Rudder Skin Question
jakecrause(at)yahoo.com
PostPosted: Sat Aug 15, 2009 1:14 pm    Post subject: Rudder Skin Question Reply with quote
Hey folks,
I've got two questions concerning 801 rear rudder skin. Each question has a photo to go with it.
Question 1: If you notice from the photo, the edge of the very forward bottom corner of the skin appears to be uneven. What I mean is that when the skin was cut out at the factory it appears there was not enough material in the sheet it was cut from to make the skin? It looks like it runs out of sheet at the bottom. Is this normal?
Question 2: The bottom of my rudder skin was cut by the builder assist facility I took delivery of the tail kit from. Looking at photo two, the very rear edge near the fold was not cut straight but in an upward fashion. The builder manual says cut along the pre-marked line but since it was already cut I don't know where that line was laid out. Is this right?
Thanks guys. I look forward to hearing from you.
Jake Crause
Pooler, GA
 Filesize:  70.9 KB
 Viewed:  4802 Time(s)
 Filesize:  75.27 KB
Phil Owens
PostPosted: Sat Aug 15, 2009 1:46 pm    Post subject: Rudder Skin Question Reply with quote
------------Boundary-00=_INTFQ7B2QL8000000000--
Phil Owens
CH-801 Builder
akskydiver
PostPosted: Sun Aug 16, 2009 7:19 am    Post subject: Rudder Skin Question Reply with quote
Hi Jake,
For question one, it looks like my rudder skin is the same. Your' is not on the rudder yet so I can't tell if it's worse than mine. I guess this applies to both questions, but the important thing is the edge distance of the rivets in the skin. Some times it might make things look better to round an edge here and there as long as the pilot holes line up and the edge distance is correct.
This is my first kit so I'm not an expert, but that is my two cents.
Have fun building
Chane Burk
801 50% done 150% to go
928-580-6339
To: zenith701801-list(at)matronics.com
Sent: Saturday, August 15, 2009 2:04:58 PM
Subject: Rudder Skin Question
Hey folks,
Jake Crause
Pooler, GA
CH801 with 13B 50% done 110% to go.
PostPosted: Sun Aug 16, 2009 3:12 pm    Post subject: Rudder Skin Question Reply with quote
Thanks Chane. I checked the edge distance for the last rivet hole and it's right at 9.3mm (see photo). It's not 10mm but it's more than the 2x the diameter which the AC 43.13 dictates. Interesting that you had a similar problem. I may just trim one side to match the other just for appearances sake.
Can anyone else see Phil's response to this question yesterday? It came as a blank email in my inbox. I'm wondering if it's yahoo giving me trouble. Thanks.
Jake
334-655-7680 (cell)
Sent: Sunday, August 16, 2009 11:15:39 AM
Subject: Re: Zenith701801-List: Rudder Skin Question
Hi Jake,
Have fun building
Chane Burk
928-580-6339
Hey folks,
Jake Crause
Pooler, GA
 Filesize:  69.99 KB
 Viewed:  4783 Time(s)
bob(at)frontrange-pc.com
PostPosted: Sun Aug 16, 2009 4:25 pm    Post subject: Rudder Skin Question Reply with quote
Jake,
I don’t have Yahoo mail and Phil’s response was blank for me as well.
Bob Percival
Scratch 701/Vair – working on Elevator/Stab – after I recover from my daughter’s wedding
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of Jake Crause
Sent: Sunday, August 16, 2009 5:02 PM
Subject: Re: Rudder Skin Question
Jake
334-655-7680 (cell)
Hi Jake,
Have fun building
Chane Burk
928-580-6339
Hey folks,
Jake Crause
Pooler, GA
Checked by AVG - www.avg.com
08/16/09 06:09:00
