Weight limit - Kolb Twinstar MKII
dutrac
PostPosted: Mon Sep 07, 2009 6:10 pm    Post subject: Weight limit - Kolb Twinstar MKII Reply with quote
Hi Folks,
I just purchased a Kolb MKII. I've read through the manuals and searched the internet (including this list) for one seemingly simple spec on the aircraft. Can someone tell me? What is the max gross weight?
Duane
gliderx5
PostPosted: Mon Sep 07, 2009 7:11 pm    Post subject: Weight limit - Kolb Twinstar MKII Reply with quote
Duane
I'm not sure what my MKII has for a listed max gross, but it flys nicely with 410 lbs of people and 30lbs of fuel. With the airplane weight at 390 lbs that is a total of 830 lbs.
Malcolm
cristalclear13
PostPosted: Tue Sep 08, 2009 6:43 am    Post subject: Re: Weight limit - Kolb Twinstar MKII Reply with quote
dutrac wrote:
Hi Folks,
Duane
Duane,
When I first purchased my Mark II I believe I got the attached document from Dennis at Kolb.
Congratulations on your new plane. You'll love it.
Mark II Specs.tif
 Filesize:  42.77 KB
 Viewed:  9176 Time(s)
Mark II Specs.tif
Cristal Waters
Private Pilot Aug 2008
Rotax 2 stroke maintenance April 2009
cristalclear13
PostPosted: Tue Sep 08, 2009 6:47 am    Post subject: Re: Weight limit - Kolb Twinstar MKII Reply with quote
Looks like the .tif file didn't work. Here is the same file as .jpg.
 Filesize:  434.67 KB
 Viewed:  9171 Time(s)
Cristal Waters
aslsa.rng(at)gmail.com
PostPosted: Tue Sep 08, 2009 7:43 am    Post subject: Weight limit - Kolb Twinstar MKII Reply with quote
Cristal, The tiff file came through fine here. I did the same and cropped it a bit.
Rick Girard
On Tue, Sep 8, 2009 at 9:47 AM, cristalclear13 <cristalclearwaters(at)gmail.com (cristalclearwaters(at)gmail.com)> wrote:
--> Kolb-List message posted by: "cristalclear13" <cristalclearwaters(at)gmail.com (cristalclearwaters(at)gmail.com)>
Cristal Waters
Kolb Mark II Twinstar
Rotax 503 DCSI
http://forums.matronics.com/viewtopic.php?p=262055#262055
http://forums.matronics.com//files/mark_ii_specs_134.jpg
le, List Admin.
 Filesize:  154.82 KB
 Viewed:  9169 Time(s)
