ltaylor02(at)Chartermi.ne Guest
Posted: Sun Aug 09, 2009 5:14 am Post subject: ENGINE OPTIONS |
I've performed a search regarding engine selection specific to VW applications and the AeroVee. Did anyone follow through with an AeroVee installation and if so, are you satisfied with performance? I have a new grey head 582 complete FF setup for my model IV, but am continuing to research other options. Appreciate any feedback. I've also been evaluating the Jabiru 2200.
Lane
ronal22(at)verizon.net Guest
Posted: Mon Aug 10, 2009 4:40 am Post subject: Engine Options |
I have a KF IV with a Jabiru 2200, and I am pleased with it's performance. I would recommend using the Skyfox cowl instead of the round cowl. Cooling is a major issue, but if you have sufficient air flow over the cylinders, it doesn't seem to be a problem. Also you might need to rejet the Bing carb to control the EGTs.
Ronal Smith, KF IV
Jabiru 2200, S/N 2030, 150hrs.
Lynn Matteson
Posted: Mon Aug 10, 2009 7:04 am Post subject: Engine Options |
I'll second what Ron said, and add that the addition of the Rotec
TBI-40 mechanical fuel injection system will enable the pilot to
control the EGT's rather well. I've been test flying mine over the
last several days, and I've seen EGT's as close together as (today's
flight) 41 degrees F., and CHT's as close together as 7 degrees F.
It's nice to be able to adjust the mixture with this device, and also
to see the fuel flow read down as low as 2.9 gph at about 80 mph
groundspeed into a 12 mph wind at 2700 rpm.
I've been playing with "lean of peak" with this device, which is one
reason that I bought it. It amazed me that you can see the EGT's go
down after reaching peak temperature....I was a sceptic as first, but
if the engine lives, I'll be a believer. Even without the ability to
go lean of peak, just being able to adjust the mixture on the fly is
worth the added workload on this pilot during takeoff and landing.
Lynn Matteson
Jabiru 2200, #2062, 727.5 hrs
Sensenich 62"x46" Wood prop
Rotec TBI-40 injection
Status: TBI installation done...tests flights underway
On Aug 10, 2009, at 8:32 AM, RONAL SMITH wrote:
| Quote: | I have a KF IV with a Jabiru 2200, and I am pleased with it's
EGTs.
Ronal Smith, KF IV
contribution_-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
jdmcbean(at)kitfoxaircraf Guest
Posted: Mon Aug 10, 2009 8:12 am Post subject: Engine Options |
Then there is always the Kitfox Smooth cowlings.
Fly Safe !!
John & Debra McBean
Ph 208.337.5111
www.kitfoxaircraft.com
"The Sky is not the Limit... It's a Playground"
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of RONAL SMITH
Sent: Monday, August 10, 2009 6:33 AM
To: Kitfox-List Digest Server
Subject: Engine Options
Ronal Smith, KF IV
| Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
jose_m_toro(at)yahoo.com Guest
Posted: Mon Aug 10, 2009 9:36 am Post subject: Engine Options |
Ronal:
Where is the oil cooler located in your installation?
José
To: Kitfox-List Digest Server <kitfox-list(at)matronics.com>
Sent: Monday, August 10, 2009 8:32:37 AM
Ronal Smith, KF IV
[quote][b][b]
Pat Reilly
Posted: Mon Aug 10, 2009 12:37 pm Post subject: ENGINE OPTIONS |
Lane, Why not use the 582? What reduction box is with it?
Pat Reilly
Mod3 582 Rebuild
Rockford, IL
On Sun, Aug 9, 2009 at 8:11 AM, lst <ltaylor02(at)chartermi.net (ltaylor02(at)chartermi.net)> wrote:
[quote] I've performed a search regarding engine selection specific to VW applications and the AeroVee. Did anyone follow through with an AeroVee installation and if so, are you satisfied with performance? I have a new grey head 582 complete FF setup for my model IV, but am continuing to research other options. Appreciate any feedback. I've also been evaluating the Jabiru 2200.
Lane
arget="_blank">http://www.matronics.com/Navigator?Kitfox-List
ttp://forums.matronics.com
Posted: Tue Aug 11, 2009 2:40 am Post subject: Engine Options |
Ron, Thanks for your feedback.
Posted: Tue Aug 11, 2009 3:15 am Post subject: ENGINE OPTIONS |
Hi Pat, It came with the C box and a GSC ground adjustable three blade prop. Are you using the 582 grey head? If so, are you satisfied with it and what kind of performance are you experiencing? Appreciate your feedback.
Lane
Posted: Tue Aug 11, 2009 7:19 am Post subject: Engine Options |
My oil cooler is located right in front of cooling fins on the Jabiru 2200 oil pan or case. There is about 0.5 inch clearance between the two. I have a bump-out over the cooler on the cowling with an opening at the bottom of the bump-out. This is so the air coming in the opening on the bottom cowl can flow over the oil cooler/engine case and then exit without pressurizing the bottom of the engine compartment.
When I got my cowling, John McBean was not in business. If he has the smooth cowl for the Kitfox IV, I would certainly look at that. My dealings with John have been excellent.
Ron Smith, Kitfox IV
Jabiru 2200, S/N 2030, 150 hrs.
Lewes, DE
806.74 KB |
101198 Time(s) |
748.86 KB |
101198 Time(s) |
Pat Reilly
Posted: Tue Aug 11, 2009 2:18 pm Post subject: ENGINE OPTIONS |
Lane I am still about 2 weeks away from having mine airborne. I am rebuilding a mod 3 that was set up for a 912. I was going to install a 912 but found a 100 hr 582 grey head C box FWF for about 1/3 of what a good used 912 would cost. The 582 is so much lighter that it should out climb the 912. I am an old 2 stroke dirt bike racer so I am comfortable with, understand, and like 2 stroke engines. The older lighter KF seem to me to be a bush plane that I wouldn't relish taking long trips in no matter what engine it had. If you want to know if the 582's are acceptable talk with Dave in Canada, Noel in Newfoundland and Lenoard in Alaska. They are on this web and between the 3 of them have more 582 experience than the rest of the world put together.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
On Tue, Aug 11, 2009 at 6:07 AM, lst <ltaylor02(at)chartermi.net (ltaylor02(at)chartermi.net)> wrote:
[quote] Hi Pat, It came with the C box and a GSC ground adjustable three blade prop. Are you using the 582 grey head? If so, are you satisfied with it and what kind of performance are you experiencing? Appreciate your feedback.
Lane
Posted: Wed Aug 12, 2009 2:40 am Post subject: ENGINE OPTIONS |
I'm also a motocrosser from the two-stroke days, but have recently made the conversion to a CRF450R like nearly everyone else. I have the advantage of being light--140 wet so perhaps the 582 will work just fine. I also like the idea that I can do my own rebuild having done countless bikes and sleds over the years. Have you tried Evans coolant in your 582. I used it in my 912 powered Pulsar XP and it work well. Thanks again for your feedback and the contacts.
Lane
