ianxbrown
Posted: Thu Sep 24, 2009 9:54 am Post subject: Leaky air inlets on RV-9A |
My RV-9A is starting to chill my wife! As the weather gets cooler we've noticed significant amounts of air coming in through the control stick holes and also out of the edges of the mounting of the eyeball vents. The Van's drawing calls for the removal of the fourth hole on the mounting (the one you would catch your leg on) and this seems to result in a slightly open joint, especially under air pressure. What have others done about both problems. I realize putting a boot over the stick will help that area, but unfortunately I just bought nice looking automotive gear shift boots that have lots of fancy little holes in them! Any ideas for what material would be light, flexible and draughtproof??
Beautiful flying day!
Ian Brown
Bromont, QC, C-GOHM
HCRV6(at)comcast.net Guest
Posted: Thu Sep 24, 2009 10:24 am Post subject: Leaky air inlets on RV-9A |
I solved the leaking Van's air vent by replacing them with the beautifully machined aluminum vents that screw together and clamp that leaky bottom corner joint airtight. The leak around the control stick requires boots around the aileron push rods at the fuselage side and an airtight stick boot. Those two things solved 90% of the cold air leaks in my RV-6 slider. Now my wife just complains about the slight draft on the back of her neck from the rear canopy slide. I haven't bothered to work on that yet.
Harry Crosby
RV-6 N16CX, 616 hours
david.nelson(at)pobox.com Guest
Hi Ian,
For the push-rod boots:
http://home.hiwaay.net/~sbuc/journal/cold.html#boots
For the air-vents, I bought a set (very nice metal ones) from Stein Air:
http://www.steinair.com/eyeballvents.htm
/\/elson
~~ Lately my memory seems to be like a steel trap .... without any spring. ~~
On Thu, 24 Sep 2009, Ian wrote:
| Quote: | My RV-9A is starting to chill my wife! As the weather gets cooler we've noticed significant amounts of air coming in through the control stick holes and also out of the edges of the mounting
Ian Brown
Bromont, QC, C-GOHM
Posted: Thu Sep 24, 2009 10:43 am Post subject: Leaky air inlets on RV-9A |
draughtproof??
Get ripstop nylon from a fabric store. Comes in lots of colors! You
can also order stick covers and aileron pushrod covers from most
experimental interior suppliers.
Linn
Ian Brown
Bromont, QC, C-GOHM
retasker(at)optonline.net Guest
The main source of air coming up through your control stick area comes
in from the wings. An aileron boot such as Flightline Interiors sells
would go a long way to removing that as a source of cold. You could
also make your own if you are good with a sewing machine. Just use
coated nylon or similar and make a cone shaped assembly that attached to
your aileron pushrod and the edges of the holes in the sidewall.
See http://www.flightlineinteriors.com/products/construction/default.asp
Dick Tasker
and draughtproof??
Ian Brown
Bromont, QC, C-GOHM
bmeyette
Posted: Thu Sep 24, 2009 10:50 am Post subject: Leaky air inlets on RV-9A |
try Abby at FLightline Interiors for aileron rod boots
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ian
Sent: Thursday, September 24, 2009 1:38 PM
To: rv-list(at)matronics.com
Subject: Leaky air inlets on RV-9A
Ian Brown
Bromont, QC, C-GOHM
Checked 270.13.112/2392 - Release Date: 09/24/09 05:52:00
_________________ Brian Meyette, Cornish, NH
RV-7A QB tipup, supercharged Subaru STi engine, MT CS prop, all glass day/night/IFR panel, being built with solar and wind power
N432MM
http://brian76.mystarband.net/RV-7Ahome.htm |
Vanremog(at)aol.com Guest
Posted: Thu Sep 24, 2009 6:32 pm Post subject: Leaky air inlets on RV-9A |
rainproof poncho material in olive drab is what I used for the pushrod boots to the fuselage wall. The stickboots are DJs. Very little airflow when you do the pushrod boots.
In a message dated 9/24/2009 10:54:55 A.M. Pacific Daylight Time, ixb(at)videotron.ca writes:
| Quote: | My RV-9A is starting to chill my wife! As the weather gets cooler we've noticed significant amounts of air coming in through the control stick holes and also out of the edges of the mounting of the eyeball vents. The Van's drawing calls for the removal of the fourth hole on the mounting (the one you would catch your leg on) and this seems to result in a slightly open joint, especially under air pressure. What have others done about both problems. I realize putting a boot over the stick will help that area, but unfortunately I just bought nice looking automotive gear shift boots that have lots of fancy little holes in them! Any ideas for what material would be light, flexible and draughtproof??
Ian Brown
Bromont, QC, C-GOHM
 Download |
| Filename: |
Boot.dwg |
35.33 KB |
| Downloaded: |
631 Time(s) |
Charles Heathco
Posted: Thu Sep 24, 2009 7:38 pm Post subject: Leaky air inlets on RV-9A |
The thing I do re air inlets is put a strip of duct tape over the inlet
Never had one blow off. Its aboujt time to do that again. (pull of when
warms up) Charlie H
PeterHunt1(at)aol.com Guest
Posted: Sun Sep 27, 2009 6:55 pm Post subject: Leaky air inlets on RV-9A |
Yes, coned shaped boots on the aileron pushrods where the pushrods exit the fuselage into the wing are very important to cutting down cold drafts. I made mine out of sail cloth material available at the local sailing/marine store. Use a pipe clamp to hold the small end of the cone to the pushrod and make a large donut ring to hold the large end to the fuselage opening to the wing. The flexible cone collapses/expands like an accordion when the pushrods are moved.
Pete in Clearwater
RV-6
stan(at)vangrunsven.us Guest
Posted: Mon Sep 28, 2009 8:42 pm Post subject: Leaky air inlets on RV-9A |
Hi Ian,
When we first flew the 6-A, in early spring, it leaked something awful. When the first passenger flew, his jacket sleeve was being tugged at by the air leaking OUT at the upper rail where we had not sealed the slider canopy. What I'm saying is that the low pressure over the wing was pulling air out of the cabin from every available hole. When we sealed the canopy sides above the wing most of the other areas were much more managable. We used some "V" seal with the opening blocking the direction of flow which is Out above the wing and IN along the rear skirt. Some other type seals also work, like "P" seals where the "bulb" is flexable enough move in the direction of air flow and get pushed against skirt or skin.
I hope this helps; many builders have never dealt with this area first.
Best wishes,
Stan VanGrunsven RV-6A April 1998
