Posted: Sun Aug 16, 2009 5:38 am Post subject: 12 volt 3 or 4 pole relay for 1 to 2 amp load? |
At 09:18 PM 8/15/2009, you wrote:
| Quote: | Hello Bob,
I want to add a little 3 pole relay to turn a Trutrak Flight Systems Automatic Pitch Trim on and off. (I did not consider this capability when I was running my wire bundle to the pitch servo area though I do have a spare pair that could be used to control a relay.)
Page 7 of the Trutrak manual has the wiring diagram for their Auto Trim module.
http://www.trutrakflightsystems.com/documents/AutomaticPitchTrim.pdf
Can you recommend a relay that might be carried by Allied Electronics? http://www.alliedelec.com/
I don’t think you sell such a critter. |
Allied has a lot of choices. This one is suited
to your task:
http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=8210912&MPN=LY3F-DC12
http://www.alliedelec.com/Images/Products/Datasheets/BM/OMRON_ELECTRONICS_LLC/821-0906.PDF
[img]cid:.0[/img]
( -Thomas Paine 1776- )
44.36 KB |
2347 Time(s) |
Posted: Sun Aug 16, 2009 10:38 am Post subject: 12 volt 3 or 4 pole relay for 1 to 2 amp load? |
| Quote: | Hello Bob,
to your task:
[img]cid:7.1.0.9.0.20090816133725.01ee4288(at)aeroelectric.com.1[/img]
44.36 KB |
2333 Time(s) |
Allen Fulmer
Joined: 10 Jan 2006 Posts: 79 Location: Alexander City, AL
Posted: Sun Aug 16, 2009 6:48 pm Post subject: 12 volt 3 or 4 pole relay for 1 to 2 amp load? |
Thank you BobN and BobMc.
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III
Sent: Sunday, August 16, 2009 1:38 PM
Subject: Re: 12 volt 3 or 4 pole relay for 1 to 2 amp load?
Hello Bob,
to your task:
44.36 KB |
2323 Time(s) |
_________________ RV7 QB Fuselage
Eggenfellner H6 on orde
N808AF reserved
Alexander City, AL |
