Vortex Generators
Goto page 1, 2, 3  Next
rwaltman
PostPosted: Tue Sep 08, 2009 7:55 am    Post subject: Vortex Generators Reply with quote
The post "Summary of Kolb database" says 35% of the poll participants use
vortex generators in their machines.
Can somebody provide figures on the their aircraft weight and stall speed
before and after installing the VGs?
I am asking because I am interested in a project, (not a Kolb, sorry,)
that could be flown as a legal Part-103 ultralight if I can bring down the
stall speed.
Roberto Waltman
Roberto Waltman
Richard Pike
PostPosted: Tue Sep 08, 2009 1:42 pm    Post subject: Re: Vortex Generators Reply with quote
rwaltman wrote:
The post "Summary of Kolb database" says 35% of the poll participants use vortex generators in their machines.
stall speed.
Roberto Waltman
Here is my experience -
http://www.bcchapel.org/pages/0003/Vortex%20Generators.html
http://www.bcchapel.org/pages/0003/FSII%20Vortex%20Generators.html
Recently looked at Beauford's Firefly and his VG setup, consequently will be going to the little plastic triangular store bought VG's when we rebuild the FSII as he has found them to work better than the homemade ones.
Hope this helps -
Richard Pike
MKIII N420P (420ldPoops)
beauford
PostPosted: Tue Sep 08, 2009 2:45 pm    Post subject: Re: Vortex Generators Reply with quote
Brother Waltman:
Despite Brother Pike's reference to improvements from the VG's, still getting mixed results and experimenting with the placement. Not totally satisfied that these things work that well. Am currently back 11.5 inches from the leading edge, (see photo) but thinking of reducing this to about 10 inches. Have some more testing planned with yarn tufts to see where the boundry layer is breaking away...
You mentioned that your machine wasn't a Kolb... What kind of airfoil are you working with...?
beauford
FF-076
 Filesize:  584.02 KB
 Viewed:  15264 Time(s)
slyck(at)frontiernet.net
PostPosted: Tue Sep 08, 2009 4:44 pm    Post subject: Vortex Generators Reply with quote
bad boy.
On 8, Sep 2009, at 6:45 PM, beauford wrote:
Brother Waltman:
breaking away...
beauford
FF-076
http://forums.matronics.com/viewtopic.php?p 62133#262133
http://forums.matronics.com//files/vginstalljpg_554.jpg
lcottrell
PostPosted: Tue Sep 08, 2009 4:47 pm    Post subject: Vortex Generators Reply with quote
Beauford,
I put my first 7 VG's on the ribs at 11 inches, and got a 5 or so MPH reduction in stall. I decided to put 7 more of them evenly in between the ribs at 10 inches and obtained an equal amount of stall reduction, which lead me to believe that 10 inches would be the better place to install them. I think if you figure the percentage that is recommended of 10 percent comes out closer to 10 than 11 inches.
Like you say- " worth what you paid for it"
Larry C
lcottrell
PostPosted: Tue Sep 08, 2009 6:18 pm    Post subject: Vortex Generators Reply with quote
OOOOOOOOOOOPS! snookered again.
Larry C
beauford
PostPosted: Tue Sep 08, 2009 6:24 pm    Post subject: Vortex Generators Reply with quote
Yes... I know... guilty as charged, Brother Bean... bad boy...
The photo is an old gag... although I'll bet someone has tried them down there...
Brother Waltman:
The Landshorter clear lexan VG's Brother Pike referred to seeing when he was
visiting are right up on top of the wing at 10% of chord exactly where the LS
people said to put them. Substantial performance improvement over the homemade
aluminum jobs, which were at 11.5 inches. I don't have the exact measurement at
hand, but the Landshorters are roughly 2.5 inches forward of where the old
aluminum ones were.
The Fly actually feels a tad floaty with the Landshorters... vice the previous
imitation of a lawn dart it wanted to execute when the power was chopped before.
The aluminum VG's helped some, and were definitely better than nothing, but the LS
installation really changed the game. It now gives a pretty fair power-off glide
at 46 or so indicated ... before, at anything below 50 it seemed as if you would
be looking almost between your feet at where the impact crater was likely to be.
No real change in the stall personality...still a mild non-event at normal
acceleration... just a few mph slower than before. There is a real improvement in
the landing flare in ground effect... again, more bouyant. I like 'em. To me,
anything which can extend the dead-stick glide and slow the terminal arrival speed
of an airplane powered by a single-ignition, 2-stroke Nazi engine is a worthwhile
insurance item.
'Ol bad beauford is going to now punish himself for posting the gag picture by
going to bed without any (more) supper.... although he may get himself just a
taste of cheap brandy and a Cusano 18 stogie and sit out back a while before
bed...no sense in going Draconian over this... He'll be meditating about paper
VG's...
..worth what ye paid fer it, Brother Waltman...
beauford
FF-076
Brandon, FL
aslsa.rng(at)gmail.com
PostPosted: Tue Sep 08, 2009 6:52 pm    Post subject: Vortex Generators Reply with quote
Okay, Beauford, that was just rude. Smile On a more serious note, has anyone read the Wind Tunnel column in the new issue of Kitplanes?
Rick Girard
On Tue, Sep 8, 2009 at 9:27 PM, Beauford T <beauford173(at)verizon.net (beauford173(at)verizon.net)> wrote:
[quote]--> Kolb-List message posted by: "Beauford T" <beauford173(at)verizon.net (beauford173(at)verizon.net)>
Brother Waltman:
aluminum ones were.
insurance item.
VG's...
beauford
FF-076
Brandon, FL
apilot(at)surewest.net
PostPosted: Tue Sep 08, 2009 7:45 pm    Post subject: Vortex Generators Reply with quote
My VG's are at about 11 inches back on my Mk III Classic. This location is based on the highest tangent line when the wing is at cruise attitude (about 7 degree). They work good, but I believe that they would produce a slower stall if they were on the top tangent of the airfoil when the angle of attack is at stall speed. Also, it is my opinion that I should have put them in the valleys between the ribs and not on the ribs. At any rate, I like them and it has saved my stock landing gear legs several times. Now that I have achieved a smooth tail wheel first landing, I plan to do most of my landings on the main gear. I cannot remember an airplane than I enjoyed flying more than my old Classic. It is for sale, but not because I don't like it. Vic N4201G
Thom Riddle
PostPosted: Wed Sep 09, 2009 4:53 am    Post subject: Re: Vortex Generators Reply with quote
The least expensive source I've found for plastic manufactured VGs is at the following link.
http://flyfbi.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=FS&Product_Code=AIRWAVE-100&Category_Code=ACS
or
http://tinyurl.com/mp76ay
I have some home made aluminum ones that I was going to put on my SS but since Beauford said the Landshorter ones work better than the aluminum ones did on his Kolb, I'm considering ordering a set of these.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
PostPosted: Wed Sep 09, 2009 6:47 am    Post subject: Vortex Generators Reply with quote
Thom Riddle
Hi Gang:
I was looking at the VG ad from Thom R. Kit includes 100 each VGs. Without
going to Land Shorter web site, I believe they also send 100 VGs in their
kit.
From the above info, am I to assume all airplanes use the same number of
VGs? i.e., Fire Fly with 22 foot wingspan uses same number as MKIII with 30
feet?
MKIII
West Yellowstone, MT
rwaltman
PostPosted: Wed Sep 09, 2009 9:04 am    Post subject: Vortex Generators Reply with quote
Thanks for all the responses.
The project in question was a Colomban CriCri, now in eBay:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=300343336101&viewitem=&sspagename=STRK%3AMEWAX%3AIT
I played for a while with the idea of buying it, and build a pair of
slightly longer wings to shoehorn it into Part-103 limits.
(Stock stall speed is too high for VGs alone to bring it down to '103
specks - would be non-aerobatic, of course.)
Between the longer wings + VGs + new propellers to limit max speed, it
could have been a wonderful '103 plane.
Fortunately, I suffered an attack of temporary sanity and begun to think
about the side effects of such change. Longer wings will develop more
lift, but what about elasticity problems? Do I want to do flutter testing
with the new wings? (Answer: No)
The tail surfaces may not have enough control authority at lower speeds
making landings tricky.
Also, flying at lower speeds and higher angle of attack will make the
T-tail sink into the turbulence created by the fuselage and canopy. Again,
potential control problems at low speeds.
Finaly, I could fit in that plane, but me and my wife together would not.
So I am back looking for a two-seat LSA, may be a Kolb.
Sorry for the detour from the regular programming and again, thanks for
the very useful information shared here.
Roberto Waltman
Roberto Waltman
beauford
PostPosted: Wed Sep 09, 2009 1:22 pm    Post subject: Vortex Generators Reply with quote
>feet?
..Well...I reckon you COULD get all 100 of 'em on the Fly, John... but it might
look kinda like a cheese grater from the front.... and would likely sound like a
harmonica band going by...
Actually, the Landshorter package provides an assortment of templates to make sure
that the installer sets them on the wings of a given airplane at an efficient
interval and exactly the right angle of attack...they make a big deal of getting
the angle of attack of the VG precisely correct, and the templates will do that if
one pays attention to them. I had about 28 of the original 100 left over on the
Fly as I recollect. When I ordered them the lady at Landshorter mentioned that
while most folks just keep the extras as spares in the event some fall off, she
said that some customers who have shorter wingspan machines use the leftovers at
other places such as the tail feathers... I decided to leave the old aluminum
items currently on the bottom of the horizontal stab and both sides of the
vertical stab on the Fly where they are... mainly because they are danged hard to
get off, even after soaking. I tried. I'll keep about 8 of the Lexan extras in
case I eventually lose a few off the wings... will likely replace the five large
yellow ones on the helmet with the remaining 20...
Speaking of losing them... I have yet to have a single one of the Lexan units fall
off... Landshorter recommends a certain Loctite #401 industrial-strength
cyanoacrylic clear cement, basically a souped-up crazy glue, to put them on
with... they sell the stuff and I ordered a tube with my VG's. One thing,
though -- one had best know EXACTLY where, and at what angle, one wants that
doober BEFORE it touches to the fabric...or your thumb.... your stogie... the
cat.... your left nostril..... whatever. The word "adjustment" is clearly not in
the Loctite #401 vocabulary....even one nanosecond after first contact. Kinda
reminded me of our honeymoon....
So far -- So good, with these things... as already mentioned, a remarkable
positive difference from the VG setup I previously had...
..worth what ye paid fer it...
beauford
FF-076
Brandon, FL
PostPosted: Wed Sep 09, 2009 1:55 pm    Post subject: Vortex Generators Reply with quote
Fly as I recollect.
beauford
Beauford/Gang:
Still don't know if I would have enough left over for my helmet after
fitting out the MKIII wing. ;-(
West Yellowstone, MT - 24F this morning when I got up, but T-shirt weather
under a dark blue cloudless sky this afternoon. Just got up from my nap and
headed out to find me some senior citizen grub. Wink
mdnanwelch7(at)hotmail.co
PostPosted: Wed Sep 09, 2009 2:16 pm    Post subject: Vortex Generators Reply with quote
John C
  You have the priority backwards.  FIRST C the helmet C then the wings.  : )
Mike Welch
MkIIICX
[quote] From: jhauck(at)elmore.rr.com
Subject: Re: Re: Vortex Generators
Date: Wed C 9 Sep 2009 15:30:57 -0600
--> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com>
> Fly as I recollect.
> beauford
Beauford/Gang:
West Yellowstone C MT - 24F this morning when I got up C but T-shirt weather
headed out to =====================
_=====
With Windows Live C you can organize C edit C and share your photos. Click here.
JetPilot
PostPosted: Fri Sep 11, 2009 1:39 pm    Post subject: Re: Vortex Generators Reply with quote
Hope this helps -
Richard Pike
I have been posting the above information about VG's here on the list for the last 3 years, telling people that they were critical in design and placement, and to just spend the 100 dollars on ones that are designed properly and will perform best, you just now figured this out ???
Kolb MK-III Xtra, 912-S
zeprep251(at)aol.com
PostPosted: Fri Sep 11, 2009 2:08 pm    Post subject: Vortex Generators Reply with quote
Richard,
That didn't take very long, did it?
G.Aman
jlsk1(at)frontiernet.net
PostPosted: Fri Sep 11, 2009 4:24 pm    Post subject: Vortex Generators Reply with quote
I like my MK-3 the way it is.(Keeping this Kolb related) (Smiles)
Leopards don`t change spots.
Jim Kmet MK-3C
PostPosted: Fri Sep 11, 2009 4:53 pm    Post subject: Vortex Generators Reply with quote
Well, not to be a contrarian, but I'm going to Agent Orange for some plastic angle tomorrow and make them per the latest Wind Tunnel column in Kitplanes. Cheap thrills. Okay, every body have your finger poised on the Delete key. Smile
Rick Girard
On Fri, Sep 11, 2009 at 7:18 PM, Jim Kmet <jlsk1(at)frontiernet.net (jlsk1(at)frontiernet.net)> wrote:
[quote] I like my MK-3 the way it is.(Keeping this Kolb related) (Smiles)
Jim Kmet MK-3C
PostPosted: Fri Sep 11, 2009 5:35 pm    Post subject: Vortex Generators Reply with quote
Rick, Tender subject I know,but I have the Landshorter VGs on my MK-3,but never had them on the Firestar,and granted they are two different airplanes,BUT,solo the MK stalls in the 20's and the FS2 at 36 and the break is gentle in the MK when it quits.BUT they were on it when I got it.The guy I bought it from had a 2" thick file on VG's and had really investigated before he bought and installed them.I'm interested to see your results -before and after.
G.Aman
Page 1 of 3
