wroe1(at)dbtech.net Guest
Posted: Tue Sep 15, 2009 1:47 pm Post subject: fuel flow transducer location |
Does anyone have a recommendation as to the location of a fuel flow transducer? I’m building an RV-7 and see two potential options for positioning this AFS transducer: - between the boost pump and the firewall, or
- Between the injection servo and the distribution spider.
Any comments would be appreciated. Thanks!
Wade Roe
RV-7 in progress
Aeronca Champ flying
Tuscaloosa, AL
frank.hinde(at)hp.com Guest
Posted: Tue Sep 15, 2009 2:20 pm Post subject: fuel flow transducer location |
Between boost pump and the firewall is the most perfect spot. Try to maintian a straight section of pipe (10 pipe diameter's in front and 5 diameter's behind I believe). If you can't manage that it seems the unit can be calibrated pretty accurately anyway. I have known some builders put the flow pransducer on a 90 degree elbow and it still calibrates just fine.
The cabin is cooler, less vibration (at least compared to the engine itself) and these units almost never go wrong so burying it under the cover is entirely satisfactory.
Frank
7a 400 and something hours
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Wade Roe
Sent: Tuesday, September 15, 2009 2:07 PM
Subject: fuel flow transducer location
Wade Roe
RV-7 in progress
Tuscaloosa, AL
ist">http://www.matronics.com/Navigator?AeroElectric-List
ics.com
.matronics.com/contribution
kahuna
Posted: Tue Sep 15, 2009 2:21 pm Post subject: fuel flow transducer location |
The latter will be more accurate.
The closer to the injectors, the better.
Further away will give you less accurate readings particularly with/without boost pump on.
Seems odd I know. Flow is flow. But the pressure changes affect readings even if the little turbine wheel in the transducer is still spinning at the same speed.
[img]cid:1__=08BBFCA1DFEA76AB8f9e8a93df938(at)us.ibm.com[/img]"Wade Roe" ---09/15/2009 06:09:55 PM---Does anyone have a recommendation as to the location of a fuel flow transducer? I'm building an RV-
[img]cid:2__=08BBFCA1DFEA76AB8f9e8a93df938(at)us.ibm.com[/img]
From:[img]cid:2__=08BBFCA1DFEA76AB8f9e8a93df938(at)us.ibm.com[/img]
"Wade Roe" <wroe1(at)dbtech.net> [img]cid:2__=08BBFCA1DFEA76AB8f9e8a93df938(at)us.ibm.com[/img]
To:[img]cid:2__=08BBFCA1DFEA76AB8f9e8a93df938(at)us.ibm.com[/img]
<aeroelectric-list(at)matronics.com> [img]cid:2__=08BBFCA1DFEA76AB8f9e8a93df938(at)us.ibm.com[/img]
Date:[img]cid:2__=08BBFCA1DFEA76AB8f9e8a93df938(at)us.ibm.com[/img]
09/15/2009 06:09 PM [img]cid:2__=08BBFCA1DFEA76AB8f9e8a93df938(at)us.ibm.com[/img]
Subject:[img]cid:2__=08BBFCA1DFEA76AB8f9e8a93df938(at)us.ibm.com[/img]
AeroElectric-List: fuel flow transducer location [img]cid:2__=08BBFCA1DFEA76AB8f9e8a93df938(at)us.ibm.com[/img]
Sent by:[img]cid:2__=08BBFCA1DFEA76AB8f9e8a93df938(at)us.ibm.com[/img]
Wade Roe
RV-7 in progress
Tuscaloosa, AL
105 Bytes |
6419 Time(s) |
45 Bytes |
6419 Time(s) |
al38kit
Posted: Thu Sep 17, 2009 5:20 am Post subject: Re: fuel flow transducer location |
I have used them in both locations with equal success.
Now I have one mounted on the engine case after the transducer...this is on a Lycoming installation.
On the Continental, it is the only place that you will get an accurate flow, as they use a return line from the servo to the tank.
Another thing that Flowscan recommends beside the lines being straight, is to mount the transducer with the wires pointing up.
I have installed them with a 90 degree fitting on the out side and it has worked fine.
Al
