nose rib fabrication ch 701/ch 750
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith750-List
joemotis(at)gmail.com
PostPosted: Fri Aug 28, 2009 7:17 pm    Post subject: nose rib fabrication ch 701/ch 750 Reply with quote
Hi all,
I have been having a lot of trouble fabricating the nose ribs. I am using the spruce vise grip fluting tool and am wondering if the 3/8 rod one in the plans is the way to go. Any hints or advice appreciated
Joe Motis  CH 750 plans and avid Pietenpol assistant
- The Matronics Zenith750-List Email Forum -
http://www.matronics.com/Navigator?Zenith750-List
klondike(at)megalink.net
PostPosted: Sat Aug 29, 2009 4:38 am    Post subject: nose rib fabrication ch 701/ch 750 Reply with quote
Joe, the problem probable isn't the tool, but rather the sequence and procedure you are using to make the mends both while in the forming block and afterwards with the hand tool.----- what part of the world are you located in?---Fritz --- do not archive
d.shrader
PostPosted: Fri Sep 04, 2009 11:40 pm    Post subject: Re: nose rib fabrication ch 701/ch 750 Reply with quote
Joe,
what seems to be the problem, is it at the front of the nose rib or else where it the metal trying to pucker or is it just bowed i have dealt with these problems and others if you could elaborate maybe i could lend some help
Dave
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith750-List All times are GMT - 8 Hours
