al38kit
Posted: Sat Aug 01, 2009 3:28 pm Post subject: Load Monitoring |
I'm considering using two alternators, the 20 Amp B&C, and the 60 AMP Plane Power. I'm also considering using two PP regulators, as it appears that they will load share as a percent of output...I'm going to use a JPI 930 that has the ability to monitor two locations with 50mv shunts...they sell 100 AMP units at $75 a pop...I thought that to be a little much for a shunt...
I think I read that you were using 50mv shunts in your load meter set up and that they were matched or calibrated or something...
Do you think that using two of them on the load meter of the JPI would be a good idea...and how much are they?
Any other comments welcome, especially on the PP regulators and the load sharing feature.
PS...I found the Tyco EV200 relays for $50, delivered...so I bought them.
Al Kittleson
Posted: Sat Aug 01, 2009 5:06 pm Post subject: Load Monitoring |
At 06:28 PM 8/1/2009, you wrote:
Al Kittleson
Please don't do this. The elegant application of
the two alternators is EITHER as shown in
Z-11 or INDEPENDENT W/cross-feed as shown in
Z-14.
What are your load requirements that you think you'll
ever need the combined output of both alternators to
drive a single bus?
( -Thomas Paine 1776- )
al38kit
Posted: Sat Aug 01, 2009 6:03 pm Post subject: Re: Load Monitoring |
Sorry to not word the question better regarding the shunts.
I was generally thinking of a design along the lines of Z-14...my thought was to run with the crossfeed tie closed in normal operation and use both alternators to feed the tied busses...
If that is a bad idea, then I'll run split busses.
My monitor should function the same way, regardless of whether the buss tie is open or closed...that is where the question regarding the shunts enters the picture.
Al
Posted: Sun Aug 02, 2009 6:22 am Post subject: Load Monitoring |
At 09:03 PM 8/1/2009, you wrote:
The cross-tie is used only when one alternator has
failed and there's a useful mode of operation where
one alternator can feed equipment on both sides.
The cross-tie contactor is closed only for engine
cranking and single-alternator operations.
| Quote: | My monitor should function the same way, regardless of whether the
If you've done your homework (load analysis) then
the amount of power required of either alternator is
known before-hand for all flight conditions. In
other words, your plan-A, plan-B . . . plan-x execution
should not depend on reading an ammeter. But if your
electrical system monitoring device(s) come with
hall effect sensors, then they can go on the alternator
b-leads. For the most part, current displays are most
useful on the ground as trouble shooting assists.
Run each alternator with its own, stand alone regulator
and ov protection . . . and if your glass panels do not
include active notification of low voltage, then that
feature should be part of your instrumentation planing
for both sides.
What airplane are you building where you think you
can get a good return on investment for Z-14?
al38kit
Posted: Sun Aug 02, 2009 7:35 am Post subject: Re: Load Monitoring |
Bob,
I think we have a numbers of things that have come up regarding my original question...which was inquiring about the 50mv shunts and their price, which was the question du jour.
But to answer your question, I'm working on a rebuild of an Express (four place, low wing composite...family mobile, X-C plane)...It has an IO-520, three blade prop. I already have the 60-70 amp alternator belt driven alternator and the B&C gear driven unit.
As I don't plan to put in a vacuum system, the Z-14 design appears to be a good choice.
Is there something about the Plane Power regulator that you don't like?
I'm open to ideas, but using a regulator that was designed to load share seems like a good idea, but if it isn't, it's easy to go with the open tie buss design.
I've flown a lot of big airplanes where tying the busses together is ops normal. I've had some thought of trying this too. If it is, or turns out to be a bad idea, all I need to do is open the tie buss relay.
I'll do all the normal buss load analysis and thought that an easy way to monitor loads would be to use your shunt, along with the JPI monitor. This monitor has user settable alarms for current and voltage.
What are your thoughts on the shunts in this application? I don't have any hall effect ammeters right now and as the JPI has two shunt type ammeters available, I thought it would be a good idea to use them...
What about the Plane Power regulators? From talking to the owner of the company, they work in tandem by turning each alternator "ON" for the same period of time. He claims that dissimilar sized alternators can easily be used in this type of setup. It's normally used in twin engine aircraft, with one buss.
I'm not attempting to be a heretic, just exploring other options...I have almost all the parts that I have scrounged second hand (Including the JPI monitor)...
How about "them shunts"...?
Cheers,
Al
Posted: Sun Aug 02, 2009 8:44 am Post subject: Load Monitoring |
At 10:35 AM 8/2/2009, you wrote:
Bob,
oops . . . yeah. If your system uses 50mv shunts both
I and B&C have them in stock in various sizes. I can
cut larger shunts down to smaller applications as
well. I think we both get $25.00/ea for them.
| Quote: | But to answer your question, I'm working on a rebuild of an Express
Oh yeah, I recall that now.
| Quote: | As I don't plan to put in a vacuum system, the Z-14 design appears
Agreed
| Quote: | Is there something about the Plane Power regulator that you don't like?
Not a thing. I'm sure their product performs as advertised. But
it's not clear that they are true load sharing devices driven
by DIRECT MEASUREMENT of output from all power generating
devices. For example, the Hawkers have two engine driven
generators and one APU driven generator. ALL three can be
tied to the one bus at the same time. Each generator will
be loaded to it's proportionate share of the load based on
individual capability (the APU generator is smaller than
the other two). This isn't rocket science but it's not
trivial either.
| Quote: | I'm open to ideas, but using a regulator that was designed to load
That's the original design goal for Z-14 for a variety
of reasons . . . not the least of which is the hassle/
expense of true load-sharing regulators. I've designed
and proposed two different load sharing regulators over
the years. All worked as advertised but were markedly
more expensive than the stand-alone, single alternator
regulators. We never went to production with them in
spite of the fact that the Cessna and Beech light
twins really needed them. Today, I could do a uP based
regulator for a small fraction of the cost and much
better performance . . . neat stuff that software!
The really cool thing about the old carbon pile
regulator for generators is their ease of paralleling
using the relatively high voltage drop in generator's
compensation windings as a crude shunt. See:
http://aeroelectric.com/Pictures/Schematics/Parallel_Aircraft_Generators.jpg
a simple addition of a few turns of wire in the
regulator wired to cross-tied compensation windings
did a pretty good job of paralleling the generators
with a minimum parts count. Alternators are a whole
other problem . . .
| Quote: | I've flown a lot of big airplanes where tying the busses together is
Yup, wiring the 2-50 switch as illustrated gives you
auto-tie for cranking and leaves the bus-tie contactor
open unless selected by moving to the opposite position.
| Quote: | I'll do all the normal buss load analysis and thought that an easy
Very well. We can get the proper shunts into your
possession through several venues.
| Quote: | What are your thoughts on the shunts in this application? I don't
If they're already in place, then putting them
to useful service is not a bad idea. The shunts
don't weigh much either.
| Quote: | What about the Plane Power regulators? From talking to the owner of
In that situation you MUST do something to
distribute the loads. Making two IDENTICAL
alternators, turning THE SAME SPEED approximately
share loads by what I BELIEVE Plane Power does is
indeed practical. But I that control philosophy
wouldn't work with a 60/20 or 40/20 combination
like Z-14 where the alternators are different from
each other and turn different speeds.
| Quote: | I'm not attempting to be a heretic, just exploring other options...I
Understand and no fault perceived. Sounds
like you've got a workable plan that needs
at most a bit of tweaking.
| Quote: | How about "them shunts"...?
Can fix you up. You can place an order by ordering
a dual ammeter kit from the website and enter quantity
of "0" but put values in for the shunts you need.
klehman(at)albedo.net Guest
Posted: Sun Aug 02, 2009 9:05 am Post subject: Load Monitoring |
With Z-14 normally running with isolated alternators, I have instant
notification of either alternator failing due low voltage. With
paralleled alternators I presume you would add something like low
current warnings (independent of the regulator) to warn of a bad alternator.
Ken
| Quote: | > Is there something about the Plane Power regulator that you don't like?
trivial either.
al38kit
Posted: Sun Aug 02, 2009 9:52 am Post subject: Re: Load Monitoring |
Bob,
I really appreciate your insight into this stuff. I'm not just "kicking the tires" but really plan some installation in the near future and I'm just getting stuff lined up...
Regarding the PP regulators, I'm sure Les said that alternators of dissimilar outputs would load share based upon their respective max values...If, for example, you used the 20/60 amp combo and required 40 amps, each alternator would be tasked with 50% of the load...but I'll check into it...I believe he said that it could be done by each regulator being fired up for the same amount of time...does that make sense to you?
I'm not sure why that would work, but I'm pretty sure that's what he said was the basis for the idea. I believe both regulators are connected by a single wire that gives the feedback of them "knowing" how long to stay on.
Probably my final question on this topic: If more current is needed from an alternator than it is able to make, what happens?
I expect that most of these alternators will produce more than the rated current. At PP they told me that the 60 amp will easily put out more than 70. I'm not advocating that anyone try it, and I expect there are a lot of bad things that would happen if one tried to do it for a long time. Excess heat and premature failure are two things I can think of, or even catastrophic failure of the unit...what I'm wondering is...what would occur if, say, the 60 amp unit failed and only the 20 amp unit stayed on line when the overall requirement was 50 amps.
Would the 20 amp unit continue to do it's job to the best of it's ability, with the battery(s) picking up the slack for as long as they could, or would something worse happen?
I'm wondering as this could be the situation IF the 60 amp unit failed and one continued with the 20. I expect I could get by indefinitely on the 20 as long it's pitot heat and/or lights were needed...just wondering if when that occurred, what would happen.
I suspect that the alternator would do what it could and that the battery(s) would pick up the slack with the buss voltage going down from 13.8-14 to whatever voltage the batteries could supplement...like 12.2 something...
What do you think?
Sorry if this is an old question, but I'm new to the forum and didn't find anything with a search.
Thanks again,
Al
Posted: Sun Aug 02, 2009 11:17 am Post subject: Load Monitoring |
At 12:04 PM 8/2/2009, you wrote:
Ken
The B&C alternator controllers were designed such that
LV warning is powered independently of the lead that
powers the alternator. The idea was to maintain as much
separation as possible between jelly-bean parts that
"regulate" as those which "warn".
Newer designs with micro-controllers often tempt the
designer to roll it all up in one piece of silicon.
The legacy design goals for separation suggest this
is not a good idea. So even if we were to develop
a processor based regulator, the OV/LV protection
and warning would still be electrically independent
even if they shared the same enclosure.
Posted: Mon Aug 03, 2009 6:58 am Post subject: Load Monitoring |
At 12:53 PM 8/2/2009, you wrote:
Bob,
"kicking the tires" but really plane some installation in the near
Understand.
| Quote: | Regarding the PP regulators, I'm sure Les said that alternators of
make sense to you?
sort of . . . but given my limited knowledge of
their design's inner workings, I'd be out of school
to offer well considered opinion.
| Quote: | I'm not sure why that would work, but I'm pretty sure that's what he
This description suggests something of a synchronization
signal that causes the duty-cycle regulators to do some
sort of cooperative activity. But this is a kind of
"feed forward" or "open loop" control philosophy that
depends on or assumes certain things about the alternator
characteristics and operation.
The system may well have performed to design goals in
PP's testing and field experience with what ever
combinations of alternators were tried. My personal
experience suggests that the universal, "feed back" design
doesn't care about speeds, sizes or transfer functions.
It does the tight-wire balancing act by monitoring
actual alternator output as a proportion of total.
| Quote: | Probably my final question on this topic: If more current is needed
Field voltage is max'd out. The regulator is turned on
hard. Now the alternator goes into a current limited
mode based on its physics and depending on how gross
the overload is, the bus voltage begins to sag.
| Quote: | I expect that most of these alternators will produce more than the
You've touched on a small segment of the failure
modes considered for crafting your design. Paralleling
two alternators makes it difficult to tell when one
has failed unless the system is ALSO fitted with
gross imbalance detection and warning in addition to low
voltage warning. Making the two systems independent
of each other builds a solid partition between both
flight operations and failure detection.
If you had 50 amps being sucked from a 70A paralleled
system, the smaller alternator would go into current
limit and it's output sag until the battery picks up
the difference. I.e. bus voltage drops below 13.0 volts
and the battery joins the defence to keep the panel
lit up until (1) you become aware of the condition
and (2) react to it with a plan-b activity. But
nothing "smokes". In fact, a properly installed
alternator is essentially overload-proof. People
who have burned alternators up didn't "overload" them
with respect to their ratings . . . they "under-cooled"
them such that ratings could not be met without
over heating.
There's been much past discussion here on the List
about "de-rating" alternators to prevent bad-days
in the cockpit. The ratings are what the ratings are.
Continuous loading at or even past the nameplate ratings
without electrical damage . . . as long as you get the
heat out. We routinely TEST as-installed generators and
alternators to this design philosophy in TC aircraft.
| Quote: | Would the 20 amp unit continue to do it's job to the best of it's
| Quote: | I'm wondering as this could be the situation IF the 60 amp unit
What do you think?
Yup, you've figured it out. Your well maintained battery
steps in to hold the gremlins at bay until you can
react to the warnings.
| Quote: | Sorry if this is an old question, but I'm new to the forum and
No problem sir. Out of 1800 other folks who frequent this
list, there's a bunch who haven't heard this before either.
This is a classroom, not a one-shot reference library.
