Big Iron Envy
robin1(at)mrmoisture.com
PostPosted: Tue Aug 25, 2009 9:52 pm    Post subject: Big Iron Envy Reply with quote
RV-List,
  In the past I have mentioned that a number of pilots have said how bright & noticeable my Dual Wig Wag HID lights are from the ground when I am on approach during the daylight hours. This is exactly what I wanted from the first day I saw my neighbor’s Pilatus swoop into our home field with his flashing HID’s a blazing. I think the little boy inside of me said… “me want.”
  Well yesterday on a dusk flight departing the LA basin ATC called traffic “South West 737 you have RV-10 Traffic 10 O’clock, 17 miles 8,500 feet. November 110EE traffic 2:00 O’clock descending out of one-one-thousand feet a Boeing 737.” Before I could respond the South West 737 replied Traffic Insight. Moments later the SW pilot told me through the controller “that is some light system he has on his RV-10, it’s really easy to pick up” COOL! Getting “at a boy’s” from commercial pilots.
I consider the Wig-Wag HID’s to be an important safety feature on my -10. Seeing is avoiding.
  The set up is nothing out of the ordinary with the exception of dual 35W HID lights placed in the leading edge. If interested I have a page that shows the install. http://www.painttheweb.com/rv-10/Lights_LEDHID.htm . One more thing of note. When on that page you will also see some pretty expensive (but nice) LED Position Lights. My next build is an RV-8A and I have found a set of Red & Green LED bulbs for around $8.00 each including wired sockets (eBay). These appear to be an excellent and cost effective solution vs. the printed circuit board LED’s I used on my -10. Plus some significant time savings to install as well. I will report results once flying.
Not exactly the LED’s I purchased but this gives you an idea of the concept: eBay Item# 380151029392
Robin
RV-4 Sold
RV-6A Sold
RV-10 75 Hours
RV-8A Flying 2010
bmeyette
PostPosted: Wed Aug 26, 2009 5:40 am    Post subject: Big Iron Envy Reply with quote
i'm confused - I thought HIDs couldn't (or shouldn't) be flashed
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Robin Marks
Sent: Wednesday, August 26, 2009 1:43 AM
To: rv10-list(at)matronics.com; rv-list(at)matronics.com
Subject: Big Iron Envy
RV-List,
Robin
RV-4 Sold
RV-6A Sold
RV-10 75 Hours
RV-8A Flying 2010
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
No virus found in this incoming message. Checked by AVG - www.avg.com 270.13.66/2325 - Release Date: 08/25/09 06:08:00 [quote][b]
Brian Meyette, Cornish, NH
RV-7A QB tipup, supercharged Subaru STi engine, MT CS prop, all glass day/night/IFR panel, being built with solar and wind power
N432MM
http://brian76.mystarband.net/RV-7Ahome.htm
PostPosted: Wed Aug 26, 2009 6:26 am    Post subject: Big Iron Envy Reply with quote
Many WigWag kits available. Most important that the controllers have a warm up feature so the bulb is not cycled till it is warm.
Regarding Wig Wag:
http://www.duckworksav.com/WigWag.html
REMEMBER: Not all wig-wags will work with HID lights! Be sure you use one specifically designed for use with HID units.
[img]cid:image001.jpg(at)01CA261E.39031C60[/img] Duckworks True Solid State Flasher
This Flasher is great for new installations, or as a fantastic replacement for a setup where you want to upgrade to support HID, or your Flasher has failed or is inadequate and you want to use the switches you already have in the panel.
  • No 'Clacking' Relays - ALL Solid State - Silent operation
  • Compatible with Halogen and HID Units
  • Small and lightweight
  • Alternating Flash at 1.1Hz Flash Rate
  • Capable of handling up to 300W (150W per side)
  • Mixing of HID and Halogen Lamps OK
  • Simple 4 wire connection
  • Easy Mounting with removable Flange
  • Full instructions including wiring diagrams
Note - This unit does NOT have an automatic HID 'warm-up' feature like the XeVision unit. Pilot must remember to warm-up the HID lights before switching to Flash.
See our switch options below.
Application
Order direct from Duckworks
Price
Order
All Halogen and HID Lights
TSSFlasher- Sale! (while supplies last)
$85
[img]cid:image003.jpg(at)01CA261E.39031C60[/img] MaxPulse Flasher/Total Light Control
  • Single Knob Control of both Lights - Off, Starboard, Port, Both, Alternating or Both Pulse
  • Dual 10A Circuits
  • Small and Easy to Install
  • Fully FAA PMA STC Certified
  • Automatic startup of HID Lamps
  • More Information - Brochure
Go to the MaxPulse site to see Installation Instructions, Diagrams, and STC Documentation.
Application
Price
Order
Halogen Lamps and HID Lamps
MaxPulse- Sale! (while supplies last)
$140
http://www.tcwtech.com/ILC-4ch.htm
http://www.xevision.com/hid_pulsing.html
Very important that the Wig/Wag has Warm Up Feature so HID does not pulse till fully warmed up (30 seconds or so).
Good luck,
Robin
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Brian Meyette
Sent: Wednesday, August 26, 2009 6:39 AM
To: rv-list(at)matronics.com
Subject: RE: Big Iron Envy
RV-List,
Robin
RV-4 Sold
RV-6A Sold
RV-10 75 Hours
RV-8A Flying 2010
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c
 Filesize:  7.68 KB
 Viewed:  2256 Time(s)
 Filesize:  43 Bytes
 Filesize:  2.38 KB
 Filesize:  21.33 KB
 Filesize:  106.33 KB
rgf(at)dcn.davis.ca.us
PostPosted: Wed Aug 26, 2009 6:41 am    Post subject: Big Iron Envy Reply with quote
They can be flashed if they’re allowed to warmup up first (30-60 seconds of steady on). Even then the life is shortened but it’s still measured in the 1000s of hours I believe.
RF
carlosh(at)structuralaz.c
PostPosted: Wed Aug 26, 2009 7:52 am    Post subject: Big Iron Envy Reply with quote
Here's a site that has done something very simila regarding the nav lights light the ones you've shown. Here's his link. http://www.reiffpreheat.com/RV4.htm Scroll to the bottom to see his installed pics.
Carlos in Arizona
Robin Marks wrote: [quote] <![endif]--> <![endif]-->
RV-List,
Robin
RV-4 Sold
RV-6A Sold
RV-10 75 Hours
RV-8A Flying 2010
Carlos Hernandez <carlosh(at)sec-engr.com> (carlosh(at)sec-engr.com)
Structural Engineers Company
2963 W. Elliot Rd. - Suite 3
Chandler, AZ 85224
Phone: 480.968.8600
Fax: 480.968.8608
www.sec-engr.com
CONFIDENTIALITY NOTICE
The information in this email may be confidential and/or privileged.
This email is intended to be reviewed by only the individual or
organization named above. If you are not the intended recipient or
an authorized representative of the intended recipient, you are hereby
notified that any review, dissemination or copyingof this email and
its attachments, if any, or the information contained herein is
prohibited. If you havereceived this email in error, please
immediately notify the sender by return email and delete this email
from your system.[b]
