Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27640 Location: Livermore CA USA
Posted: Fri Sep 18, 2009 7:58 pm Post subject: CB-1002-H Governor Bracket Installation Photos...? |
Dear Listers,
Van's turned me on to a bracket for the RV-10 called the CB-1002-H which is a bracket for mounting the governor control cable on front mounted governors.
Does anyone have some good pictures of how this bracket is installed? Maybe even a scan of the baffling installation OP sheet where the RV-10 baffling is described?
Since the IO-390 has a front mounted governor similar to the IO-540 used on the RV-10, some of these baffling pieces seem to work.
Any docs you could provide would be most appreciated!
RV-8 #82880 N998RV
Engine Baffling...
144.01 KB |
3912 Time(s) |
140.41 KB |
3912 Time(s) |
_________________ Matt Dralle
Lenny Iszak
Posted: Fri Sep 18, 2009 8:28 pm Post subject: Re: CB-1002-H Governor Bracket Installation Photos...? |
Matt,
See if this helps.
Lenny
420.27 KB |
3906 Time(s) |
rv10builder(at)bellsouth. Guest
Posted: Fri Sep 18, 2009 8:48 pm Post subject: CB-1002-H Governor Bracket Installation Photos...? |
Hope this helps...lower left of the photo.
45.83 KB |
3904 Time(s) |
AV8ORJWC
Posted: Sat Sep 19, 2009 10:49 am Post subject: CB-1002-H Governor Bracket Installation Photos...? |
Beautiful bracketry.
John Cox
