rvg8tor
Posted: Fri Sep 25, 2009 7:22 am Post subject: Why have a switch on ALT Field? |
I am brain storming here while I work on my electrical system design (Z12). I wonder why there is a switch for the Alt Field. From my reading on the forums internally regulated alternators get their life shortened if one turns them on under load, (they should be on before start until after start to get the most life out of the alternator). The B&C alternator is externally regulated and can handle the switching under load. But operationally there is no reason to switch the alternator on and off, if you have an abnormal situation and need to turn the alternator off you can do that just as easily with a circuit breaker as you can with a switch. So why not leave the switch out of the loop and wire the alternator field directly to circuit breaker so it is always on, in case of alternator problem, pull circuit breaker. On less switch a few ounces and dollars saved. So, am I missing something obvious here?
I have posted this on VAF, but thought since this forum is more on point I should post it here.
_________________ Mike "Nemo" Elliott
RV-8A QB (Engine)
www.mykitlog.com/rvg8tor |
Posted: Fri Sep 25, 2009 11:16 am Post subject: Why have a switch on ALT Field? |
Bob Nuckolls replies:
An urban (or perhaps hangar) legend. I've been
working with alternators and generators for 40+
years. There is no basis in physics to support
the legend. In fact, it has always been a design
goal of every TC aircraft electrical system to
offer any time, any conditions, positive ON/OFF
control of alternators and/or generators without
concern for degradation of performance or damage
to equipment.
As can ALL other skillfully designed alternators. One
of the foundations upon which the hangar-myth was
built had to do with alternators ostensibly
wired per Z-24 . . .
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z24-Interim.pdf
. . . and apparently switched off (B-lead
broken) while the alternator was under load.
This started a hysterical kerfuffle about "turning
alternators on or off under load". Numerous
authors have posited the same hypothesis before.
However, the special case presented by a b-lead disconnect
contactor energized efforts by the in-experienced
and un-informed to stoke the fires anew and stir
the pot of misunderstanding.
I enjoyed a two-day tour of a LARGE scale alternator
remanufacturing operation about a year ago. Details
of this visit can be discovered at:
http://aeroelectric.com/R12A/03_Alternator_12A1.pdf
During that visit I witnessed a demonstration
of a full load, max rpm, hot-alternator b-lead
disconnect that liberated kilojoules of energy
in the ensuing arc . . . 5 times in a row. The
flash of fire was so great that it was impossible
to photograph or record on video. Their chief engineer
asserted that all of their reman products (2800+
line items) were tested to the same design goals.
These alternators were demonstrably immune from
self-induced load dump damage.
Suppose you have two alternators like Z-12 or
Z-13? Is it not useful to test the two alternators
independently of each other irrespective of all
other conditions?
Suppose you have smoke in the cockpit? How
about an unruly regulator? Our brothers in
the TC aircraft world have adopted any-time,
any-conditions, ON/OFF control as a design
goal.
Perhaps not obvious . . . but certainly not
'secret'. Any student of contact physics for
things like relays, switches and CIRCUIT BREAKERS
will understand that depending on a breaker
like . . .
http://aeroelectric.com/Pictures/Breakers/Klixon_1.jpg
. . . to open the 100 volts plus, b-lead of a runaway
alternator is quite likely to experience a hundreds-of-
kilojoules arc in the gap of relatively slow moving
contacts that are guaranteed to produce a lot of smoke
in the cockpit. BREAKERS are not intended to serve
as commanding manual control devices. Breakers for
aircraft are designed to break faults of several
thousand amps at 32 VOLTS or less. See paragraph
4.7.14 of . . .
http://www.aeroelectric.com/Reference_Docs/Mil-Specs/5809G.pdf
Since the first generators (and then alternators) went
aboard an airplane, the pilot has been offered positive
control of those electrical energy sources by breaking the
FIELD lead. At no time did anyone consider the main power
output feeder protection to be a control device. In fact,
b-lead protection on TC aircraft isn't even on the panel . . .
http://aeroelectric.com/Pictures/Wiring_Technique/A36_Firewall_A.jpg
Please post this reply to VAF. Thanks!
rvg8tor
Posted: Fri Sep 25, 2009 5:47 pm Post subject: Re: Why have a switch on ALT Field? |
Thank you for the explanation, this really helps me understand the design better. I did post your reply on the VAF for all to read. I think this will add to everyones education.
So if I understand what your post, the gist is that there is potential for excess voltage in some situations as to make a CB fail if used to cut the field to the alternator. I have heard others say CBs are not meant to be switches, but at my airline we routinely pull CB on certain items while the airplane sits between flights for several hours. Things like the radar, TCAS, VSI indicator. This use of the CB as a switch happens several times a day for each aircraft. It this an accepted practice since these are low voltage items.
You have given me the data i was looking for, I now understand why the switch is needed, it is due to potential high loads.
RV-8A QB (Engine)
bakerocb
Posted: Sat Sep 26, 2009 3:57 am Post subject: Why have a switch on ALT Field? |
9/26/2009
Hello Mike and Bob, The recent exchange of postings between the two of you
on the subject of "Why have a switch on ALT Field?" has left me a bit
baffled.
Mike, your question dealt with shutting down an alternator by removing the
electrical source to its FIELD. Figure Z 12 was the starting point for your
question and presumably dealt with externally regulated alternators, but
then you threw in the red herring of shutting down internally regulated
alternators.
Bob, your answer appeared to deal extensively with shutting down an
internally regulated alternator by opening the B LEAD such as in Figure Z
24..
Mike, your response below indicated that you believed, as a result of Bob's
posting, that there was a huge amount of electricity flowing through the
wire to the alternator FIELD circuit in an externally regulated alternator
and that therefore a switch rather than a circuit breaker would be needed to
open that circuit.
"You have given me the data i was looking for, I now understand why the
switch is
needed, it is due to potential high loads."
It is my understanding that:
1) The alternator FIELD wire in an externally regulated alternator only
carries a few amps of electricity.
2) Opening this FIELD wire with either a CB or a switch while electricity is
flowing through this wire generates no huge electrical flow interruption
issue.
3) The alternator B LEAD (in either an internally regulated or externally
regulated alternator) can carry a significant amount of electricity and
interrupting this flow through the B LEAD by opening the B LEAD brings up
the issues that Bob dealt with extensively in his response.
Mike if you will check some of the Z diagrams (Z 9 as well as Z 12 for
example) you will see that there is both a CB and a switch that can
interrupt the electrical flow to the alternator FIELD of an externally
regulated alternator. And this is good. The CB provides the traditional
protection to that wiring and the switch makes it possible to turn on / off
the alternator FIELD as desired with no great concern regarding interrupting
huge amperage flow.
My airplane has both a CB and a switch (as do the Z figures) and the
externally regulated alternator FIELD gets turned off by the switch during
every engine shut down procedure while the engine is still running. Shortly
after the alternator is turned off by the FIELD switch the low voltage light
begins to flash telling me that that warning indication is working. I then
turn on my essential bus** and then turn off the battery master and the
radio master (yes I have one ##) to ensure that my Garmin 430W and my
transponder continue to operate off the battery which is now feeding the
avionics essential bus. The Garmin 430W and the transponder are essential
for me to return to my home field inside the Washington DC SFRA.
Please let me know if I have confused or clarified the issue raised by
Mike's original question.
'OC' Says: "The best investment we can make is the effort to gather and
understand knowledge."
**PS: Yes I am aware that there are means of causing this to happen
automatically with a diode, but the guy who wired my panel did not do it
that way and I have been living very happily with what he provided because I
understand the system.
##PS: Again this was given to me (after I paid big money to have the panel
built), but I have access to the avionics that I need via an essential
avionics bus so I have been living very happily with what he provided
because I understand the system.
Time: 06:49:13 PM PST US
Subject: Re: Why have a switch on ALT Field?
better.
excess
but
indicator.
aircraft.
switch is
Mike "Nemo" Elliott
RV-8A QB (Fuselage)
Posted: Sat Sep 26, 2009 8:40 am Post subject: Why have a switch on ALT Field? |
At 08:47 PM 9/25/2009, you wrote:
think this will add to everyone's education.
That's not the bottom line . . .
We should start with some design goals in mind.
For all of my career in TC and OBAM aircraft,
I've embraced and designed systems that meet
traditional goals for any time, any conditions,
On-0ff control of the engine driven power source(s).
low voltage items.
This isn't about using breakers as switches, it's
about meeting the design goal cited above. The b-lead
breaker on an alternator COULD be used to disconnect
the alternator assuming (A) the alternator is under
control [producing 14 or so volts] and (B) the
breaker is on the panel and pullable [many TC aircraft
have push-only breakers]. The classical control philosophy
for engine driven power sources has been a SWITCH in
reach of the crew that offers control over the field
excitation . . . always a low current, easy-to-manage
task. This task COULD be managed by flipping a switch
-OR- pulling the field supply breaker . . . it's your
choice.
There are other legacy design goals . . . like automatic
and absolute control of the alternator in case of
a failed regulator in an OV runaway condition.
Figure Z-24 is but one of several recipes for success.
When Z-24 was combined with alternators NOT designed
and tested to withstand their own load-dumps that some
builders experienced alternator failures immediately
after turning them off while under load.
You have given me the data I was looking for, I now understand
No . . . its about dependance on pulling
of a b-lead breaker for the purpose of taking
a runaway alternator off line. This is a shaky
design goal due to the fact that a failed alternator
can deliver 100-200 volts in a runaway condition.
Attempting to do this reliably with a 32-volt rated,
pullable breaker would very likely fail the breaker.
Further, pulling a b-lead breaker to mitigate an
ov condition puts human perception, decision, reaction
delays into the shutdown event. That's never been
embraced by the TC aircraft world that I'm aware
of.
The issues before us are (1) design goals for
control (2) design goals for automatic millisecond-
fast mitigation of an OV event. You can pull a
field breaker for (1) if you wish . . . but NOT
a b-lead breaker for (2).
rvg8tor
Posted: Sat Sep 26, 2009 9:17 am Post subject: Re: Why have a switch on ALT Field? |
My design goal is a system that is simple as possible but still meets capacity and redundancy goals (glass IFR bird). Thankfully I found Z12 and this design suits my need.
My assumption not mentioned by me so far, is that I will have an alternator that will have a controllable filed with OV protection, be that with internal or external regulation. I never thought of controlling the alternator with the "B" lead. So just looking at the Z12 diagram I pondered whether I needed the switch for the alternator field, I was looking for way to simplify where I could.
My CB panel will all be in easy reach by my right leg, the CB layout has 4 breakers at the end of two rows to make then stand out from the rest, I also plan to have them with colored collars, this would make finding them in the dark easy. Two at the end of the top row are for the primary and standby alternator fields. Two at the end of the next row control 12V power to the L/R P-mags respectfully. Also the two rows are not the same length, this also allows for identification in the dark. Top row is shorter, last two breakers are MAIN ALT then STBY ALT, easy to remember easy to find.
I know a toggle switch will be faster to actuate than finding a breaker but not by much. So would elimination of the switch change the design goal of Z12, would I not still have a controllable engine driven power source? I guess from what I have read so far the answer is no. Even though the switch will be used very little, it is still required?
RV-8A QB (Engine)
ianxbrown
Posted: Sat Sep 26, 2009 9:45 am Post subject: Why have a switch on ALT Field? |
OK, now here's one more vote for "confused". I thought the circuit breaker was supposed to be rated at the output amperage of the alternator because it's that current that one wants to limit. My 40A circuit breaker would do nothing for me on the alternator field circuit.
As I understand it, the switch is on the alternator field low-current 12V line (called IGN on my alternator) and the circuit breaker protects the output side (B lead). Mine is wired this way because it made sense.
Ian Brown,
RV-9A, Bromont, QC
On Sat, 2009-09-26 at 07:53 -0400, bakerocb(at)cox.net wrote: | Quote: | | Quote: |
--> AeroElectric-List message posted by: <bakerocb(at)cox.net (bakerocb(at)cox.net)>
9/26/2009
baffled.
alternators.
24..
open that circuit.
switch is
issue.
huge amperage flow.
From: "rvg8tor" <rvg8tor(at)comcast.net (rvg8tor(at)comcast.net)>
better.
excess
but
indicator.
aircraft.
switch is
Mike "Nemo" Elliott
RV-8A QB (Fuselage)
Posted: Sat Sep 26, 2009 9:53 am Post subject: Why have a switch on ALT Field? |
At 06:53 AM 9/26/2009, you wrote:
<Snip>
by Mike's original question.
Your words appear to paint a clear understanding . . .
The problem with this (and many threads of similar discussion
in the past) is the stirring of a LOT of simple-ideas (facts)
into one pot of ill-conceived stew (no definition of design
goals) and stirred over a hot fire ("don't do that or you're
gonna die") with the unbridled enthusiasm (mis-interpretation
of words).
and understand knowledge."
Yup, you got that right. I notice that my response to Mike's
follow-up hasn't passed through the server yet . . . but
I hope it proves to be a useful clarification of how we . . .
(1) start with design goals . . .
(2) then craft an architecture that addresses design
goals while . . .
(3) eliminating single points of failure for extra ordinarily
useful electro-whizzies as revealed by skillfully
conducted FMEA.
(4) Study and understand the specs for ingredients that go
into recipes for success.
(5) Select style, quality and a minimized quantity of components
that go into the proposed recipe.
(6) Verify that the recipe meets design goals.
(7) Analyze subsequent failures to deduce root cause.
Wear out? Mis-application? Robustness? Quality?
Error of stating or conformance to design goals?
Other? Answers to these questions may prompt a program
review that goes all the way back to step (1).
When one makes a career of this process, you eventually
discover that it's a Mobius Loop which strives for archiving
a host of lessons-learned while improving upon the best we
know how to do. This is the essence of good design engineering
as I've come to understand it.
Its interesting but frustrating that there are so many
pitfalls that put the 7-step process at risk. We're
fortunate that until recently, loss of the entire
electrical system was unlikely to force an airplane
down.
Now that we've embraced performance advantages of modern
electronics to control engines, there's a pressing
need to craft an architecture with particular attention
to step (3). This is relatively easy to do if the
seven steps are dutifully observed . . . but it's
easy to be distracted from the process if
excited rhetoric borne out of misunderstanding
dominates the tenor of the discussion.
So while we "gather and understand knowledge" (become
designers) we must be ready to calmly defuse
excitement with lucid explanation of simple-ideas
and how they become ingredients that go into recipes
for success (become teachers).
rvg8tor
Posted: Sat Sep 26, 2009 11:14 pm Post subject: Re: Why have a switch on ALT Field? |
I know you are trying to help but, this last post does not seem to help me, it actually confuses me. I respect your experience but I am not trying to design an electrical system from scratch, much like I did not design my RV-8A from scratch. I picked a plane from a good designer (Van's). While building I study the plans and try to understand how the parts relate to be a better builder, if I have a question I call builder assistance and I ask questions on the forum.
When it came to the electrical system, I went with a design from an expert in the field, in studying the design I asked a simple question,
'why is the alternator field switch needed". There have been a lot of words written, much of which my little brain doesn'tunderstand how it relates to the very simple question. The possible answers I was expecting were:
1. It has always been done that way
2. It doesn't matter the non-switch method will work but has these limitations (fill in the blanks)
3. You need the switch because if you don't have one it will cause XYZ.
Some of what you wrote I get but I really just need the simple short answer, not a run down on design philosophy. Since you designed the systems I thought of all people you could provide the best explanation. I thank you for attempting to answer my questions, if nothing else you have convinced me not to deviate from the Z diagram. I can't say that I understand fully why the alternator field switch is a requirement other than to provide a convenient way to turn off the field. I look forward to the simple answer if there is one.
RV-8A QB (Engine)
jay(at)horriblehyde.com Guest
Posted: Sun Sep 27, 2009 2:16 am Post subject: Why have a switch on ALT Field? |
Hi there Mike,
Perhaps I can shed a bit of light on your questions. The switch is used as
it switches a smaller current than would be required on the B-lead; thus you
can use a switch and not a contactor. By switching off the field you have
effectively switched off the alternator in its entirety, not just its
output.
Now its just a spinning mechanical device. If you switch the output (B
lead) then you have a live spinning device and if the fault is inside the
alternator then you're still feeding it...
Utilising the field to switch the alternator also allows you to fit in
overvoltage protection that will quickly detect and clear any overvoltage
fault that would fry all your avionics leaving you with a damaged alternator
AND no instruments (electrically powered ones in any case); whereas, if the
overvoltage fault is detected and cleared you can still run the instruments
on the battery.
If you have an internally regulated alternator then you need to switch the
output by using a contactor close to the alternator, because you cannot
access the field winding wire. Protecting the alternator by using a panel
mounted CB means that you lead a fat wire into the cockpit to the breaker in
your panel, which in turn means that there is a long bit of fat wire that is
unprotected- that long bit from the alternator to the CB. Personally I
don't like that.
If you use a contactor that is close to the source (alternator or battery)
then the only unprotected bit of fat wire is that bit between the source and
the contactor. A short bit of fat wire is unlikely to fault, or has a
higher reliability because it is short and mechanically robust. The closer
a contactor is to the voltage source the better your chances of removing the
power source from a fault.
Jay
rckol
Posted: Sun Sep 27, 2009 5:41 am Post subject: Re: Why have a switch on ALT Field? |
Mike,
Here is a response without embellishment.
snip [You need the alternator field switch because there is no alternator field breaker in Z-12. A fuse is used instead. ]
The statement above is false. I should have consulted the diagram instead of going from memory. Items 1 and 2 below are still valid.
You could use the breaker as a switch , but I wouldn't because:
1. You will be switching the field on and off at least once on every flight and a normal breaker is not designed to be a robust switch.
2. You could use a "switch-breaker", but I have heard so many stories about these having short life spans (at least the reasonably priced ones) that I would not put one in my aircraft.
_________________ rck
bakerocb
Posted: Sun Sep 27, 2009 5:50 am Post subject: Why have a switch on ALT Field? |
9/27/209
Hello Ian, Thanks for reading my post and responding. Please let me make an
attempt at reducing your confusion. You wrote:
1) "As I understand it, the switch is on the alternator field low-current
12V line (called IGN on my alternator) ........"
Can you both turn ON (activate) and turn OFF (deactivate) your alternator's
electrical output with this alternator field switch?** This is generally
considered a desireable design goal.
There are some internally regulated alternators that, once activated, draw
their field current from inside the alternator and it is not possible to
deactivate those alternator's electrical output by turning OFF an external
field switch. While this subject has been hotly debated several times on the
aeroelectric list it is generally considered that the feature of not being
able to shut down the alternator's electrical output with an external field
switch is an undesirable design goal.
2) "..........the circuit breaker protects the output side (B lead)."
The primary purpose of a CB or fuse in the B lead is to protect the wiring
in the B lead. This wiring normally goes from the positive terminal of the
battery to a main battery contactor and then onto the B output terminal of
the alternator. If this wiring should encounter a short to ground the
BATTERY could dump a huge amount of amperage into the wiring and cause a
fire. Therefore the primary purpose of the CB or fuse in the B lead wiring
is to protect the wiring from BATTERY electrical output.
But since there are alternators that could "run away" and not be shut down
by a switch in the circuit providing electricity to the alternator's field
some people who have those kinds of alternators look upon the CB in the B
lead as a means of cutting off the excess electrical flow from the
alternator.
Depending upon the manual pulling of a circuit breaker in the B lead as the
only means of terminating an over voltage situation or a "run away"
alternator is generally not considered a desirable design goal.
Does this help?
**PS: I'd be interested in knowing how your alternator field switch does
work and if you have an externally or internally regulated alternator?
Time: 10:45:24 AM PST US
sense.
Ian Brown,
RV-9A, Bromont, QC
Joined: 28 Mar 2008 Posts: 1972 Location: Riley TWP Michigan
Posted: Sun Sep 27, 2009 7:07 am Post subject: Why have a switch on ALT Field? |
This is the way I understand it. Please correct me if I am wrong.
The alternator output current does not need to be limited by a circuit breaker because the alternator output is self-limiting. If one were to add more loads to a fully loaded alternator, the voltage would drop, thus limiting the current automatically. It is not desired to unnecessarily run the alternator B lead into the cockpit. The B-lead circuit breaker is not necessary, and adds weight, cost and complexity. The purpose of an ANL fuse on the alternator output is not to protect the alternator or to prevent it from producing more than its rated current. The purpose of the ANL fuse is to protect the wires between the battery and alternator from 400+ amps of battery current in the event that the alternator shorts out, most likely from shorted diodes.
In the event that an over-voltage condition occurs (due to a faulty regulator), an over-voltage module will short out the supply voltage that goes to the alternator field. If that happens, an alternator-field circuit breaker will trip, thus protecting the wires from excessive current resulting from this short circuit.
Joe
_________________ Joe Gores |
Kellym
Posted: Sun Sep 27, 2009 7:57 am Post subject: Why have a switch on ALT Field? |
rckol wrote:
Why?? Is there a need to turn the alternator on/off separate from the
master if it is functioning correctly?
| Quote: | 2. You could use a "switch-breaker", but I have heard so many stories about these having short life spans (at least the reasonably priced ones) that I would not put one in my aircraft.
The Klixon switch breakers in my Mooney are almost all OEM from 45
years/6000 hours ago. A couple have been replaced from springs getting weak.
KCHD |
tonybabb(at)alejandra.net Guest
Posted: Sun Sep 27, 2009 10:27 am Post subject: Why have a switch on ALT Field? |
Jay,
Thank you so much. Spelling out what may be obvious or intuitive to
experienced hands is a great assistance to us neophyte electron herders.
Tony
Velocity SEFG 62% done, 78% to go
www.alejandra.net/velocity
Posted: Sun Sep 27, 2009 1:18 pm Post subject: Why have a switch on ALT Field? |
At 09:58 AM 9/27/2009, you wrote:
| Quote: | This is the way I understand it. Please correct me if I am wrong.
The alternator output current does not need to be limited by a circuit breaker because the alternator output is self-limiting. |
correct
| Quote: | | If one were to add more loads to a fully loaded alternator, the voltage would drop, thus limiting the current automatically. |
yes
| Quote: | | It is not desired to unnecessarily run the alternator B lead into the cockpit. |
yes
| Quote: | The B-lead circuit breaker is not necessary, and adds weight, cost and complexity.
| Yup . . .
| Quote: | | In the event that an over-voltage condition occurs (due to a faulty regulator), an over-voltage module will short out the supply voltage that goes to the alternator field. If that happens, an alternator-field circuit breaker will trip, thus protecting the wires from excessive current resulting from this short circuit. |
Yes . . . this is a property unique to the
crowbar philosophy for opening the alternator's
field supply after an ov condition is detected.
There are other designs that do not open the
field supply breaker . . . and can be considered
as a potential player in your design goals.
The reason that Z-figures featuring crowbar
ov protection -AND- fuseblocks have a field
supply breaker is to accommodate the crowbar
ov control philosophy. If non-crowbar shutdown
products are considered, then one could easily
supply alternator field through one of the
fuses and leave the circuit breaker out.
( -Thomas Paine 1776- )
Posted: Sun Sep 27, 2009 1:26 pm Post subject: Why have a switch on ALT Field? |
the master if it is functioning correctly?
Depends on your architecture. Does the MASTER control
the alternator too? Is the MASTER a progressive transfer
two-pole switch or classic "split rocker". Then indeed,
the alternator field breaker may never need to be touched.
But if the MASTER is a simple two-pole switch that controls
alternator and battery at the same time, then you could
use the field breaker to shut the alternator down for
battery-only ground-ops.
2. The Klixon switch breakers in my Mooney are almost all OEM from 45
But the Potter-Brumfield W31 style breakers installed in
many other airplanes for about the same length of time
have been identified has having a safety of flight
failure mode that is prompting an AD to replace about
80,000 of the critters. Not all switch breakers are
alike. All are much more expensive than the fuse/switch
architecture featured in the Z-figures.
bakerocb
Posted: Mon Sep 28, 2009 5:35 am Post subject: Why have a switch on ALT Field? |
9/28/2009
Hello Again Mike, You wrote: "I look forward to the simple answer if there
is one."
Let's try this -- How do you intend to simulate or check the continued
functioning of essential for flight avionics items when you are airborne and
have a non functioning alternator because: the field wire broke,** the belt
broke, or whatever?
Here is my answer: At the end of each flight while the engine is still
running I turn off the alternator by means of its field switch and ensure
that:
A) The essential for flight avionics items (Garmin 430W and transponder) can
still function off an essential bus. (These items needed to return to my
home field inside the Washington DC SFRA.)
B) My low voltage warning system (a flashing light) is still functioning.
Discussion:
1) Why not perform check A above at the beginning of each flight before the
engine is started and the alternator is not yet putting out current?
Because: a) I do not have my Garmin 430W and transponder turned on prior to
or during engine start, and b) I don't want to put the electrical burden of
the Garmin 430W and transponder on the battery before engine start.
2) Why not perform check B above at the beginning of each flight before the
engine is started and the alternator is not yet putting out current? That
check is indeed accomplished as soon as the master battery contactor is
closed at the beginning of the flight. The B check at the end of the flight
is a duplication of the before flight B check and is just a system design
fall out in order to perform check A.
3) Why not just use pulling the alternator field CB as a means of turning
off the alternator at the end of each flight? I have not priced the cost
differential between replacing my fancy, internally illuminated, rocker
activated, alternator field switch and the alternator field CB, but I do
know this: a) The switch is designed to be switched on and off thousands of
times, the CB is not, and b) It will be much easier for me to replace the
switch than the CB.
So please let me know what you decide regarding whether or not you will
install the alternator field switch and what were the deciding factors in
that decision. Thanks.
**PS: This happened to a friend of mine in his Beech Sierra just a few
months ago. He has no low voltage warning system other than looking at an
aftermarket automotive gadget voltmeter plugged into his cigarette
lighter -- not very visible. His first real warning was when his VHF comm
began to not work properly because the battery was becoming depleted. Soon
he had no electronic nav functions either.
He was on an IFR flight plan, but in VMC. He spotted a little podunk airport
and landed. A mechanic at the airport quickly diagnosed the problem,
repaired the wire, and my friend was on his way shortly. But what if he has
been in IMC? What if he had not spotted podunk airport? What if there was no
repair person or facility at podunk airport?
Using your word "convenient" do you think that he would have had a
convenient termination of that flight?
Time: 12:20:59 AM PST US
it
design
study
forum.
in the
written,
limitations
not
of
attempting
off
Mike "Nemo" Elliott
RV-8A QB (Fuselage)
Posted: Mon Sep 28, 2009 6:27 am Post subject: Why have a switch on ALT Field? |
expert in the
of words written,
simple question.
I'm sorry if my words are too much for you.
When I wear my teacher-hat, the answers
I offer are intended to lead to understanding of
the foundation upon which the answer is based.
It's my belief that once understanding is
achieved, the student then becomes a teacher
on the same discussion. Perhaps I presume too
much . . . that everyone here on the List is
as enthusiastic about understanding as I . . .
| Quote: | The possible answers I was expecting were:
Okay, with my expert-hat on, that answer works
for me.
Fly comfortably my friend . . .
Neal.George(at)hurlburt.a Guest
Posted: Mon Sep 28, 2009 7:55 am Post subject: Why have a switch on ALT Field? |
Keep at it Bob -
I generally need to be told more than once.
As for the presentation style, I learn more than electron herding here.
Too many of us can barely speak, much less write...
neal
 Download |
| Filename: |
smime.p7s |
5.04 KB |
| Downloaded: |
560 Time(s) |
