague(at)comcast.net (d-m-hague(at)comcast.net)>
I have heel brakes on my UltraStar and I feel it's the perfect setup.  The levers connect to Hegar cylinders driving Black Max brakes.
-Dana
 Mr. Cole's Axiom:
The sum of the intelligence on the planet is a constant; the population is growing.
http://forums.matronics.com
le, List Admin.
ces308
PostPosted: Thu Oct 01, 2009 5:16 pm    Post subject: Re: Heel brakes or ??? Reply with quote
......I like my toe brakes.....
chris ambrose
M3X/Jab 70.hrs
N327CS
lcottrell
PostPosted: Thu Oct 01, 2009 6:03 pm    Post subject: Heel brakes or ??? Reply with quote
I don't have a Mark III, but I do have a Firestar if that counts. I did have a Mark III with heel brakes, and I didn't like them. I have tried toe brakes on a 150, didn't like that either. I used to have one hand brake on the Firestar and changed it to two individual hand brakes on the stick. I like that a lot. I had to make a "deally bob" to hold the levers, but it was worth it.
Larry
Richard Pike
PostPosted: Thu Oct 01, 2009 6:45 pm    Post subject: Re: Heel brakes or ??? Reply with quote
Know how you feel. Rigged up a different variation of hand brake levers for the MKIII, you actuate them by pushing straight down with the left hand. Sounds odd, works good, and after you do it once or twice, it becomes very intuitive. Just have to be careful when fastening the seat belt, if you aren't paying attention, you can loop the belt over them. (Hmmm... Wonder why it takes full power to taxi?)
Here are the pictures.
http://www.bcchapel.org/pages/0003/pg4.htm
Richard Pike
MKIII N420P (420ldPoops)
aoldman(at)xtra.co.nz
PostPosted: Thu Oct 01, 2009 11:13 pm    Post subject: Heel brakes or ??? Reply with quote
Toe brakes on MK111c and like them , they work great , although I have to admit I would use them more for ground maneuvering mostly ,long grass runways don't need a lot of braking.
Downunder
MK111c
Thom Riddle
PostPosted: Fri Oct 02, 2009 4:06 am    Post subject: Re: Heel brakes or ??? Reply with quote
My Slingshot has dual caliper Matco brakes. One caliper on each wheel is actuated with a single hand lever operated master cylinder on the stick for straight ahead stopping, i.e., non-differential braking. The other caliper on each wheel is actuated independently from heel operated master cylinders below the rudder pedals. These are used for tight turning. I use them all for added brake capacity during run-ups.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
frank.goodnight(at)att.ne
PostPosted: Fri Oct 02, 2009 5:12 am    Post subject: Heel brakes or ??? Reply with quote
Hyd. heel brakes on my firestar 2. They work really good , but I HATE
them . they are difficult
to use & I don"t trust myself to be able to them use correctly if a
bad situation develops. I'm
not confortable with them even after 100 hrs of flight time and who
knows how many landings.
On Oct 1, 2009, at 6:58 PM, albertakolbmk3 wrote:
Frank Goodnight
Firestar2
Brownsville , TX
way.
Kolb MKIII C
Rotax 582
C Gearbox 3.00:1
WD 66&quot; 3 Blade Prop
http://forums.matronics.com/viewtopic.php?p 65944#265944
albertakolbmk3
PostPosted: Fri Oct 02, 2009 5:41 am    Post subject: Re: Heel brakes or ??? Reply with quote
Interesting... seems most have heel brakes and they don't like them either. I find mine work really well and that is where the problem lies. A few times after just touching down I accidentally hit one and veered me to that side of the runway. A little scary when your not expecting it. Anyone have pictures of their toe brake setup?
Tony B.
Kolb MKIII C
Rotax 582
C Gearbox 3.00:1
WD 66" 3 Blade Prop
zeprep251(at)aol.com
PostPosted: Fri Oct 02, 2009 5:54 am    Post subject: Heel brakes or ??? Reply with quote
Cherie,
Heel brakes.They are,they do,but you get used to them.
G.Aman
JetPilot
PostPosted: Fri Oct 02, 2009 7:58 am    Post subject: Re: Heel brakes or ??? Reply with quote
Toe brakes are the standard in the aviation world, from th smallest to the biggest planes. Toe brakes are not complicated or hard to make, it just seems that ultralight designers like to take shortcuts on this item. Reversing the brakes with the rudder pedals is just a setup for disaster, as albertakolbMKIII just pointed out with his experience. I have toe brakes, they don't weigh any more than a heel brake setup, the my Kolb has standard controls just like every other plane in the world. Heel brakes and hand levers can work, but its a design shortcut and substandard.
 Filesize:  270.39 KB
 Viewed:  23677 Time(s)
Kolb MK-III Xtra, 912-S
Dana
PostPosted: Fri Oct 02, 2009 9:24 am    Post subject: Heel brakes or ??? Reply with quote
At 11:58 AM 10/2/2009, JetPilot wrote:
...Heel brakes and hand levers can work, but its a design shortcut and
substandard.
I don't agree at all; heel brakes aren't substandard, just a different
(earlier) standard.
Like probably most on this list, I learned to fly with toe brakes (in a
C-150). When I bought my first plane, a 1941 Taylorcraft, it had heel
brakes. Took a short while to get used to, but I soon came to prefer
it. One disadvantage of toe brakes is that it's easy to inadvertently
apply brake when using the rudder.
One difference on my T-Craft is that the heel brakes were to the _outside_
of the rudder pedals, rather than to the inside as in my UltraStar. I
haven't made up my mind which is better... it's been so long since I flew
the T-Craft the UltraStar didn't feel awkward.
I didn't care for the hand brake on the Quicksilver I was flying for
awhile, but that _was_ a design shortcut, using bicycle components... and
pretty anemic to boot.
Thousands of production aircraft have been built with both heel and hand
brakes.
-Dana
Remember when a trojan was a warrior?
George Alexander
PostPosted: Fri Oct 02, 2009 10:06 am    Post subject: Re: Heel brakes or ??? Reply with quote
JetPilot wrote:
.............my Kolb has standard controls just like every other plane in the world.
Maybe most..... certainly many, but hardly "every other plane in the world."
JetPilot wrote:
.............Heel brakes and hand levers can work, but its a design shortcut and substandard.
But may be a necessity. I know the original question related to MKIII's, but those of us Kolb flyers with smaller nose cones (e.g. Firestars, Fireflys and some Ultrastars), and who have big feet, generally don't have much choice . Operating the rudder pedals with size 14 shoes in that small space is sometimes enough of a challenge. A design to incorporate toe brakes would be more of an accomodation than I think would be worth it in my case. Work hard to avoid situations where brakes are critical. Can't always do that, but as some would say... "you pays your money and takes your chances".
As Beauford says..... worth what you paid fer it.
PS: I have moderately effective heel brakes, giving serious consideration to switching to hand lever(s).
George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net
slyck(at)frontiernet.net
PostPosted: Fri Oct 02, 2009 10:29 am    Post subject: Heel brakes or ??? Reply with quote
The Aeronca Chief had a dandy heel brake design, little levers at the
bottom of the rudder pedals and cable operated.
-foolproof except when the cables froze with ice in the fairleads on
the bottom of the gearlegs.
You could turn and brake at your need.
The Champs had an awkward pedal sticking out of the floor.
My MkIII has what I thought at the time I was creating it, a
brilliant design. Throttle handle actuated.
I reinforced the throttle bar and had a rod actuate a Girling (copy)
master cylinder. There is a little concealed reliever
spring built into the throttle cable at the carb so it will back up
from closed throttle.
I also put a brake lock in the line so I could do a runup.
Ignorant at the time of the leverage required, the output is puny and
I have to pull fairly hard to get much to happen.
I haven't retrofitted it because I fly off of grass.
Eventually.
BB
wet and overcast Scottsville, NY
On 2, Oct 2009, at 2:06 PM, George Alexander wrote:
<gtalexander(at)att.net>
> plane in the world.
the world."
> Mike
chances".
George Alexander
FS II R503 N709FS
http://gtalexander.home.att.net
http://forums.matronics.com/viewtopic.php?p 66093#266093
jbhart(at)onlyinternet.ne
PostPosted: Fri Oct 02, 2009 11:46 am    Post subject: Heel brakes or ??? Reply with quote
Been flying the FireFly with home made band brakes activated by a single
lever on the stick. Up to this point, I have not found any need for
separate wheel braking. I fly off from and to hard surface runways almost
100%.
Jack B. Hart FF004
Winchester, IN
by0ung(at)brigham.net
PostPosted: Fri Oct 02, 2009 12:27 pm    Post subject: Heel brakes or ??? Reply with quote
my heal brakes are close as well,,,, love them.
Boyd Young
Kolb MKIIIC
JetPilot
PostPosted: Fri Oct 02, 2009 12:32 pm    Post subject: Re: Heel brakes or ??? Reply with quote
It makes no difference what a Aeronca , Taylorcraft, or a few small manufacturers may have done 60 years ago, the standard has long since been decided...
The first motorcycles used to have a reverse clutch that had to be constantly squeezed to engage the motor, we have since learned that it was a horrible idea and we now have a world standard that is the opposite.
Same goes for some old airplanes, lots of things have been tried over the decades in airplanes, big deal... We now have a standard of toe brakes, and for very good reasons. Just because something may have been used 60 years ago or even on a very few odd planes, it still does not change the fact that heel brakes, levers, strings, or what every crazy design some people have come up with are a substandard shortcut.
There will always be a few that say " it works for me " and accept anything, as we have seen on past discussions of Fuel Filters, and other things. When possible I believe in making my Kolb to accepted Aircraft standards, It's not always possible but I do it where I can, and toe brakes is one that can be easily done on the MK III. Smaller ultralights and the Firefly may be more difficult, each person will have to decide for themselves.
PostPosted: Fri Oct 02, 2009 12:49 pm    Post subject: Heel brakes or ??? Reply with quote
substandard.
when I first was building the mkIII I called and asked Dennis Souder and
addressed my concerns. his response was to give them a chance and they
would grow on you. they have, and I am very comfortable with them.
a lot of plane manufactures have gone to nose dragging... that does not
infer that all tail draggers are obsolete, or sub standard, just
different.
Boyd Young
Kolb MkIIIC
Brigham City, Ut.
Page 1 of 4
