		dave.gribble(at)mchsi.com Guest
				 Posted: Mon Aug 31, 2009 5:06 pm    Post subject: Why Brass Bolt for ground terminal? |
				I'm building a firewall ground terminal system consisting of faston tabs soldered to sheets of brass stock.  I'll sandwich these around the RV firewall (thin stainless steel) and use a big bolt on one side to attach the battery and engine ground straps to.
 I see that the B&C version of this calls for a brass bolt - what is the reason for this, and also what size of bolt to use?  I assume it is a dissimilar metals corrosion problem... I have designed for a few smaller #8 bolts to hold the brass sheets together.. do these have to be brass too?
 Thanks for any info,
 Dave Gribble
 Cedar Rapids IA
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Mon Aug 31, 2009 6:25 pm    Post subject: Why Brass Bolt for ground terminal? |
				At 08:00 PM 8/31/2009, you wrote:
    If the Big bolt is long (like through a composite
    firewall) the brass bolt is preferred for electrical
    conductivity. But for a thin firewall, regular AN
    hardware is fine. The #8 hardware is mechanical only,
    plain vanilla AN hardware there too.
         ( . . .  a long habit of not thinking   )
         ( appearance of being right . . .       )
         (                  -Thomas Paine 1776-  )
		icubob(at)gmail.com Guest
				 Posted: Tue Sep 01, 2009 3:33 am    Post subject: Why Brass Bolt for ground terminal? |
				the brass bolt will carry the current thru the firewall to the ''forest of tabs'' you will mount on it on the cabin side of the firewall.
   bob noffs
  On Mon, Aug 31, 2009 at 9:23 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
  [quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
   	  | Quote: | 	 		  --> AeroElectric-List message posted by: dave.gribble(at)mchsi.com (dave.gribble(at)mchsi.com)
  s such as List Un/Subscription,
  www.matronics.com/Navigator?AeroElectric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
  ronics.com/" target="_blank">http://forums.matronics.com
  Matt Dralle, List Admin.
				 Posted: Tue Sep 01, 2009 6:43 am    Post subject: Why Brass Bolt for ground terminal? |
				Hi Glenn - I built the ground block because I like building things!  I enjoy the challenge, and also learning new skills (never sweat soldered brass before)....Sort of the same reason I'm building my plane instead of buying one
 I'm sure the B&C parts are nice, but $50 is about $49 more than I spent and I can save that money and put it towards my EFIS.  Besides, B&C has already got enough ca$h from me this month!
 -------------- Original message ----------------------
  Wow, I really appreciate your craftsmanship effort, but why would you
  build one of these? B & C sells them relatively cheaply and they are
  perfect for the job. Drill a hole, add the appropriate number of washers
  and move on.
  Glenn
  [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of bob
  noffs
  Sent: Tuesday, September 01, 2009 7:28 AM
  Subject: [Probable SPAM] Re: Why Brass Bolt for
  ground terminal?
   bob noffs
  too?
		Eric M. Jones
  Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
				 Posted: Wed Sep 02, 2009 5:42 am    Post subject: Re: Why Brass Bolt for ground terminal? |
				Since you want ground termination on both sides of the firewall, you can do approximately the following:
 Take a 2X long copper strap, fold it in the middle and insert it through a slot in the firewall (or around the edge). Then drill a battery ground bolt hole through both layers and the firewall too. The bolt hole is better if it is closer to the fold, but this is a fine detail.
  Teamwork: " A lot of people doing exactly what I say."
        (Marketing exec., Citrix Corp.)
  _________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
		bakerocb
				 Posted: Thu Sep 03, 2009 4:49 am    Post subject: Why Brass Bolt for ground terminal? |
				9/03/2009
 Hello Eric, Your proposal (see below) is not entirely clear to me.
 So you fold the copper strap only 90 degrees in the middle? Then you insert
 one leg of the angle through the slot in the firewall and place that leg
 along the stainless steel firewall and drill through both? Then place the
 battery ground bolt through that hole to connect the lug on the battery
 ground wire to the copper strip and the firewall? Then use the copper strap
 leg that is at 90 degrees to the firewall to connect things for grounding on
 the other side of the firewall through a previously drilled hole in the
 copper strap?
 Sounds good, but don't expect that the stainless steel of the firewall will
 provide a good reliable ground in other locations because of a non
 conducting film that tends to build up on the surface of the stainless
 steel.
 'OC' Says: "The best investment we can make is the effort to gather and
 understand knowledge."
 Time: 06:44:26 AM PST US
 Subject: Re: Why Brass Bolt for ground terminal?
 approximately
 the following:
 slot
 through
 Eric M. Jones
 113 Brentwood Drive
 (508) 764-2072
				 Posted: Thu Sep 03, 2009 5:17 am    Post subject: Why Brass Bolt for ground terminal? |
 firewall will provide a good reliable ground in other locations
 because of a non conducting film that tends to build up on the
 surface of the stainless steel.
    In the best of all ELECTRICAL worlds, we don't worry about
    high quality electrical bonding to the firewall. The goal
    of optimum ground system is to avoid using the firewall sheet
    (or engine mounts) for any electrical purpose.
    The diagrams suggested in Z-15 go toward those goals and
    suggest that for metal airplanes, it's no REALLY big deal
    to ground strobes, nav lights, and a few odd accessories
    locally.
    What Eric is suggesting is a 'lamination' of the firewall
    sheet between the folds of a copper strap that is fastened
    to the firewall with one fat bolt for battery and crankcase
    grounds . . . and spreading the other grounds out over the
    outside surface of the U-shaped copper strap by what ever
    means is most attractive. If everything grounded to this
    construct, then it wouldn't matter if the copper were well
    bonded to the stainless.
