z601a(at)anemicaardvark.c Guest
Posted: Thu Aug 06, 2009 8:24 am Post subject: Bottom position of 6B17-1 |
I'm having a bit of fun trying to figure out where, longitudinally, the bottom
of 6B17-1 should be located. 6B17 shows the top connection, and indicates
that the bottom is affixed to 6B1-4.
Maybe I'm staring at it and don't see it, but I haven't found the dimension to
locate the bottom of 6B17-1. Obviously, those of you who are further along
have done something, and probably found the dimension. Any chance of sharing
this information with me?
TIA
Do not archive.
Jim B Belcher
BS, MS Physics, Math, Computer Science
A&P/IA
Retired aerospace technical manager
ashleyw(at)gvtc.com Guest
Posted: Thu Aug 06, 2009 9:11 am Post subject: Bottom position of 6B17-1 |
Jim.
Check the builders quide 6 B 17 page 9
Floyd Wilkes
601XL O-200
jaybannist(at)cs.com Guest
Posted: Thu Aug 06, 2009 9:48 am Post subject: Bottom position of 6B17-1 |
Jim,
What is critical is the 90 deg angle between the torque tube and the face of 6B17-1, both horizontally and veritcally. Cleco 6B17-1 to 6B5-1. Lay a tube or a rod in the holes where the torque tube goes and adjust 6B17-1 to make a 90 deg angle between it and the rod or tube for vertical alignment. Measure from both edges of the bottom of 6B17-1 to 6B5-5 to make sure it is parallel to 6B5-5.
As an aside, I don't know what you mean by "TIA", but to me it means "transient ischemic attack" - a mini stroke. I've had one and it is a really scary thing.
Jay Bannister
Posted: Thu Aug 06, 2009 12:31 pm Post subject: Bottom position of 6B17-1 |
On Thursday 06 August 2009 12:47, jaybannist(at)cs.com wrote:
| Quote: | Jim,
What is critical is the 90 deg angle between the torque tube and? the face
of 6B17-1, both horizontally and veritcally.? Cleco 6B17-1 to 6B5-1.? Lay a
make a 90 deg angle between it and the rod or tube for vertical alignment.?
parallel to 6B5-5.
Thanks for the idea. I may do that.
| Quote: | As an aside, I don't know what you mean by "TIA", but to me it means
"transient ischemic attack" - a mini stroke.? I've had one and it is a
really scary thing.
TIA = Thanks In Advance
Do not archive.
Jim B Belcher
A&P/IA
