Lee Francke
Joined: 02 May 2007 Posts: 3 Location: Prairie du Sac, WI
Posted: Thu Aug 27, 2009 11:34 am Post subject: Main gear wheel removal |
What is the easiest way to remove a wheel from the main gear to change tire?
Posted: Thu Aug 27, 2009 2:09 pm Post subject: Main gear wheel removal |
Melvin,
I'm initially presuming the effort to raise the tire on a 601XL. A
C-clamp with a small jack will work if it's
done in the hangar. If it's unexpected on a trip, you may have to be
prepared with a C-Clamp and a scissor-jack
in your stowage. For HD series gear all wheels are easily removed with a
small jack and a bent bar with a T welded
to it. See link.
http://www.macsmachine.com/images/completion/full/Teebarforkjack2.gif
http://www.macsmachine.com/images/completion/full/601-gear-fork-jack.gif
If you're in the boonies with a tire change needed with a HD series, you
might
find someone that wants to act as a jack with his legs, feet under the
spar. Ha!
Melvin Francke wrote:
| Quote: | What is the easiest way to remove a wheel from the main gear to change
tire?
