centre wing, HD(S) question
carlossa52(at)gmail.com
PostPosted: Mon Aug 10, 2009 3:10 pm    Post subject: centre wing, HD(S) question Reply with quote
Hello, all
Did anybody bother to bend plate 6V11-4 to fit the curvature of the wing?
I see small gaps at the front and rear, something around 1.0 mm ... see attached file...
Carlos
CH601-HD, plans
 Filesize:  251.95 KB
 Viewed:  4183 Time(s)
grs-pms(at)comcast.net
PostPosted: Mon Aug 10, 2009 4:20 pm    Post subject: centre wing, HD(S) question Reply with quote
Carlos:
Yes, I bent that plate. I supported the ends on a couple of pieces of wood and bumped the middle (carefully) with a wood block and hammer. Mine fits the contour perfectly.
I also bevelled the edges and put a generous radius on the corners.
George Swinford
MHerder
PostPosted: Mon Aug 10, 2009 8:38 pm    Post subject: Re: centre wing, HD(S) question Reply with quote
I didn't bother, I figured the amount of A5 rivets in there would suck it tight, and I was right. I'm sure it wouldn't hurt either way though. Good luck and keep trucking along. I agree 100 percent with taking your time to round those corners good and beveling, its smart structurally and that plate is pretty visible, so make it look right.
Zodiac 601 HD
Jabiru 3300
Wood Sensinich 64x47
Finally Flying
larry(at)macsmachine.com
PostPosted: Tue Aug 11, 2009 6:49 am    Post subject: centre wing, HD(S) question Reply with quote
Yes Carlos,
I had to bump the plate into a nearly imperceptible curve to get a fit.
Carlos Sa wrote:
Hello, all
Carlos
CH601-HD, plans
PostPosted: Tue Aug 11, 2009 3:43 pm    Post subject: centre wing, HD(S) question Reply with quote
Done - harder to describe than to do...  Smile
Thanks all for the replies
Carlos
2009/8/11 LarryMcFarland <larry(at)macsmachine.com (larry(at)macsmachine.com)>
[quote]--> Zenith-List message posted by: LarryMcFarland <larry(at)macsmachine.com (larry(at)macsmachine.com)>
Yes Carlos,
Larry McFarland  601HDS at www.macsmachine.com
