Door bulge
ncol(at)xtra.co.nz
PostPosted: Tue Sep 29, 2009 9:41 am    Post subject: Door bulge Reply with quote
Here is an air to air pic + enlargement.
Speed was only about 110 knts max as the photo ship was a C182.
On the ground the door is perfectly flush all around, with no visible
bulge at the leading edge, nor at the bottom.
In flight I have not noticed it moving out, but we have a thick lining
material there. But the bulge is definitely visible in these pics. Our
pins go right into the frame as per Vans instructions, but it serves
as a reminder to ensure that the front pins have plenty of engagement.
We also have the Vans door warning system and that hasn't illumintated
in flight.
Nor is there any feeling of a draught at all, so the seals obviously
do their job well.
Neil
 Filesize:  29.72 KB
 Viewed:  7297 Time(s)
 Filesize:  28.75 KB
bkbrown(at)minetfiber.com
PostPosted: Tue Sep 29, 2009 2:46 pm    Post subject: Door bulge Reply with quote
Makes one wonder if a spring loaded latch pin engaging through the sill
vertically at the center of the door would help. Visualize a door latch,
that is flat on one side (to facilitate latching) and rounded on the other.
It would make getting out of the plane a "two-latch" affair, but may prevent
the in-air mating of a door to the horizontal stab...
Kellym
PostPosted: Tue Sep 29, 2009 3:59 pm    Post subject: Door bulge Reply with quote
One RV-10 at OSH had just what you suggest. Owner had door come open and
off before rotation, and was able to abort, and door did not hit
anything to damage airframe. He was not about to have a second event, so
put latch with clevis pins vertically through bottom of each door. I
don't think I got a picture, but if I look, I can get the tail number.
Kelly McMullen
KCHD
toaster73(at)embarqmail.c
PostPosted: Tue Sep 29, 2009 7:11 pm    Post subject: Door bulge Reply with quote
Here it is.
Chris
 Filesize:  123.85 KB
 Viewed:  7259 Time(s)
AirMike
PostPosted: Wed Sep 30, 2009 2:25 am    Post subject: Door bulge = RV10 archilles heel Reply with quote
N220RV - the factory Continental equipped RV10 has a nice latch system. I do not know when it was installed but it is a spring loaded mid door latch
 Filesize:  630.26 KB
 Viewed:  7241 Time(s)
See you OSH '18
Q/B - sold.
velo
PostPosted: Wed Sep 30, 2009 6:33 am    Post subject: Re: Door bulge Reply with quote
Is this Van's answer to their door design? I think they should make this modification available to all builders as a standard build item. Has anyone talked with Van's about this mod?
Rick
kearney
PostPosted: Wed Sep 30, 2009 8:09 am    Post subject: Door bulge Reply with quote
Hi
Does anyone have a pix of the N220RV mid door latch? I'd like to see how
Van's handled this issue.
Cheers
Les
