Info and Question on Van's FWF Kit (including hoses)
nukeflyboy
PostPosted: Thu Sep 10, 2009 8:45 am    Post subject: Info and Question on Van's FWF Kit (including hoses) Reply with quote
I have been reading the posts about engines hoses and wondering about what to get and what to leave out in Van's FWF kit. Another RV-10 builder recently got the kit and I noticed that the hoses looked like teflon coated stainless steel braid. I emailed Van's to find out and this is what they sent me. Included is the current inventory of the kit.
start of Van's note:
1) The Fuel and Oil lines in the RV-10 Firewall Forward kits
are teflon coated with stainless steel braid.
(2) The Vibration mount we sell are made in the USA by
"Vibration Isolation Products".
(3) I have the list of the RV-10 Firewall Forward kit below for
you.
Best Regards
Van's
FF-10 IO-540 F.WALL FWD.KIT IO-540
3.00 CT A-740 BLACK PUSH PULL CABLE BLACK
2.00 DUCT CBT-5/8 COOLING BLAST TUBE
2.00 EA 4" DUCT HOSE CLAMP 4" HOSE CLAMP
1.00 EA CV HOSE 7545 BREATHER HOSE -540
6.00 EA GASKET 77611 BLO-PROOF EXHST GASKT
4.00 EA DYNA VI I(O)-540 VIB.ISO. RV-10 ONLY
1.00 EA OIL COOLER 20006A OIL COOLER I(O)-540
1.00 ES ALTERNATOR DELUXE 60A KIT W/OV PROTECT
1.00 FAB-360/540 FLTRD A/BOX-360 FI320
1.00 FF-1005 BREATHER TUBE
1.00 IE VMP INSTALL KIT FITTINGS/HOSES
1.00 PROP GOV MT P-860-3 I(O)-540 LYCOMING
1.00 VA-102 FUEL PRES. HOSE 15.5
1.00 VA-133 OIL PRESS. HOSE 27.25
1.00 VA-135 OIL COOLER HOSE 16.5
1.00 VA-168 SENDER MOUNT
1.00 VA-186 OIL COOLER BOX ASSY.
1.00 VA-187 4" FLANGED DUCT
1.00 VA-190 OIL COOLER HOSE 27"
1.00 BAF-10-540 BAFFLE KIT IO-540
1.00 PT-035X1/4X4' LO PRES-BRKE RES.TUBE
1.00 SS304-26GAX1/2X9 SCAT CLAMP !!SHARP!!
1.00 VENT SCAT 2X3' RED 2" SCAT 3' LONG
1.00 VENT SCAT 2X6' SCAT TUBE X 6 FT
1.00 VENT SCAT 4X16" 4" DIA. RED SCAT HOSE
1.00 EA DYNA BOLT I(O)-540 MOTOR MOUNT BOLT KIT
1.00 BAG 516 RIVET AN426AD3-3.5
1.00 BAG 517 RIVET AN426AD3-4
1.00 BAG 518 RIVET AN426AD4-4
1.00 BAG 519 RIVET AN426AD4-5
1.00 BAG 520 MISC. AN BOLTS
1.00 BAG 521 MISC. WASHERS
1.00 BAG 522-1 MISC. FITTINGS/CLAMPS
1.00 BAG 523-1 FITTINGS/MISC.
1.00 BAG 524 MISC. CLAMPS
1.00 BAG 525-1 MISC/BEARINGS
1.00 BAG 526-1 CABIN HEAT SHUTTLE HW
1.00 PT-062X1/4X24" HIGH PRESSURE
1.00 CT BLK THROTTLE 47.5 10 (I(O)-540)
1.00 CT BLUE VPROP 72.5 10 (I(O)-540)FWD GOV
1.00 CT RED VMIXTURE 51.5 10 (I(O)-540)
1.00 VA-182-PC KIT THR/MIX BKT IO VERT
1.00 VA-189 FUEL LINE IO-540 25.5
1.00 DOC FF-IO-540 TEXT/DWGS RV-10 F.FWD
1.00 EA EXH 10 I(O)-540 I(O)-540 VETTERMAN
1.00 VA-138 FUEL SUPPLY HOSE 14.0
end of Van's note
First of all it is good to see that they have switched to teflon/SS hoses for the fuel and oil lines.
I am not familiar with the "Vibration Isolation Products" engine mount. Is anyone? It is a division of Pacific Molded Technologies in California. Do you recommend that I stick with Lord Mounts?
So far it looks like I will stick with Van's hoses and just about everything else but will drop a couple items. I have another source for a Plane Power alternator so I will drop it. (They are good alternators and I recommend that you use them.) I bought an AirFlow oil cooler from Alex and will drop it from the kit. I still need to make up my mind on the engine mounts and throttle quadrant.
Any other thoughts?
Dave Moore
RV-6 built and sold
RV-10 built and flying
msausen
PostPosted: Thu Sep 10, 2009 9:20 am    Post subject: Info and Question on Van's FWF Kit (including hoses) Reply with quote
While they may be SS covered Teflon, I'm betting that they are not fire sleeved so take that into account when comparing aftermarkets with Van's.
Michael
jcumins(at)jcis.net
PostPosted: Thu Sep 10, 2009 9:56 am    Post subject: Info and Question on Van's FWF Kit (including hoses) Reply with quote
You need to make sure that the SS hoses have the molded file sleeve as part
of the hose when there made. It cost a bit more but very important in the
fwf area for all hoses that pass fluids thru then. I would also make the MAP
hose SS just to make all hoses the same. This is what I did on our Saratoga
and it was worth the cost.
John G. Cumins
President
JC'S Interactive Systems
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
Kelly McMullen
PostPosted: Thu Sep 10, 2009 1:13 pm    Post subject: Info and Question on Van's FWF Kit (including hoses) Reply with quote
1). You want Teflon CORE hoses, not Teflon coated hoses. If the core is still rubber, like Aeroquip 303 has, they are only good for 5-7 years.
 2)You want Silicone firesleeve hoses, not teflon coated. As others have said, all hoses forward of the firewall that carry fuel or oil should be firesleeved. External firesleeving almost doubles the diameter and doesn't look very good as soon as it ages some. Integral firesleeving is a silicone rubber compound, molded over the stainless braid, which both gives abrasion protection, as well as fire protection.
Yes, they cost about 15% more. It is well worth it, because they will last at least the life of the engine.
Parker 124J is one of the common varieties.
Kelly
On Thu, Sep 10, 2009 at 9:43 AM, nukeflyboy <flymoore(at)charter.net (flymoore(at)charter.net)> wrote:
[quote]--> RV10-List message posted by: "nukeflyboy" <flymoore(at)charter.net (flymoore(at)charter.net)>
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
AirMike
PostPosted: Thu Sep 10, 2009 5:25 pm    Post subject: Info and Question on Van's FWF Kit (including hoses) Reply with quote
I am not sure if it is in the FWF kit, but I have advocated several times that you can spend a lot of time and money on hoses and eyeball fittings.
But the big gorilla in the room (or on the firewall) is the heater valve. I strongly advocate using a SS valve. Just read this piece.
http://www.planeinnovations.com/new%20heater.htm
For about $100 you can trade out the Van's valve for a real fireproof valve of very high quality
See you OSH '18
Q/B - sold.
rv10builder(at)verizon.ne
PostPosted: Thu Sep 10, 2009 6:19 pm    Post subject: Info and Question on Van's FWF Kit (including hoses) Reply with quote
I'll second that. I have a pair and there is no comparison in the quality of
the planeinnovations heater valves and the standard Van's. The valves are in
the fusellage kit- remove them from that order and use the money on SS, it
is worth whatever difference in price there may be.
Pascal
Sent: Thursday, September 10, 2009 6:25 PM
Subject: Re: Info and Question on Van's FWF Kit (including hoses)
OSH '10 or Bust
Q/B Kit - phase 1
http://forums.matronics.com/viewtopic.php?p 62508#262508
dlm46007(at)cox.net
Another option is a fire bottle , dumping Halon for and aft of the baffling
at pilot activation.
SEE http://www.stroudsafety.com/HalonSystems.html
 Filesize:  41.01 KB
 Viewed:  13723 Time(s)
johngoodman
PostPosted: Thu Sep 10, 2009 6:28 pm    Post subject: Re: Info and Question on Van's FWF Kit (including hoses) Reply with quote
Am I missing something? Just cut off the fuel. The fire should go out without fuel.
tsts4
PostPosted: Fri Sep 11, 2009 5:01 am    Post subject: Re: Info and Question on Van's FWF Kit (including hoses) Reply with quote
Just to play devil's advocate, what if you can't shut the fuel off--you're knocked out or something. Hypothetically, having maximum protection FWF might buy you or some bystander time to extract you from the cabin before getting cooked.
Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying
dlm46007(at)cox.net
PostPosted: Fri Sep 11, 2009 7:20 am    Post subject: Info and Question on Van's FWF Kit (including hoses) Reply with quote
If the fuel cannot be shutoff then the fire is already in the tunnel. An
Andair fuel selector turned off should stop feeding the flames and a fire
bottle ought to cool everything ; without oxygen the fire should be
suppressed. Race cars are required to have fire suppression systems and are
more susceptible to fires than our aircraft. In addition Part 21 aircraft
are required to have fire detection and fire suppression systems. Check the
Boeings. My A&P course had an extensive class on fire detection/fire
suppression systems for Part 21 aircraft. My Glastar has a temperature
sensor in the Carburetor box and inlet spray and a spray nozzle over the
cylinders. The 10 has a sprayer on top of the cylinders and another between
the firewall and the rear baffling.
gengrumpy(at)aol.com
PostPosted: Fri Sep 11, 2009 8:50 am    Post subject: Info and Question on Van's FWF Kit (including hoses) Reply with quote
Another alternative is a small, spring loaded door in the top of the
tunnel just forward of the fuel valve.
Poke the nozzle of on-board extinguisher through the opening and let
'er rip.
$64 question is whether or not to use halon or the standard gasoline
ABC extinguisher.
Halon will kill you dead as a door nail if you breathe it.
grumpy
tunnel. An
fire
and are
aircraft
Check the
the
between
dlm46007(at)cox.net
PostPosted: Fri Sep 11, 2009 9:43 am    Post subject: Info and Question on Van's FWF Kit (including hoses) Reply with quote
Mine is Halon but the gas goes forward of the firewall. You definetly do not
want to discharge Halon in the cabin without a lot of air flow in and out.
PostPosted: Fri Sep 11, 2009 11:35 am    Post subject: Info and Question on Van's FWF Kit (including hoses) Reply with quote
Aviation consumer news did a report on this. Basically Halon is your best
option. ABC extinguisher will ultimately cause more damage than Halon.
They note about inhaling Halon- "The FAA notes- The toxic effects of a
typical aircraft seat fire, for example, far outweigh the potential toxic
effects of discharging a Halon fire extinquisher". I take away two things
from this- don't allow smoking in the plane, and if the seat is on fire to
care what Halon will do.. all joking aside.. the point really is that one
wants to keep the fire out of the cabin, smoke alone will do far more than
anything the Halon could do.. one can spray a little on a smaller fire and
use vents to get air, but with smoke from a fire there is no only inhaling a
little bit. This goes back to my seconding that having Stainless steel for
a vent is a great option. If the fire goes through the weakest link, SS vent
or RTV than the smoke will hit you probably before any fire, but if you have
a cheap aluminum vent the fire may very well start coming in and burning
everything on the cabin side than cause lots of smoke- "everything" since
the vents go forward and back in the cabin.
There really isn't any great option when one has a fire, but it sure helps
to keep any openings sealed as best as possible. There is the discussion
about "must have" firesleeves on the hoses that runs another $200 plus above
the stock Van's hoses, if one is going to go to that extent, spend the $100
and do your best to keep the fire out a few seconds more.. it really could
be the difference between you talking about it or everyone else talking
about it in your memory..
So what did ACS say about the Halon? since that was the question- basically
ABC (dry-chemical) have too much to be desired among the issues-
vision-limiting and respiratory effects.
They conclude with "on a really bad day you have one, however, you'll want
to reach for a Halon extinquisher while aiming for the nearest runway."
Referenced December 2008 edition.
Pascal
Sent: Friday, September 11, 2009 9:47 AM
Subject: Re: Re: Info and Question on Van's FWF Kit (including
hoses)
Poke the nozzle of on-board extinguisher through the opening and let 'er
rip.
$64 question is whether or not to use halon or the standard gasoline ABC
extinguisher.
grumpy
> fire
> are
> aircraft
> the
> between
dlm46007(at)cox.net
PostPosted: Fri Sep 11, 2009 11:57 am    Post subject: Info and Question on Van's FWF Kit (including hoses) Reply with quote
I also carry a couple of disposable smoke hoods in addition the fire bottle;
I don't know whether I would be able to deploy them in time. My plan was to
be so prepared that the occasion to use would not arise.
jcumins(at)jcis.net
PostPosted: Fri Sep 11, 2009 12:28 pm    Post subject: Info and Question on Van's FWF Kit (including hoses) Reply with quote
With over 5k hours and 13 years flying on the USAF largest cargo plane as a
flight engineer. I am very familure and trained on the Halon fire
extinguisher systems. The C-5 had 24 fire bottles of halon in the cargo
compartment. 2 very large 150 lb portable extinguishers in the cargo
compartment and 14 5 lb portable bottles throughout the plane also. Halon
is one of the best fire fighting products available and is totally
survivable by the person fighting the fire. It will not kill you unless you
directly inhale it straight from the extinguisher. I have had a in-flight
fire none night about 3am over the gulf next to Patia Beach Thailand. A
light assembly in the flight engineer panel electrical connector started to
melt the caught fire. So we blasted it with both the large extinguishers
from the cargo compartment. Not knowing what was burning, we thought to
error on the large side and use both extinguishers and the large ones. We
lowered the flight engineer insterment panel down and blasted. Once the
smoke cleared we felt a bit surprised to see it was a very small fire, but
it put out a tone of very black smoke. The cooling fan for the Engineer
panel exits into the cargo compartment and it filled it with black smoke in
minutes. Boy was that a fun night. We dumped 200,000 lbs of jet fuel in
the bay and landed back at Utapow AB replaced the light assembly, refueled
and departed for Saudi.
If I was to install a extinguishing system in my -10 it would be a Halon
system, no questions asked.
Just my 2 cents work and a war story.
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
PostPosted: Thu Sep 17, 2009 11:20 am    Post subject: Info and Question on Van's FWF Kit (including hoses) Reply with quote
I've seen mention of the MAP hose (VA-119) yet that is not part of the Van's
list for the FWF kit.
Have people been adding that to their lists?
Thx
Pascal
Sent: Thursday, September 10, 2009 10:48 AM
Subject: RE: Info and Question on Van's FWF Kit (including hoses)
part
MAP
Saratoga
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
