Andair Valves
Phil.Perry(at)netapp.com
PostPosted: Thu Sep 17, 2009 4:25 am    Post subject: Andair Valves Reply with quote
There’s a discussion on VAF about the Andair fuel valves and it raised a question on my part.
First, I didn’t realize there were so many versions of a Andair fuel valves. And you have to know which fittings you want on each port.
What model number and configurations did you use? I’d like to get mine on order and get it put on the shelf.
Also, what’s the difference between the regular Andair valve and the duplex valve? My guess is that the duplex valve has a dedicated return line to send fuel back to the originating tank.
I’d like to return the fuel to the original tank, that sounds great. Except I will be using QB wings with the fuel tanks already assembled and sealed. Does this mean I am not a candidate for a duplex (return to source) valve?
Phil
rv(at)thelefflers.com
PostPosted: Thu Sep 17, 2009 5:12 am    Post subject: Andair Valves Reply with quote
Phil,
You already got several answers on VAF. Do a quick search and you’ll find more of the same here. FS20x7 w/ extender is what is needed for the RV-10. No, you don’t want a duplex. That is for returning fuel to both tanks, which is not required nor recommended on the IO-540. Don at Airflow recommends running the purge line to a tee under the right seat just before the fuel valve. This is used for hot starts. Just set the valve to the left tank and hot fuel goes back to the right tank.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry, Phil
Sent: Thursday, September 17, 2009 8:24 AM
Subject: Andair Valves
Phil
recapen(at)earthlink.net
PostPosted: Thu Sep 17, 2009 5:43 am    Post subject: Andair Valves Reply with quote
Phil,
Your guess about the duplex valve is correct - dedicated return lines to source tank.
I had QB tanks on my 6A and put a fitting in the side forward of the fuel guage sender
all the way in to the second bay. Wasn't a big deal at all.
When I got my duplex valve, I didn't know about the gozillion configurations and would
have ordered it with -4 fittings for the purge lines and plumbed it back to the tank that
way - had I known. I got the one that has all(6) AN6 fittlngs - I don't have the part
number - but like I said, I would have done one set of AN6 and one set of AN4 had I
known.
My FI is from AFP and the line from the servo to the purge valve, spider, and back to
the valve is a -4. It converts to a -6 line right before the valve. Check your FI
system - you might be able to simplify yours like I could have.....
BTW, I oriented my valve such that it points to the left fuel guage when drawing from
the left tank and points to the right fuel guage when drawing from the right tank. It
was a PITB to put together - but real simple in flight.
I attached a photo - during construction - hope it isn't stripped off. More pics if you
want.
Ralph
 Filesize:  181.84 KB
 Viewed:  16917 Time(s)
jdriggs49(at)msn.com
I installed the Andair duplex valve in my -10. I also have the QB wings. Not really a problem vis-a-vis the wings if you install any fittings BEFORE you install the float level valve. After that it's doable but harder.
Date: Thu C 17 Sep 2009 05:23:35 -0700
.ExternalClass p.EC_MsoNormal C .ExternalClass li.EC_MsoNormal C .ExternalClass div.EC_MsoNormal {margin-bottom:.0001pt;font-size:11.0pt;font-family:'Calibri' C'sans-serif';} .ExternalClass a:link C .ExternalClass span.EC_MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited C .ExternalClass span.EC_MsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass span.EC_EmailStyle17 {font-family:'Calibri' C'sans-serif';color:windowtext;} .ExternalClass .EC_MsoChpDefault {;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass div.EC_Section1 {page:Section1;}
First C I didn’t realize there were so many versions of a Andair fuel valves.  And you have to know which fittings you want on each port.
Also C  what’s the difference between the regular Andair valve and the duplex valve?  My guess is that the duplex valve has a dedicated return line to send fuel back to the originating  tank.
I’d like to return the fuel to the original tank C that sounds great.  Except I will be using QB wings with the fuel tanks already assembled and sealed.  Does this mean I am not a candidate for a duplex (return to source) valve?
Phil
ttp://www.matronics.com/Navigator?RV10-List
ronics.com
ww.matronics.com/contribution
Ready for Fall shows? Use Bing to find helpful ratings and reviews on digital tv's. Click here. [quote][b]
Strasnuts
PostPosted: Thu Sep 17, 2009 6:07 am    Post subject: Re: Andair Valves Reply with quote
I would have definitely changed out the original valve that Vans wassending. Now they send a nicer valve that doesn't look like the one in my 1965 motor home. I won't be changing this one out since it has a detent and looks a lot better.
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
Kellym
PostPosted: Thu Sep 17, 2009 6:46 am    Post subject: Andair Valves Reply with quote
Not sure I understand why folks want to do things the hard way.
Precision injection...no return at all.
AFP...return for purge only...minimal flow, just tee into tank line like
Bob Leffler suggested.
You do not actively return fuel to any tank when the engine is running,
unlike Continental engines with TCM injection that return fuel all the
time, so no need to worry which tank your purge returns to.
Date: Thu, 17 Sep 2009 05:23:35 -0700
source) valve?
Phil
ronics.com
<http://www.bing.com/shopping/search?q=digital+tv>
Kelly McMullen
KCHD
dave.saylor.aircrafters(a
PostPosted: Thu Sep 17, 2009 6:47 am    Post subject: Andair Valves Reply with quote
I thought the exact same thing--that the new stock valve was much better than the older style.
It was better.  Mine lasted about 300 hours.  I replaced it with an Andair, and I'm really glad I did.  Night and day.
We work on a lot of planes with a lot of different valves.  The Andairs are bulletproof and worth what they charge.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Thu, Sep 17, 2009 at 7:07 AM, Strasnuts <sean(at)braunandco.com (sean(at)braunandco.com)> wrote:
[quote] --> RV10-List message posted by: "Strasnuts" <sean(at)braunandco.com (sean(at)braunandco.com)>
Cust. #40936
RV-10 SB Fuselage
N801VR reserved
http://forums.matronics.com/viewtopic.php?p=263505#263505
le, List Admin.
bkbrown(at)minetfiber.com
PostPosted: Thu Sep 17, 2009 7:55 am    Post subject: Andair Valves Reply with quote
Kelly McMullen and Bob Leffler (and Don Rivera at Airflow Performance!)
have it right. There is no need to use the Andair duplex valve. None. No
benefit... just extra plumbing, fittings and complexity.
I have the purge setup in my 7A plumbed through an Andair valve with a 1/4"
line plumbed to a tee fitting in the left tank line (between the tank and
the valve). When using the purge valve for a hot start, you put the fuel
selector to the <Right> setting, firewall the throttle and mixture setting,
pull the purge cable to open the purge valve (closing off fuel flow to the
injectors) and engage the boost pump for 30 seconds. During this time, cool
fuel is being pumped from the <Right> tank to the fuel servo, up to the
spider (where the purge valve is located), through a fire sleeved return
line to a steel bulkhead fitting at the firewall, where the 1/4" line runs
back to that tee in the left fuel tank line and back into the left tank. 30
seconds of pumping cool fuel through that 1/4" line will only move about a
cup of fuel, but that is sufficient to accomplish the purpose.
After I count to 30, (with boost pump still engaged) push close the purge
valve for a couple of seconds (your now putting fuel out to the injector
lines) and pull open again. Reset the throttle and mixture to full rich
mixture and 1/8" throttle, engage the starter and begin closing the purge
valve and the engine is now running.
Don't bother with a duplex valve, listen to Don, who builds the system.
Bob Brown
dlm46007(at)cox.net
PostPosted: Thu Sep 17, 2009 9:05 am    Post subject: Andair Valves Reply with quote
When you install the Andair valves , don't forget to segment the tunnel cover for future access.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Danny Riggs
Sent: Thursday, September 17, 2009 6:19 AM
Subject: RE: Andair Valves
(at)page Section1 {size: 8.5in 11.0in; } .ExternalClass P.EC_MsoNormal { FONT-SIZE: 11pt; MARGIN-BOTTOM: 0pt; FONT-FAMILY: 'Calibri','sans-serif' } .ExternalClass LI.EC_MsoNormal { FONT-SIZE: 11pt; MARGIN-BOTTOM: 0pt; FONT-FAMILY: 'Calibri','sans-serif' } .ExternalClass DIV.EC_MsoNormal { FONT-SIZE: 11pt; MARGIN-BOTTOM: 0pt; FONT-FAMILY: 'Calibri','sans-serif' } .ExternalClass A:link { COLOR: blue; TEXT-DECORATION: underline } .ExternalClass SPAN.EC_MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline } .ExternalClass A:visited { COLOR: purple; TEXT-DECORATION: underline } .ExternalClass SPAN.EC_MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline } .ExternalClass SPAN.EC_EmailStyle17 { COLOR: windowtext; FONT-FAMILY: 'Calibri','sans-serif' } .ExternalClass .EC_MsoChpDefault { } .ExternalClass DIV.EC_Section1 { page: Section1 }
Phil
ronics.com
PostPosted: Thu Sep 17, 2009 10:34 am    Post subject: Andair Valves Reply with quote
David,
Please elaborate………
It appears to me with the remote extension, the remote selector comes off easily and isn’t a problem with the tunnel cover.
bob
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
Sent: Thursday, September 17, 2009 1:03 PM
Phil
ttp://www.matronics.com/Navigator?RV10-Listronics.comww.matronics.com/contribution
href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.com
5
6
7
8
9
ronics.com
dlm46007(at)cox.net
PostPosted: Thu Sep 17, 2009 11:53 am    Post subject: Andair Valves Reply with quote
When I received my kit, the tunnel cover was one piece. It is very unhandy for removal. We segmented the one piece into three. firewall to aft of fuel selector, then to back of seats , then to aft of flap motor. we also used CS screws with internal hex head on the center piece to be able remove without removing flap torque tube covers and front seats.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler
Sent: Thursday, September 17, 2009 11:33 AM
David,
Please elaborate………
bob
Subject: RV10-List: Andair Valves
Phil
5
6
7
8
9
ronics.com
ronics.com
1 [quote][b]
Strasnuts
PostPosted: Thu Sep 17, 2009 12:13 pm    Post subject: Re: Andair Valves Reply with quote
Dave, What part of the new Van's fuel valve broke after 300 hours?
780 Hours
SuperSTOL 60 hours
PostPosted: Thu Sep 17, 2009 1:11 pm    Post subject: Andair Valves Reply with quote
I took it apart twice trying to figure out why it didn't feel crisp and smooth.  After the first time, maybe 250 hours (guessing) I put it back together and it didn't feel any different.  From that point it just kept getting tighter and less precise.  I tried one more time.  I never did find anything that looked wrong, but it sure didn't feel as nice as when it was new.
I looked at buying a new one since I could buy many Vans valves for the cost of an Andair.  But I eventually figured the effort would catch up to me, maybe the thing would fail at a bad time, and the tunnel was all apart so I just bit the bullet.
Dave Saylor
AirCrafters LLC
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
On Thu, Sep 17, 2009 at 1:13 PM, Strasnuts <sean(at)braunandco.com (sean(at)braunandco.com)> wrote:
Cust. #40936
RV-10 SB Fuselage
N801VR reserved
http://forums.matronics.com/viewtopic.php?p=263575#263575
le, List Admin.
Strasnuts
PostPosted: Thu Sep 17, 2009 1:35 pm    Post subject: Re: Andair Valves Reply with quote
I don't like the sound of failing at a bad time. Thanks for the quick reply.
780 Hours
SuperSTOL 60 hours
Deems Davis
PostPosted: Thu Sep 17, 2009 5:51 pm    Post subject: Andair Valves Reply with quote
I'll second Davids suggestion. During the final phase you will have
several reasons to reopen the tunnel. Segmenting it can make the process
easier and allow for more direct access. This is PARTICULARLY true if
you plan to install a center console on top of the tunnel, or some
quadrant configurations.
Deems Davis
front seats.
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Bob Leffler
*Sent:* Thursday, September 17, 2009 11:33 AM
*To:* rv10-list(at)matronics.com
*Subject:* RE: Andair Valves
David,
Please elaborate………
bob
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *David McNeill
*Sent:* Thursday, September 17, 2009 1:03 PM
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Danny Riggs
*Sent:* Thursday, September 17, 2009 6:19 AM
doable but harder.
to source) valve?
Phil
*ttp://www.matronics.com/Navigator?RV10-List*
*ronics.com*
*ww.matronics.com/contribution*
*href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List*
*href="http://forums.matronics.com">http://forums.matronics.com*
*href="http://www.matronics.com/contribution">http://www.matronics.com/c*
*http://www.matronics.com/Navigator?RV10-List*
*http://forums.matronics.com*
*http://www.matronics.com/contribution*
Strasnuts
PostPosted: Sat Sep 19, 2009 7:32 am    Post subject: Re: Andair Valves Reply with quote
Dave,
Now that I am ordering my Andair valve which AN fittings work the best with the ten. Do the banjo fittings work well?
780 Hours
SuperSTOL 60 hours
wcurtis(at)nerv10.com
PostPosted: Sat Sep 19, 2009 10:47 am    Post subject: Andair Valves Reply with quote
No need for the very expensiver banjo fittings. Use the 90 degree Elbow fittings (AN-6,JIC-6) on the side and male AN-6 on the bottom outlet with a FS20x 7T valve.
William http://wcurtis.nerv10.com/
On Sat, Sep 19, 2009 at 11:32 AM, Strasnuts <sean(at)braunandco.com (sean(at)braunandco.com)> wrote:
[quote]--> RV10-List message posted by: "Strasnuts" <sean(at)braunandco.com (sean(at)braunandco.com)>
Dave,
Now that I am ordering my Andair valve which an fittings work the best with the ten.  Do the banjo fittings work well?
Cust. #40936
RV-10 SB Fuselage
N801VR reserved
http://forums.matronics.==========
Browse, Chat, FAQ,
="http://www.matronics.com/Navigator?RV10-List" target="_blank">http://====
http://forums.mle, List Admin.
PostPosted: Sat Sep 19, 2009 10:49 am    Post subject: Andair Valves Reply with quote
Other builders might have more to say here.  I didn't use the banjos, just AN hardware in the threaded ports.  I ended up moving my valve forward from the the stock position about 6 inches so none of my mounting details would apply to a standard build.  I moved it so I wouldn't have to take out a bunch of the existing plumbing--I just extended what was there from the stock valve.  Now that it's forward a little, almost directly under the quadrant, I like the placement because it gives a little more room.  But, it doesn't fall quite as easily to hand, which was nice about the stock position.
There's been a lot of discussion on the valve install.  Some are using hoses instead of the long, complex tubes.  I'd consider that too, which would make the fitting selection easier.
Dave Saylor
AirCrafters LLC
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
On Sat, Sep 19, 2009 at 8:32 AM, Strasnuts <sean(at)braunandco.com (sean(at)braunandco.com)> wrote:
Dave,
Cust. #40936
RV-10 SB Fuselage
N801VR reserved
http://forums.matronics.com/viewtopic.php?p=263822#263822
le, List Admin.
Strasnuts
PostPosted: Sat Sep 19, 2009 11:22 am    Post subject: Re: Andair Valves Reply with quote
Thanks again Dave and William
I can get mine on order now.
780 Hours
SuperSTOL 60 hours
