Splicing wire
bcollinsmn
PostPosted: Sat Aug 15, 2009 7:19 pm    Post subject: Splicing wire Reply with quote
A pretty elementary question, I'm afraid. Can you refer me to the proper location of the resource that shows the proper way to splice two wires into one?
Specifically, I'm making a wiring harness for an Icom A210 and I don't want to jam two #18 wires into the single molex pin for the jumper for ground and power.
Instead, I'd like to take a single wire out of each connector, splice them to a third wire and run that wire to ground and the buss.
I've seen pages on single-wire to single-wire, and I've seen doing this with shielded cable etc., but I'll be darned if I can find the proper technique for this.
Warm regards.
Bob Collins
St. Paul, Minn.
RV-7A - Running wires
http://rvbuildershotline.com
Day job: http://minnesota.publicradio.org/collections/special/columns/news_cut/
n395v
PostPosted: Sun Aug 16, 2009 3:59 am    Post subject: Re: Splicing wire Reply with quote
I would consider a lash splice............
http://workmanship.nasa.gov/guidadv_recmeth_lashsplice.jsp
covered with heatshrink.
 Filesize:  9.99 KB
 Viewed:  5069 Time(s)
Milt
Bob Collins
PostPosted: Sun Aug 16, 2009 6:18 am    Post subject: Splicing wire Reply with quote
Excellent, Milt. Thank you.
B
Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/
PostPosted: Sun Aug 16, 2009 8:50 am    Post subject: Splicing wire Reply with quote
At 06:59 AM 8/16/2009, you wrote:
That works good. We've published similar processes
on aeroelectric.com
Solder and insulate techniques range from the
simple processes described above to the more
sophisticated (and expensive) process illustrated
here:
http://parts.digikey.com/1/parts-kws/solder-sleeve
Any methodology that achieves good mechanical
and electrical joining of the wires followed by
robust insulation will serve your purposes. The
simplest processes are recommended.
( -Thomas Paine 1776- )
