aerosport1
Posted: Wed Aug 19, 2009 7:59 pm Post subject: Door locks |
I have seen some door locks with the stock door handles that are about 2 inches in front of the outside door handle. Can anyone post some pictures
on how these were done with the stock door hardware on the inside of the door.
Thanks Geoff
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
msausen
Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
David Shelton
Posted: Tue Sep 08, 2009 10:08 am Post subject: Re: Door locks |
Geoff,
I just sold my RV-10 so I can't take a picture. In the locked position, the locking arm swung downwards in front of the lower gear rack. In theory... this would provide a stop and prevent the lower gear rack from moving forwards.
In practice, it only took a little force on the door handle to strip the lock and open the door. My neighbor accidentally stripped his lock also... it was mostly decorative.
This type of lock should probably be mounted at the bottom of the door and the arm should swing through a slot to engage the door frame. This would subject the lock to shear loading, rather than rotation. -David
rebrunk42(at)gmail.com Guest
Posted: Tue Sep 08, 2009 2:52 pm Post subject: Door locks |
I agree too bad vans can't furnish a decent lock for such an expensive
kit. My lock does not work it probably got stripped too
Robert E. Brunkenhoefer
Brunkenhoefer Law Firm, P.C.
520 Lawrence St.
Corpus Christi, Texas 78401
Phone: 361-888-8808
Facsimile: 361-888-6753
robert(at)brunklaw.com
On Sep 8, 2009, at 1:08 PM, "David Shelton" <SBaircraft(at)yahoo.com>
wrote:
Geoff,
rotation. -David
http://forums.matronics.com/viewtopic.php?p 62089#262089
dlm46007(at)cox.net Guest
Posted: Tue Sep 08, 2009 3:24 pm Post subject: Door locks |
All locks are installed to make the thief go to check the next item of
interest. I would rather the thief had an easy entry and did not damage the
airframe while trying to get the avionics, etc. If you are concerned about
the airframe I suggest lojack and possibly an audible alarm. Or perhaps
airframe damage is preferred so that the thief will be reluctant to fly away
the aircraft
Posted: Tue Sep 08, 2009 3:43 pm Post subject: Door locks |
All locks are designed to convince the thief to try another asset. If the
lock is too robust, the airframe may be damaged by a thief gaining entry. I
would prefer that the thief took whatever component or content and did not
damage the airframe. Most individual items are replaceable by insurance off
the shelf, redoing the doors or window would not be a fun task but would be
required if the airframe is damaged. On the other hand if your concern is
the airframe then perhaps airframe damage is preferable since the thief
would be unlikely to fly it away if damaged on entry. If the aircraft is of
concern, perhaps LoJack and an audible alarm would also work.
Posted: Tue Sep 08, 2009 4:13 pm Post subject: Door locks |
The lock does not lock at all , so itdoes not even suit the purpose
for your senario
520 Lawrence St.
Phone: 361-888-8808
damage the
about
perhaps
fly away
the aircraft
for $4.86 one can get a simple lock from Lowes or HD and build a relatively
solid locking system (William Curtis has a picture on his site). No
different than the baggage door. I built mine so the handle can not be moved
at all, there is a .063 plate between the door and the lock pop riveted on,
sure with some serious pulling the lock might eventually give but it would
take some work and a ruined door, most thieves give it a quick pull, see it
doesn't bulge and move on to the next possible victim.
Pascal
From: "Robert Brunkenhoefer" <rebrunk42(at)gmail.com>
Sent: Tuesday, September 08, 2009 3:45 PM
Subject: Re: Re: Door locks
520 Lawrence St.
Phone: 361-888-8808
On Sep 8, 2009, at 1:08 PM, "David Shelton" <SBaircraft(at)yahoo.com> wrote:
> Geoff,
> moving forwards.
60.06 KB |
16921 Time(s) |
Posted: Tue Sep 08, 2009 4:45 pm Post subject: Door locks |
I criticized how blue mountain treated it's customers about the
product they sold me. Each time, a beta tester for blue mountain
would go on line and respond in a way to imply it would work fine if I
knew what I was doing . Not a good business model. We all know what
happened to them. If you supply a product it should work under normal
circumstances. There should be no need to rationalize that it's
failure is somehow a good design idea . Let's work on the premise the
a working lock is ok to expect . It needs no rationale.
520 Lawrence St.
Phone: 361-888-8808
damage the
about
perhaps
fly away
the aircraft
Posted: Tue Sep 08, 2009 4:53 pm Post subject: door locks |
Aother possibility is a sign in the window. "Theft or damage to this aircraft is a federal crime punishable by 5 years and $250,000 fine etc........................................". this is the way they post at my airport. Of course in this environment it might make the aircraft more of a target...
Posted: Tue Sep 08, 2009 5:29 pm Post subject: Door locks |
Can you share the details with the group?
520 Lawrence St.
Phone: 361-888-8808
On Sep 8, 2009, at 7:11 PM, "Pascal" <rv10builder(at)verizon.net> wrote:
| Quote: | for $4.86 one can get a simple lock from Lowes or HD and build a
relatively solid locking system (William Curtis has a picture on his
site). No different than the baggage door. I built mine so the
handle can not be moved at all, there is a .063 plate between the
door and the lock pop riveted on, sure with some serious pulling the
lock might eventually give but it would take some work and a ruined
door, most thieves give it a quick pull, see it doesn't bulge and
Pascal
> expensive kit. My lock does not work it probably got stripped too
> Sent from my iPhone
> 520 Lawrence St.
> Phone: 361-888-8808
> wrote:
>> Geoff,
>> rotation. -David
<sect 45- door lock (Medium).JPG>
Posted: Tue Sep 08, 2009 7:14 pm Post subject: Door locks |
IIRC locks were not supplied or specified in the kit. It is roll your own
time. I concur with the Blue mountain mess though. I am not justifying Vans
simply stating that Vans omits that part of the kit.
Posted: Tue Sep 08, 2009 8:04 pm Post subject: Door locks |
This will give a few builders ideas about where a lock can be placed. This is a piece of hardwood. I intend to place a lock similar to the one that locks the baggage door. It will ingage the front inside part of the cabin top. I placed it in the front edge of the door for two reason: to manually close the latch while flying so that if the door were to pop open(it won't afer I improved my pins and achore points) it would prevent the air from grabbing the door. Two C easy to see for both the pilot C co pilot while in the air and the thief while on the ground.
Note the extra carbon cloth and the Kevlar backing which I used on both sides of the door. The foam in the second picture is to make the door more rigid in that area.
[quote] From: rebrunk42(at)gmail.com
Date: Tue C 8 Sep 2009 20:28:23 -0500
99.99 KB |
16914 Time(s) |
108.41 KB |
16914 Time(s) |
AirMike
Posted: Wed Sep 09, 2009 3:56 am Post subject: Door locks |
I put in the cheap - flimsy Van's lock. You only need it on one door - use a wedge or other restraint on the Passenger side door. The alarm is probably just as good of an idea. A decal indicating alarm protection might be as good as a lock. The lock is to send the thief to the plane parked next to yours. It is really a visual to keep the thief from climbing up on the wing and damaging your flap.
Alway keep in mind the Van's philosophy of light and INEXPENSIVE..
Remember that you own a light and fast RV10 not a spam can that is essentially a pig with lipstick.
_________________ See you OSH '18
Q/B - sold. |
gengrumpy(at)aol.com Guest
Posted: Wed Sep 09, 2009 4:44 am Post subject: Door locks |
I used a simple trailer lock on both doors. Locking arm swings down
into a cutout in the top of the lower door frame.
Similar to the baggage door key, but I changed that one out and put a
combo lock on it so I don't have to mess with a key every time I want
to get into the baggage compartment.
Grumpy
N184JM
On Sep 8, 2009, at 10:08 PM, David McNeill wrote:
your own
justifying Vans
rene(at)felker.com Guest
Posted: Wed Sep 09, 2009 5:43 am Post subject: Door locks |
That combo lock sounds like a great idea. Is it a drop in replacement?
Where can I get one....
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Posted: Wed Sep 09, 2009 6:26 am Post subject: Door locks |
Get at any hardware store.
I mounted it about center bottom of each door. Mount low enough so
that the arm can go down into the lower frame.
Handle is free to move as normal, but door won't open with the latch
of the door into the frame.
grumpy
N184JM
Rene' Felker
RV-10 N423CF Flying
801-721-6080
bob.kaufmann(at)cox.net Guest
Posted: Wed Sep 09, 2009 7:17 am Post subject: Door locks |
Show us a photo
Bob K
partner14
Posted: Wed Sep 09, 2009 7:17 am Post subject: door locks |
Is it more of a target because if they get caught, not likely, they would then get 5 years of free room and board.... and get to visit all their buddies?>?>?>?
We use a simple lock on the pilot door, and a strap which holds the copilot latch from being moved. Don
--- On Tue, 9/8/09, David McNeill <dlm46007(at)cox.net> wrote:
Subject: door locks
Date: Tuesday, September 8, 2009, 5:47 PM
Aother possibility is a sign in the window. "Theft or damage to this aircraft is a federal crime punishable by 5 years and $250,000 fine etc.......................................". this is the way they post at my airport. Of course in this environment it might make the aircraft more of a target...
=nofollow target=_blank>http://www.matronics.com/Navigator?RV10-List
et=_blank>http://forums.matronics.com
llow target=_blank>http://www.matronics.com/contribution
40636 |
Posted: Wed Sep 09, 2009 7:25 am Post subject: Door locks |
Hi Bob! I was corresponding with rick ..... Louise and I'll be in LAS
at 6 PM tomorrow, staying through Wed. I was hoping to get some air
time in Ricks but he's down for the moment. I wanna get a look at your
project too, if you have time.
Linn
