Thruster87
Posted: Mon Aug 10, 2009 1:22 am Post subject: Which Fuel Qty Gauges |
Which fuel qty gauges did you use with the 10 - 75 ohm sender units supplied in the Zenith kit ?? Thanks
vk3eka(at)bigpond.net.au Guest
Posted: Mon Aug 10, 2009 9:51 pm Post subject: Which Fuel Qty Gauges |
Alan,
I ordered a set of VDO gauges from the states. They have to be the VW ones
(part no. in the photo guides) to be compatible with the senders.
Would you believe they are smaller diameter than the standard 2.25" gauge. I
mounted them on the centre section away from the rest of the instruments.
Cheers
Peter
Wonthaggi Vic
http://zodiac.cpc-world.com
Thruster87
Posted: Tue Aug 11, 2009 1:52 am Post subject: Re: Which Fuel Qty Gauges |
| vk3eka(at)bigpond.net.au wrote: | Alan,
Cheers
Peter
Wonthaggi Vic
Hi Could you post/email the part number of gauges Cheers
Posted: Tue Aug 11, 2009 2:29 am Post subject: Which Fuel Qty Gauges |
VDO Part No. 301-020. Page 12 of 12 Photo guide 6-K-1B
chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Tue Aug 11, 2009 4:55 am Post subject: Re: Which Fuel Qty Gauges |
I got mine from E guages.com in the States..
Get the VW ones..
Chris.
n85ae
Posted: Tue Aug 18, 2009 1:12 pm Post subject: Re: Which Fuel Qty Gauges |
There's LOT's of gauges available that will work, go to
www.summitracing.com
look up fuel gauge, and there is a gauge selector menu
just make sure that the ohm's range matched your senders.
Jeff
