wdleonard(at)gmail.com Guest
Posted: Wed Sep 23, 2009 5:22 am Post subject: Rotary BSFC |
| Quote: | On his forum/sandbox someone sent in two dyno sheets for a rotary.
The BSFC numbers were in the .65 range... Funny, not one person
> spoke up about that, not even the "wizzard".
Some people in the rotary community are sensitive about that. I got
smacked down on the RV List a few years ago for suggesting (based on
engineering references) that it was an accepted fact that rotaries
have a lower BSFC than piston engines, generally speaking. Being two-
strokes, effectively, and having a very poor surface-volume ratio in
the combustion chamber (compared to a piston engine) it's not
surprising that they would have low BSFC. I found it odd that anyone
even challenged the statement, but there you go.
Tedd McHenry
Surrey, BC
Tedd,
Rightly so that you got smacked down... lower BSFC is good, higher is bad. so 2-strokes have HIGH BSFC.
That being said, the rotary is in NO WAY (not effectively or otherwise) a 2-stroke.
David Leonard
Turbo Rotary RV-6 N4VY
http://N4VY.RotaryRoster.net
http://RotaryRoster.net
| | - The Matronics Engines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Engines-List |
tedd(at)vansairforce.org Guest
Posted: Wed Sep 23, 2009 6:15 am Post subject: Rotary BSFC |
On 23-Sep-09, at 6:19AM, David Leonard wrote:
| Quote: | Rightly so that you got smacked down... lower BSFC is good, higher
Good point. I meant "worse," not "lower," as you obviously realized,
but thanks for clarifying.
Tedd
tracy(at)rotaryaviation.c Guest
Posted: Wed Sep 23, 2009 3:25 pm Post subject: Rotary BSFC |
A rotary tuned for all out best power production (especially if ported for racing etc) might indeed clock in at .65 BSFC. That has little to do with what you can expect at cruise conditions in an aircraft application.
Using Van's Aircraft HP required vs airspeed chart published some time ago, I computed my BSFC at .45 - .47 BSFC at cruise conditions. That's a tiny bit worse than Lycoming numbers when run LOP but not enough to matter. Especially considering it happily burns 87 octane auto fuel.
Tracy Crook
On Wed, Sep 23, 2009 at 9:19 AM, David Leonard <wdleonard(at)gmail.com (wdleonard(at)gmail.com)> wrote:
Tedd McHenry
Surrey, BC
Tedd,
David Leonard
target="_blank">http://www.matronics.com/Navigator?Engines-List
tp://forums.matronics.com
| [b]
Posted: Wed Sep 23, 2009 4:17 pm Post subject: Rotary BSFC |
| Quote: | Using Van's Aircraft HP required vs airspeed chart published some
Tracy:
If your airframe has lower drag than Van assumed -- as it likely does,
due to your lower cooling drag -- then Van's power-required numbers
would have been too high, and the BSFC you calculated would have been
low. Any conservatism on Van's part (and he is famous for it) would
also have lowered your BSFC result.
Tedd McHenry
Surrey, BC
Posted: Wed Sep 23, 2009 5:36 pm Post subject: Rotary BSFC |
Tedd McHenry wrote:
Tracy:
Tedd McHenry
Surrey, BC
Possible, but not likely. It's pretty rare (do-able, but rare) for
homebuilt liquid cooled a/c to get cooling drag lower than a Lyc.
I've flown two 400+ mile cross countries in my 160 hp Lyc powered -4
with Tracy (he burns 87mogas, I burn 93mogas), flying the same flight
profiles for each flight, and each time he burned ~1.5-2.5 gal more than
me. My oil burn probably offset that difference.
It should also be noted that I lean my stock Lyc *far* more aggressively
than most Lyc drivers are willing to risk.
Charlie
Posted: Wed Sep 23, 2009 7:33 pm Post subject: Rotary BSFC |
I'm not familiar with Tracy's installation, specifically, but cooling
drag is one of the key advantages of liquid-cooled engines. You're
probably right that most homebuilts don't exploit that advantage very
well. You only have to look at the installations to see that. But,
given that Tracy's a pretty smart cookie, I'm giving him the benefit
of the doubt and suggesting that is why his BSFC estimate is optimistic.
The numbers Tracy published would be quite good for an automotive
piston engine. When I see numbers like that for a 13B-based rotary I
begin to look for alternate explanations.
Tedd McHenry
Surrey, BC
