flying(at)jeffhove.com Guest
Posted: Tue Sep 01, 2009 1:21 pm Post subject: Flat main tire on takeoff or landing |
Has anyone with a 7A (or other RV) experienced a flat main tire during
takeoff or landing? Were you able to keep it on the runway? Did the
wheel-pant survive?
I had a left main inner-tube fail during the taxi to the runway last
week and even at a slow taxi it was hard to keep it straight as the tire
deflated. Had the tube let go a minute later I'd have been on the
take-off roll. The tire was fine and the tube was only 2 years old and
looked ok except for a quarter-sized area where the rubber had become
cracked and leaky. Apparently a manufacturing defect as there were no
rough spots or FOD in the tire to cause this.
The way the tire bunched up inside the wheel-pant made me wonder if the
wheel would continue turning and if even full opposite rudder and brake
would be enough to keep the plane rolling straight had this happened at
a higher speed.
Jeff Hove
Flying my father's RV-A, N347RV.
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
lrhelming(at)gmail.com Guest
Posted: Wed Sep 02, 2009 4:10 am Post subject: Flat main tire on takeoff or landing |
No I haven't and I don't know of anyone. Sounds like you were lucky not to have lost control. I suggest you check tire pressure during each flight's preflight inspection. I know my tires lose pressure with time and flying time and landings. You might consider the new tubes that cost more but don't lose pressure. Also, maybe more space between the tire and wheel faring should be considered. Contact Vans for more info.
Indiana Larry
On Tue, Sep 1, 2009 at 3:04 PM, Jeff Hove <flying(at)jeffhove.com (flying(at)jeffhove.com)> wrote:
| Quote: | --> RV7-List message posted by: Jeff Hove <flying(at)jeffhove.com (flying(at)jeffhove.com)>
Has anyone with a 7A (or other RV) experienced a flat main tire during takeoff or landing? Were you able to keep it on the runway? Did the wheel-pant survive?
I had a left main inner-tube fail during the taxi to the runway last week and even at a slow taxi it was hard to keep it straight as the tire deflated. Had the tube let go a minute later I'd have been on the take-off roll. The tire was fine and the tube was only 2 years old and looked ok except for a quarter-sized area where the rubber had become cracked and leaky. Apparently a manufacturing defect as there were no rough spots or FOD in the tire to cause this.
The way the tire bunched up inside the wheel-pant made me wonder if the wheel would continue turning and if even full opposite rudder and brake would be enough to keep the plane rolling straight had this happened at a higher speed.
Jeff Hove
Flying my father's RV-A, N347RV.http://www.matronics.com/Navigator?RV7-List
href="http://forums.matronics.com/" target="_blank">http://forums.matronics.com
-Matt Dralle, List Admin.
In God I Trust.
rv7(at)b4.ca Guest
Posted: Wed Sep 02, 2009 8:27 am Post subject: Flat main tire on takeoff or landing |
On Tue, 01 Sep 2009 15:04:31 -0500 Jeff Hove <flying(at)jeffhove.com> wrote
| Quote: | The tire was fine and the tube was only 2 years old and
An RV-9A owner at our field had a flat tire on a relatively new tube as well. He found it while it was parked, so it never became a rolling incident.
When we disassembled it to find the leak, we found that the area where the leak in the tube occurred was immediately opposite the place in the inside of the tire where an "Inspected OK" sticker had been placed... The owner remembered seeing the sticker when he assembled the wheel, but there wasn't much left of it after the tube failed, just a hard lump.
I think it's highly likely that either some combination of the adhesive and label material formed a hard substance when subjected to the repeated heating/cooling cycles that the tires see, or maybe the label disintegrated, and the remaining adhesive just collected all of the random grit in the tire into one place.
So when assembling your wheels, it might be a good idea to check very carefully for inspection stickers inside the tire, and make an effort to remove them and any adhesive residue before putting it all together.
| Quote: | Flying my father's RV-A, N347RV.
Must be nice.
-Rob
Rob Prior
rv7 at b4 dot ca
rafael(at)gforcecable.com Guest
Posted: Wed Sep 02, 2009 12:24 pm Post subject: Flat main tire on takeoff or landing |
Last December, I had the right main go out on me on landing on my rv-8A.
Control was not a problem, as I was able to keep the plane going down the
runway. The only problem was that it was impossible to taxi or move the
plane once it came to a stop.
I found out the hard way the phenomena of splenation [sp], where the tube
rubs against the tire and digs a hole in the tube. After that, I use plenty
of talcum and keep my tires inflated at 40 psi. The problem has not
returned.
Cheers,
Rafael
Posted: Thu Sep 03, 2009 9:56 am Post subject: Flat main tire on takeoff or landing |
Thanks Rafael for sharing your experience. That makes me feel a little
more confident that landing with a flat isn't too bad.
Sure glad I was at my home airport with the right sized wing-jacks and
other tools available. As you said, there doesn't seem to be any way to
move the plane until after the wheel pant is removed and the tire changed.
Blue Skies,
Jeff
returned.
Cheers,
Rafael
Posted: Thu Sep 03, 2009 4:06 pm Post subject: Flat main tire on takeoff or landing |
Unfortunately there is not an easy way to check tire pressure on the RV
without removing the whole wheel pant which is a lot of screws. It had
been checked just two weeks earlier though during a condition inspection.
On this day the tire had looked fine during pre-flight and rolled out of
the hangar easily and taxied normally. The deflation happened suddenly
during the taxi from the run-up area to the active runway.
Interesting tip about the newer style of tubes though. I'll investigate
that. Thanks.
Jeff
Larry Helming wrote:
| Quote: | No I haven't and I don't know of anyone. Sounds like you were lucky not
Indiana Larry
Jeff Hove
nics.com/Navigator?RV7-List"
target="_blank">http://www.matronics.com/Navigator?RV7-List
In God I Trust.
av8er2fly(at)peoplepc.com Guest
Posted: Thu Sep 03, 2009 8:15 pm Post subject: Flat main tire on takeoff or landing |
I cut a hole in my wheel pants and put a spring loaded small door that I
got from ACS. I then went and got a straight pressure gauge from Sears. I
check mine every two weeks because of crappy tubes that leak. I will be
changing them next set of tires.
Marrk Rose 137MR
rv7(at)b4.ca Guest
Posted: Thu Sep 03, 2009 8:24 pm Post subject: Flat main tire on takeoff or landing |
On Thu, 03 Sep 2009 12:38:06 -0500 Jeff Hove <flying(at)jeffhove.com> wrote
| Quote: | Unfortunately there is not an easy way to check tire pressure on the RV
RV pilots at our airport have cut small holes in their wheelpants, and use a valve stem extender that they spin on to the valve stem. When not checking tire pressures, they plug the holes with metal snap-in hole plugs that fit almost flush to the surface. It seems to work very neatly and the plugs can be painted to match the wheelpant and be almost invisible.
The top plug in the picture on this page is pretty much the one they're using:
<http://www.stimpson.com/hole_plugs.htm>
I'm pretty sure the extensions they found locally are 6" long, but this is the only example I could find with Google:
<http://www.primetimesolutions.com/Tire-Valve-Extender-9-inch>
-Rob
Rob Prior
rv7 at b4 dot ca
hoodcom(at)sbcglobal.net Guest
Allen Fulmer
Joined: 10 Jan 2006 Posts: 79 Location: Alexander City, AL
Posted: Fri Sep 04, 2009 8:29 am Post subject: Flat main tire on takeoff or landing |
I bought one of these but I cannot remember whether it has an end that fits the stem cap or not? At any rate, it has not been a problem as you can use a nut drive or socket with extension.
HTH,
Allen Fulmer
RV4 flying
RV7 wiring
http://www.aircraftextras.com/Valve-ext.htm
From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Bill Hood
Sent: Friday, September 04, 2009 10:31 AM
To: rv7-list(at)matronics.com
Subject: Re: Flat main tire on takeoff or landing
I found this site concerning schrader valve extension.
http://www.ryderfleetproducts.com/cgi-bin/ryderfp/products/srm/oid/46413/erm/product_detail.jsp?utm_source=googlebase&utm_medium=search&utm_campaign=product
wondering how to remove the stem dust cover before attaching extension?
Bill Hood
RV7
90% COMPLETE 50% TO GO
| Quote: | | http://www.matronics.com/Navigator?RV7-List | 0123456789
_________________ RV7 QB Fuselage
Eggenfellner H6 on orde
N808AF reserved
Alexander City, AL |
Posted: Fri Sep 04, 2009 9:14 am Post subject: Flat main tire on takeoff or landing |
valve stem extension
try this link,,,sorry
bill hood
HCRV6(at)comcast.net Guest
Posted: Fri Sep 04, 2009 9:44 am Post subject: Flat main tire on takeoff or landing |
I've been following this thread for awhile so here's my $0.0002 worth. I installed Michelin slow leak tubes over three years ago and am now on the second set of tires with the same tubes. I do a visual check each preflight and remove the front half of the wheel pants once a month or so to check pressure, takes about 15 minutes to do both mains. So far I have never seen the tire pressure drop by more than one psi per month and it is usually more like one psi in two or three months. Desser Tire sells the tubes, they ain't cheap but for my in my opinion well worth the cost.
Harry Crosby
RV-6 N16CX, 612 hours
