Gaskets For Constant Speed Props & Misc...
Site Admin
PostPosted: Sat Aug 15, 2009 8:50 pm    Post subject: Gaskets For Constant Speed Props & Misc... Reply with quote
Is there a gasket to seal the CS prop to the crankshaft? Looks like there is a taper fitting between the prop and the crankshaft. What are the torque values for the prop bolts? I have a 72" Hartzell prop I got new from Van's, but I don't find the installation instructions in my pile of stuff. Anybody have any?
Thanks!
RV-8 #82880 N998RV
http://www.mykitlog.com/dralle
FWF
t6pilot(at)cfl.rr.com
PostPosted: Sun Aug 16, 2009 5:25 am    Post subject: Gaskets For Constant Speed Props & Misc... Reply with quote
There should be an O ring installed on the inside of the prop shaft. Also,
the torque should be on a decal on the cyliner of the prop. However,
strongly recommend that you obtain the Hartzell Owners/Installation Manual
115 N gives all the requirements for installation, which is on line and
available here:
http://www.hartzellprop.com/product_support/sitelinks_prod_pricelist.htm
Fly Safe.
Site Admin
PostPosted: Sun Aug 16, 2009 8:43 am    Post subject: Gaskets For Constant Speed Props & Misc... Reply with quote
Yeaaa, I found my Hartzell installation manual this morning. Thanks for the tips!
Matt
At 06:15 AM 8/16/2009 Sunday, you wrote:
There should be an O ring installed on the inside of the prop shaft. Also, the torque should be on a decal on the cyliner of the prop. However, strongly recommend that you obtain the Hartzell Owners/Installation Manual 115 N gives all the requirements for installation, which is on line and available here:
http://www.hartzellprop.com/product_support/sitelinks_prod_pricelist.htm Fly Safe.
