coop85(at)verizon.net Guest
Posted: Tue Sep 15, 2009 4:38 am Post subject: LOP (Lean of Peak) Injector Tuning |
Tim,
As always a great write-up, THANKS. Also a good slide show to support
the info. I'll be going up today to see what EGT I get at takeoff.
Marcus
40286
Tim Olson
Posted: Tue Sep 15, 2009 6:40 am Post subject: LOP (Lean of Peak) Injector Tuning |
Cool, will be nice to hear how it goes for you when you tune your
injectors. There's a side conversation that I've been having
with some people regarding LOP and planes that just can't
seem to run that way. We're learning a little, and I'm sure
we'll report back fairly soon. But, if you have an engine
that you just can't get to run LOP, you may want to drop
me a line. We've found something that looks to be specific
to the James Cowl users that can cause some issues. We're
still learning though.
Tim Olson - RV-10 N104CD
Marcus Cooper wrote:
Tim,
Marcus
40286
N777TY
Joined: 09 Apr 2006 Posts: 69 Location: Charlotte, NC
Posted: Tue Sep 15, 2009 5:22 pm Post subject: Re: LOP (Lean of Peak) Injector Tuning |
which James cowl? The regular one or the one for cold air induction? they're slightly different..
just helped my buddy go through the hoops of getting the injectors tuned, and results seem to be good.. this is on a -10 /w James cowl + BPE cold air engine.. (2 mags... for now)
_________________ RV-7A
N777TY |
Tim Olson
Posted: Wed Sep 16, 2009 11:24 pm Post subject: LOP (Lean of Peak) Injector Tuning |
I think on either.... The issue is seemingly with the airflow
blast coming in the round inlets, over the injectors. A small
air dam to lessen the direct flow changed things a lot.
More info coming in the future...
N777TY wrote:
-------- RV-7A N777TY
http://forums.matronics.com/viewtopic.php?p 63230#263230
speckter(at)comcast.net Guest
Posted: Thu Sep 17, 2009 4:43 am Post subject: LOP (Lean of Peak) Injector Tuning |
I have the standard inlets, but based on this list and Alan Barrett's
recommendation I put a small air dam in front of the front injector.
Raining down here this week so have not flown. Will keep you posted.
Gary Specketer
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Thu Sep 17, 2009 5:04 am Post subject: Re: LOP (Lean of Peak) Injector Tuning |
| speckter(at)comcast.net wrote: | I have the standard inlets, but based on this list and Alan Barrett's
Gary Specketer
Gary,
Any chance of you posting a picture or sending me one. Plane gets out of the paint shop this weekend if WX cooperates and balancing is one of the items on my to-do list.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
Tim Olson
Posted: Thu Sep 17, 2009 6:19 am Post subject: LOP (Lean of Peak) Injector Tuning |
Here's one.
orchidman wrote:
> Barrett's recommendation I put a small air dam in front of the
> front injector. Raining down here this week so have not flown.
> Gary Specketer
Gary, Any chance of you posting a picture or sending me one. Plane
-------- Gary Blankenbiller RV10 - # 40674 (N2GB Flying)
http://forums.matronics.com/viewtopic.php?p 63496#263496
108.55 KB |
14331 Time(s) |
Posted: Thu Sep 17, 2009 6:47 am Post subject: LOP (Lean of Peak) Injector Tuning |
Tim / Gary,
Please let us know your opinions of the results....
bcondrey
Posted: Thu Sep 17, 2009 6:55 am Post subject: LOP (Lean of Peak) Injector Tuning |
I've been slammed at work and have apparently missed something here...
Is the issue that incoming ram air is somehow disrupting the injector flow because of the air bleed hole in the injector itself?
RV-10 N442PM
Tim Olson
Posted: Thu Sep 17, 2009 7:48 am Post subject: LOP (Lean of Peak) Injector Tuning |
Yep. It's either the airflow or the pressure.
There is ongoing research, and there is so much
email going on that it's too much for the list right now.
We're going to let a couple things happen so we can
summarize it and then post all the info for a reference
for future builders.
Condrey, Bob (US SSA) wrote:
<bob.condrey(at)baesystems.com>
here...
Bob RV-10 N442PM
bcondrey
Posted: Thu Sep 17, 2009 8:04 am Post subject: LOP (Lean of Peak) Injector Tuning |
Great, thanks!
Posted: Thu Sep 17, 2009 8:10 am Post subject: LOP (Lean of Peak) Injector Tuning |
Some of us are having problems running LOP because the engine "stumbles"
when you go leaner than peak. The theory is that cyl #2 is running super
lean because of the ram air infiltrating the injector. The dam is an
attempt to fix that.
Gary Specketer
bcondrey
Posted: Thu Sep 17, 2009 8:49 am Post subject: LOP (Lean of Peak) Injector Tuning |
Isn't this something that you'd see on the EGT for that cylinder (peaking a lot sooner than the rest)? Just to state the obvious, is it safe to assume that folks with the issue have checked the alignment of the air bleed hole in the injector to make sure that it's oriented appropriately?
Tim Olson
Posted: Thu Sep 17, 2009 9:08 am Post subject: LOP (Lean of Peak) Injector Tuning |
Yes, and yes. It's visible on the EGT gauge, and yp, the holes all go
down. THere's more to the story, but it gets so involve we don't
want to type it over and over again. So waiting to get it all
compiled.
Posted: Thu Sep 17, 2009 10:40 am Post subject: LOP (Lean of Peak) Injector Tuning |
No idea if this applies to me but thanks Tim for the research with this. You
always seem to be in the leading edge of guidance.
Pascal
Sent: Thursday, September 17, 2009 10:07 AM
Subject: Re: Re: LOP (Lean of Peak) Injector Tuning
compiled.
> Bob
Tim Olson
Posted: Thu Sep 17, 2009 11:04 am Post subject: LOP (Lean of Peak) Injector Tuning |
This particular one isn't so much me doing the work as it is
others...I'm just participating. I did that LOP write up and
it all went well. There were others with issues that couldn't
run LOP....and some that had running problems even ROP slightly.
So we started a pretty email intensive discussion group and
piled on experiences and knowledgebase. People like Jason
Kreidler, Deems, Robin Marks, and others are to be commended
as well. With the combined reports and some trials of ideas
by them, we're digging through the issues that they're having.
The common thread is the James Cowl, so that got us head
scratching...but I remembered some things from previous online
reading that were helpful too. So we're going through a big
discussion and trying some ideas in order to get those
cowls to run LOP and run well in general, just like what
I've been experiencing.
It will be interesting in the end. I have gained a lot of
info too, because most of them are also using AFP injection,
and there are minor differences.
Sorry to not spread too much info right now, but really,
there is so much info and email that it would overwhelm
everyone and you would just have trouble sifting through and
keeping things straight anyway. So we're going to make a
couple planes run real well, and then report on what it took,
and what issues there were...so that others can get there.
You always seem to be in the leading edge of guidance.
Pascal
> compiled.
> Tim
>> Bob
partner14
Posted: Fri Sep 18, 2009 7:47 am Post subject: LOP (Lean of Peak) Injector Tuning |
Does anyone have a picture of this "air dam".
Thanks, Don
--- On Thu, 9/17/09, gary <speckter(at)comcast.net> wrote:
Subject: RE: Re: LOP (Lean of Peak) Injector Tuning
Date: Thursday, September 17, 2009, 5:43 AM
--> RV10-List message posted by: "gary" <speckter(at)comcast.net (speckter(at)comcast.net)>
Gary Specketer
40636 |
Bob Turner
Posted: Fri Sep 18, 2009 3:02 pm Post subject: Re: LOP (Lean of Peak) Injector Tuning |
There's a photo about 6 posts up.
_________________ Bob Turner
RV-10 QB |
