IO-390 Governor Cable Routing...
Site Admin
PostPosted: Sun Aug 16, 2009 2:41 pm    Post subject: IO-390 Governor Cable Routing... Reply with quote
Hey, first I wanted to say thanks for the feedback on all my other questions!
So I ran the Governor cable today and it came out pretty nice and seems to work well. The only thing that seems a little 'if-y' is how I had to route the cable over the top of the oil sump. Is this SOP or should the cable be isolated from the sump some how? I guess I could make a standoff bracket to hold it up off the sump, but do I really need to? The cable is currently resting on the sump.
Thanks!
RV-8 #82880 N998RV
http://www.mykitlog.com/dralle
 Filesize:  192.05 KB
 Viewed:  2186 Time(s)
 Filesize:  184.53 KB
 Filesize:  183.11 KB
 Filesize:  175.14 KB
wgill10(at)comcast.net
PostPosted: Sun Aug 16, 2009 8:33 pm    Post subject: IO-390 Governor Cable Routing... Reply with quote
Hello Matt,
That's certainly doable, but will be very intrusive if you use Van's FAB
air box & filter assembly. There are several variations of the prop
governor, FAB air box, and front baffle posted on Marc Ausmen's site...
http://www.io-390.com/IO-390.com/Welcome.html
Best regards,
Bill Gill
RV-7 N151WP
Barrett IO-390
