Geared engined Commanders
barry.collman(at)air-brit
PostPosted: Mon Jan 02, 2006 4:29 pm    Post subject: Geared engined Commanders Reply with quote
Hi Bert,
I'm hoping this list of geared-engined Commanders (standard, ex-factory) is
complete..........
Geared:
520; 560; 560A; 560A(HC); 560E.
Geared & Supercharged:
680; 680E; 720.
Geared & Fuel Injected:
560F.
Geared, Supercharged & Fuel Injected:
680F; 680F(P); 680FL; 680FLP; 685.
........but if it isn't, I'm absolutely certain that somebody will shout -
LOUDLY!
Very Best Regards,
Barry
bertberry1(at)aol.com
PostPosted: Mon Jan 02, 2006 4:46 pm    Post subject: Geared engined Commanders Reply with quote
Thanks Barry,
I wonder how the K seriers Cont. That were put on the later 685's would have worked on the 680FLP?
Bert
CloudCraft(at)aol.com
PostPosted: Mon Jan 02, 2006 7:39 pm    Post subject: Geared engined Commanders Reply with quote
In a message dated 02-Jan-06 16:47:12 Pacific Standard Time,
bertberry1(at)aol.com writes:
They would have consumed the same 3 cylinders per year just like they do on
the AC-685 ...
Wing Commander Gordon
Life is not simple anywhere. Probably less so elsewhere.
YOURTCFG(at)aol.com
PostPosted: Mon Jan 02, 2006 8:09 pm    Post subject: Geared engined Commanders Reply with quote
YOURTCFG(at)aol.com
PostPosted: Mon Jan 02, 2006 8:10 pm    Post subject: Geared engined Commanders Reply with quote
n395v
PostPosted: Tue Jan 10, 2006 11:11 am    Post subject: Re: Geared engined Commanders Reply with quote
Barry not to be a nitpicker but the 520Ks are turbocharged not supercharged and they are also intercooled. Smile
To expand upon Wing Commander Gordon's comment about the 520Ks consuming 3 jugs a year I think a more accurate measure would be 3 cylinders per engine for every 700-900 hrs flown.
These beasts are putting out 435HP each on only 520CID (.84HP/CI)
Thats a lot to ask from an aircooled engine running overboost especially when 870HP total is really inadequate for that particular airframe.
With graphic engine analyzers and judicious lean of peak ops you can extend the life a little and only consume 2 jugs each 900 hrs+-. This costs a bit at the top end in performance and saves about 3GPH per side.
Good grief I go away for a few years and Ya'll forget everything I taught you. Rolling Eyes
OVER HIO at the flyin
 Filesize:  35.45 KB
 Viewed:  972 Time(s)
Milt
