johngoodman
Posted: Wed Aug 12, 2009 8:25 am Post subject: Nose strut bend |
Looking at my untouched nose strut, I happened to notice a very subtle curve, or bend, to it. If you put a straight edge on it, it has a constant curve to the right. The gap between the straight edge and the tube is very small - only about 1/16", but it's definitely there.
Looking at the almost completed RV-10 next to me, the tube is straight. Perhaps weight takes it out? Anybody seen or heard of this?
dogsbark(at)comcast.net Guest
Posted: Wed Aug 12, 2009 8:43 am Post subject: Nose strut bend |
John,
Not sure if we're talking about the same part, but my nose gear had a curve in it. It was off by 3/16" in the middle. I contacted Van's with pics and they sent a replacement. I did not have to send the old one back. It now resides in a scrap heap.
Van's told me they had a few of these that came out this way from the supplier and there was an occassional jig issue during welding.
Here's a pic: http://websites.expercraft.com/seanb/index.php?q=log_entry&log_id=19689
Sean Blair
rebrunk42(at)gmail.com Guest
Posted: Wed Aug 12, 2009 8:44 am Post subject: Nose strut bend |
i noticed my vans tires were wearing on the outside . is there a
reason for this and a fix?robert 661G i will check my nose strut for
your anomaly.
On Aug 12, 2009, at 11:25 AM, johngoodman wrote:
there.
#40572 QB Fuselage, wings finished. Finish Kit progressing. Engine
& Panel delivery soon.
N711JG reserved
http://forums.matronics.com/viewtopic.php?p 57297#257297
johngoodman
Posted: Wed Aug 12, 2009 8:59 am Post subject: Re: Nose strut bend |
Here are two photos of mine.
37.79 KB |
5410 Time(s) |
37.23 KB |
5410 Time(s) |
Tim Olson
Posted: Wed Aug 12, 2009 10:17 am Post subject: Nose strut bend |
This is just how the tires wear on the RV-10's. Run them that way
and flip them 1/2 way through their life.
To keep the subject lines accurate, you may want to start a new
thread or change the subject line when taking the thread
in a different direction.
Tim Olson - RV-10 N104CD
Robert Brunkenhoefer wrote:
i noticed my vans tires were wearing on the outside . is there a reason
for this and a fix?robert 661G i will check my nose strut for your
anomaly.
> <johngoodman(at)earthlink.net>
> John
> N711JG reserved
aerosport1
Posted: Wed Aug 12, 2009 10:37 am Post subject: Nose strut bend |
I had a nose gear problem as well. It looked like the vertical portion of
the nose gear strut was welded about 4 degrees off. I contacted Vans with
photos with plumb bob and digital angle finder and they agreed and replaced
it.
Geoff
Geoff Combs
President
Aerosport Modeling & Design
8090 Howe Industrial Parkway
Canal Winchester, Ohio 43110
614-834-5227p
614-834-5230f
www.aerosportmodeling.com
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
Posted: Wed Aug 12, 2009 12:14 pm Post subject: Nose strut bend |
Sorry about that I wilco in the future
Robert E. Brunkenhoefer
Brunkenhoefer Law Firm, P.C.
520 Lawrence St.
Corpus Christi, Texas 78401
Phone: 361-888-8808
Facsimile: 361-888-6753
robert(at)brunklaw.com
On Aug 12, 2009, at 1:14 PM, Tim Olson <Tim(at)MyRV10.com> wrote:
> for your anomaly.
>> definitely there.
>> this?
>> John
>> N711JG reserved
