pj.ladd(at)btinternet.com Guest
Posted: Sun Sep 20, 2009 1:26 pm Post subject: Oil problem |
hi,
I run a jabi 2200 on a Kolb 3xtra microlight her in the UK and have a
problem
On starting the oil pressure goes at once to its proper place but over about
10 minutes it starts to decay. In half an hour it is right back at the start
of the yellow quadrant.
I am no mechanic but I think filter and pump as the first place to
investigate. Any comments? Only about 70 hours on the engine.
Cheers
Pat
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
plus2s
Posted: Sun Sep 20, 2009 2:10 pm Post subject: Oil problem |
2 Questions Pat
What oil are you using ? and at what revs is it in the yellow ?
presume you have changed the filter twice by now
Keith
--- On Mon, 21/9/09, pj.ladd <pj.ladd(at)btinternet..com> wrote:
Subject: Oil problem
To: jabiruengine-list(at)matronics.com
Received: Monday, 21 September, 2009, 9:22 AM
--> JabiruEngine-List message posted by: "pj.ladd" <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)>
hi,
I run a jabi 2200 on a Kolb 3xtra microlight her in the UK and have a problem
On starting the oil pressure goes at once to its proper place but over about 10 minutes it starts to decay. In half an hour it is right back at the start of the yellow quadrant.
I am no mechanic but I think filter and pump as the first place to investigate.. Any comments? Only about 70 hours on the engine.
Cheers
http://www.matronic/forums.matronics.com/" target=_blank>http://forums.matronics.com
bsp; -Matt Dralle, List m/contribution" target=_blank>http://www.matronics.com/contribution
| [quote][b]
imap8ntr(at)cox.net Guest
Posted: Sun Sep 20, 2009 2:44 pm Post subject: Oil problem |
Good Questions.
Just for curiosity do you notice more oil consumption when using multigrade oil that when using 100W?
I notice that when my oil filter gets to be about 25 hr old oil pressure starts to drop and it is time to change everything. I get better oil pressure and longer when using the NAPA Gold filter than the Fram cheepo.
Ivan
Phoenix, AZ
zeprep251(at)aol.com Guest
Posted: Sun Sep 20, 2009 3:54 pm Post subject: Oil problem |
Pat,
With engine cold my oil pressure is about 40 psi.As the oil temp starts to climb the pressure runs up to 60 psi.After the normal oil temp is attained the pressure returns to 40 psi and about 25 psi at 900rpm warm idle.Sound familiar?
G.Aman MK-3C Jabiru 2200A 475hrs
Thom Riddle
Posted: Mon Sep 21, 2009 3:27 am Post subject: Re: Oil problem |
Pat,
If your engine has the VDO oil pressure sending unit, that could be the problem. They are notorious for low indication after some time in service. If you can get your hands on an accurate mechanical oil pressure gauge to confirm the actual oil pressure under same conditions, this should help you diagnose the source of the low reading. I have both a mechanical oil pressure gauge installed and the VDO sending unit giving its signal to the Grand Rapids EIS. The EIS oil pressure reading is generally about 5-7 psi lower than the mechanical gauge.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
pete(at)usjabiru.com Guest
Posted: Mon Sep 21, 2009 6:17 am Post subject: Oil problem |
More likely the oil pressure sending unit
Pete
Posted: Mon Sep 21, 2009 7:49 am Post subject: Oil problem |
problem.>>
Hi Thom.
Flew to a repairer about 30 minutes away this morning. The fix which he
suggested involved removing the filter and putting another washer behind the
spring which keeps the relief valve from opening. Thinking was that if the
spring is a bit weak the relief valve is opening at too low a pressure.
this seemed to make sense but as he didn`t have a replacement filter we
decided to postpone the job for a couple of days.
However while furkling about we noticed the the VDO sensor was just touching
the exhaust pipe so we moved the exhaust about 1/4 inch. Flying home the
pressure didn`t drop below 200. Has this fixed the problem?. maybe. Further
flying required and by the time I landed it had got so rough I did not want
to fly again so i wait for another window.
Thanks everyone for their input. It may be needed yet.
Cheers
Pat
Kayberg(at)aol.com Guest
Posted: Mon Sep 21, 2009 8:50 am Post subject: Oil problem |
Pat,
The advice you got from Pete at USJabiru was not from ignorance. It was from the largest dealer of Jabiru engines and aircraft in the world.
The senders frequently have problems. Change washers only after you change the sender.
Doug Koenigsberg
In a message dated 9/21/2009 11:50:02 A.M. Eastern Daylight Time, pj.ladd(at)btinternet.com writes:
| Quote: | --> JabiruEngine-List message posted by: "pj.ladd" <pj.ladd(at)btinternet.com>
problem.>>
Hi Thom.
Cheers
Pat
Posted: Tue Sep 22, 2009 1:40 am Post subject: Oil problem |
change the sender.>>
Hi Doug,
thanks for the head up. I have changed the sender once already.
Pat
dons701
Posted: Thu Sep 24, 2009 6:51 am Post subject: Oil problem |
using a tee under the electric sender. >>
Hi Don,
that would seem a practical solution. Unfortunately the gap between the VDO
and part of the exhaust is just about enough to unscrew the VDO. Certainly
not enough to introduce another fitting.. I am not saying that it cant be
done but I suspect that I would finish up with a Christmas Tree of fittings
probably starting with a 90 degree bend to clear the exhaust. We will see.
Maybe my slight re arrangement of the exhast will sove the problem. Roll on
the next opportunity to fly and test.
Thanks for your suggestions everybody
Pat
Clive J
Posted: Fri Sep 25, 2009 12:05 am Post subject: Oil problem |
Pat, I can't picture where the exhaust is near the sender?
There are two tapping's on my engines and neither is anywhere near the
exhaust.
Am I missing something?
Regards, Clive
2200 Jab SP
3300 Esqual LS
jetboy
Posted: Fri Sep 25, 2009 1:08 am Post subject: Re: Oil problem |
My original sender failed at around 150 hrs and was replaced with a genuine VDO but placed in the lower port, the one that points directly ahead. I opened up the original and the thin wire resistance coil inside had worn through.
I fitted a low pressure warning switch to the upper port, as backup.
From an engine health point of view, the lower port is at the main gallery and is the best one to monitor oil pressure delivered to the engine. It reads about 7 psi lower. Why the original sender measures blocked oil filters and pulsations from the pump is a mystery.
If you have a hydraulic lifter engine and change the relief valve washers it can get expensive.
_________________ Ralph - CH701 / 2200a |
Posted: Fri Sep 25, 2009 6:26 am Post subject: Oil problem |
Hi Clive
I am not surprised. It is a pusher installation with a very convoluted
exhaust array with two vertical pipes (among other things). One of them just
to the rear of the VDO and justs clears it. In fact it is so close it is a
difficult job to get enough clearance to change the VDO.
As I said in my previous post The exhaust had moved slightly. Just enough to
make physical contact with the topedge of the VDO.
I pulled the exhaust to the rear and was able to rebolt it to give about
1/4 inch clearasnce. I flew this morning for an hour and the oil pressure
went to 350 kpa immediately at start up. It dropped to 230 within 6 minutes,
about take off time, and remained at 200/230 kph until I landed so it seems
that the problem is solved as 230kph puts the on the top edge of the yellow
segment on the instrument..
Just for the record this was at 2800 rpm which produces 70 mph.
Once again thanks to everyone for their suggestions.
Cheers
Pat
dons701
Posted: Fri Sep 25, 2009 6:47 am Post subject: Re: Oil problem |
Good! It does make sense as the sender works by resistance and intense heat could make the difference. Perhaps some insulating header wrap or sleeving could ensure reliability, if there is room that is !!
Don
_________________ Zenith 701 #76120
Jabiru 2200A #2456 95 hours
Sensenich Wood 64-PJ-36 Prop |
Thom Riddle
Posted: Fri Sep 25, 2009 8:36 am Post subject: Re: Oil problem |
Pat,
You must have a different sort of exhaust system on your Jabiru than I have. I wouldn't doubt it since your noise regulations are stricter than ours in the USA. Attached is a photo of the right rear quarter of my Slingshot. It is high enough resolution that you can zoom in for more detail. What you can't see because it is hidden by the prop, is the oil pressure sending unit (VDO). It is mounted above the base of the oil filter on a Tee with a hard copper line to the mechanical oil pressure gage and the electrical signal going to the EIS. As you can see, the exhaust sy
Buffalo, NY (9G0)
- Anonymous |
Thom Riddle
Posted: Fri Sep 25, 2009 8:38 am Post subject: Re: Oil problem |
accidently hit return key,
....As you can see, the exhaust system is not in play with the VDO oil pressure sender. Do you happen to have a photo of your exhaust system installed? I'm curious about how convoluted it might be to get the silencing results required in the UK.
Buffalo, NY (9G0)
- Anonymous |
Thom Riddle
Posted: Fri Sep 25, 2009 8:41 am Post subject: Re: Oil problem |
Senior moment again. I forgot to attach the photo. Here it is.
2.31 MB |
21446 Time(s) |
Buffalo, NY (9G0)
- Anonymous |
Posted: Sat Sep 26, 2009 6:14 am Post subject: Oil problem |
there is room that is !!>>
Hi Don
The removal of the actual contact between the VDO and the exhast has
obviously worked but there must still be a fair amount of heat radiated
through the air and this probably affects the temp. sensor also.
Anyone have any suggestions for a meterial which
a) will not pass or will totally reflect heat
b) a thin material, not more than an 1/8th inch. Thinner is better.
c)something easily worked and fixed by a mechanic with five thumbs and no
training.
Cheers
Pat
dons701
Posted: Sat Sep 26, 2009 7:08 am Post subject: Re: Oil problem |
Hi Pat, There is one company called Thermotec that makes many products associated with insulating and controlling heat for automotive racing. They have a header wrap that is 1/16" thick by 1 to 2 inches wide offered in black or tan color that withstands a continuous 2000 degrees. Black would look good for your aircraft. There may be other products out there now but this product comes to mind as I used it many hotroding years ago. If you download their catalog from their website and go to page 4 you will see what I am suggesting. In addition and if needed, you could install some of the heat shielding material over the sender. I like their fire sleeving for wires. You only need two thumbs. Don.
