vk3eka(at)bigpond.net.au Guest
Posted: Fri Aug 28, 2009 10:38 pm Post subject: 601XL Cowling |
Hi Guys,
I received my camlocs for the cowling from ASSC the other day.
Attached is a photo. The photo shows:-
40S5-3S SS CAMLOC STUD | Quote: | | 4002-NS CAMLOC GROMMET 214-16ND CAMLOC 4002 Receptacle |
How do I get the stud into the grommet. Do I have to remove the pin? If so, how?
Cheers
Peter
Wonthaggi Australia
http://zodiac.cpc-world.com
504.63 KB |
4765 Time(s) |
Posted: Fri Aug 28, 2009 11:12 pm Post subject: 601XL Cowling |
I haven’t used the grommets on mine but this is how I get the camloc studs through the holes I drill. Compress the camloc and its spring with the special camloc pliers. Then you should be able to “hook” the shaft with the pin through the grommet. Try this document:
www.afscamloc.net/xua/downloads/Camloc%20Quick%20Release%20Fasteners.pdf
-- Craig
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Peter W Johnson
Sent: Saturday, August 29, 2009 12:38 AM
To: zenith-list(at)matronics.com; zenith601-list(at)matronics.com
Subject: 601XL Cowling
Hi Guys,
Cheers
Peter
Wonthaggi Australia
Posted: Fri Aug 28, 2009 11:22 pm Post subject: 601XL Cowling |
Craig,
Thanks for that.
A pair of needle nose pliers did the same thing. I was looking for a complicated solution to what is a simple problem.
Peter
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Craig Payne
Sent: Saturday, 29 August 2009 5:08 PM
Subject: RE: 601XL Cowling
-- Craig
Hi Guys,
Cheers
Peter
Wonthaggi Australia
| Quote: | | 214-16ND CAMLOC 4002 Receptacle | 0 | Quote: | | 214-16ND CAMLOC 4002 Receptacle | 1 | Quote: | | 214-16ND CAMLOC 4002 Receptacle | 2 | Quote: | | 214-16ND CAMLOC 4002 Receptacle | 3 | Quote: | | 214-16ND CAMLOC 4002 Receptacle | 4 | Quote: | | 214-16ND CAMLOC 4002 Receptacle | 5 | Quote: | | 214-16ND CAMLOC 4002 Receptacle | 6 | Quote: | | 214-16ND CAMLOC 4002 Receptacle | 7 | Quote: | | 214-16ND CAMLOC 4002 Receptacle | 8 | Quote: | | 214-16ND CAMLOC 4002 Receptacle | 90123
NYTerminat(at)aol.com Guest
Posted: Sat Aug 29, 2009 5:55 am Post subject: 601XL Cowling |
Peter,
There is a tool that is used to install these. Look in the catalogue that you purchased them from. If I remember you can modify a pair of pliers to match the tool.
Bob Spudis
