messydeer
Joined: 13 Feb 2006 Posts: 214 Location: Bellingham, WA
Posted: Fri Jul 31, 2009 11:00 am Post subject: AEC9011 |
Thanks, Bob, for answering my questions on the other thread
Sifting through the forum archives, I see you have mentioned a replacement for the AEC9005-101 LV monitor module, http://aeroelectric.com/Catalog/AEC/9011/9011-700-1C.pdf ,which shows the new product. When will the 9011 become available?
Looks like it would replace the S704-1 alternator disconnect and AEC9005-101 LV monitor module. The alternator disconnect portion of the drawing shows a slightly different alternator disconnect, the AEC9011-110-1. It says 'arc suppression' and has a resistor and capacitor added. What are the pros and cons of these pieces? If I then wanted to leave of the resistor and capacitor, could I simply modify the 9011?
Dan
Posted: Fri Jul 31, 2009 2:27 pm Post subject: AEC9011 |
At 02:00 PM 7/31/2009, you wrote:
As soon as I get my kids schooled in the
art of soldering specs of fly-#$(at)(at) onto
ECB's. The design is done and I've had
a couple of prototypes flying for the past
6 months or so. When do you absolutely need
it?
| Quote: | Looks like it would replace the S704-1 alternator disconnect and
AEC9011-110-1.
No, only the AEC9005 LV warning. It COULD be used for
OV management of either generators -OR- alternators
with external regulators. The present modus operandi
for the 9011 calls for ENERGIZING the relay to shut
the alternator/generator down. For your application,
we need to ENERGIZE the relay to bring the alternator
ON and de-energize it to kill the alternator. I guess
I could do a patch to the software to make it do that.
That would allow the single device to do both OV and
LV monitoring/control on your small PM alternator.
| Quote: | It says 'arc suppression' and has a resistor and capacitor added.
Those are components added to the generator field
disconnect relay when and if the OV management relay
connects to a very inductive load (alternator or generator
field). For the application we're talking about, you
wouldn't need the arc suppression.
Let me think about this a bit and see what it would
take to offer a different dash number for the 9011.
Alternatively, I could make the existing version
energize the relay for generator turn-on . . . that
would let me offer one product into yet another application.
That's and attractive. I'll think about it.
( -Thomas Paine 1776- )
messydeer
Posted: Fri Jul 31, 2009 4:40 pm Post subject: Re: AEC9011 |
| Quote: | | When do you absolutely need it? |
Absolutely...hmm...lemme say possibly as early as 2 months, probably between 3 and 4 months, maybe as long as 6-8 months. If I knew the dimensions, connections, etc. I could prolly leave space for it and do a little retro fitting, if my project stepped into the fast lane.
| Quote: | No, only the AEC9005 LV warning. It COULD be used for
with external regulators. |
I won't have any aux battery, so if I outfitted it today I would need only an LV warning light and not the rest of the options currently available.
| Quote: | For your application,
LV monitoring/control on your small PM alternator. |
And this device wouldn't need the arc suppression devices for my use, just like you'd said before, right? That would be nice. Then it would replace the PM alternator disconnect. It could use the panel display from the 9011 prototype, showing something like lights for OV, LV, aux bat LV (wouldn't be wired in my case), and OV test?
_________________ Dan |
Posted: Fri Jul 31, 2009 6:47 pm Post subject: AEC9011 |
At 07:40 PM 7/31/2009, you wrote:
the dimensions are given in
http://www.aeroelectric.com/Catalog/AEC/9011/9011-700-1C.pdf
and the mating connector is a 9 pin, female d-sub.
The only thing that MIGHT change is wiring to the
relay such that the relay's N.O. contacts are used
to control the alternator as opposed to the N.C.
contacts as shown now.
I've decided to leave the alternator/generator version
as shown . . . for several reasons. There will be a PM
alternator version -10/14V AND -11/28v that drops out
the relay for alternator OV condition. This will merge
nicely with all the existing PM alternator Z-figures.
Your installation would not have the OV warn light and
optionally, you can leave off the aux battery warn light
too.
So all you'll have is the OV test/reset switch and the
LV warning light.
| Quote: | > No, only the AEC9005 LV warning. It COULD be used for
The 'extras' come standard and are used or not used
as your particular design goals dictate. Once the
basic circuitry and packaging is taken care of, adding
the extra features is about 5% of the total cost of
the product.
| Quote: | And this device wouldn't need the arc suppression devices for my
I haven't decided whether or not to offer a placard.
Like you've already noted, the needs of each builder
can generate a lot of different placard combinations.
I think we'll offer LED indicators, miniature switches,
control module and the 704-1 style relay.
messydeer
Posted: Fri Jul 31, 2009 8:41 pm Post subject: Re: AEC9011 |
| Quote: | I've decided to leave the alternator/generator version
the relay for alternator OV condition. |
So I would get something separately, like the current one offered, S704-1?
| Quote: | | This will merge nicely with all the existing PM alternator Z-figures. |
How so?
| Quote: | Your installation would not have the OV warn light and
too. So all you'll have is the OV test/reset switch and the
LV warning light. |
And from the Jabiru installation manual, http://www.usjabiru.com/images/pdf/manuals/new%20stuff/3300%20Install.pdf it says on page 16 a low voltage warning light can be connected to the green wire of the voltage regulator. So I would be left with an test/reset switch.
This makes me ask, is a test/reset switch of great value for the OV disconnect system? If it is, it seems it would be better to get it separately, instead of in a package where most or all of the other components are of no use.
| Quote: | Once the
the product. |
I just now saw a pic of the arc suppression relay: http://aeroelectric.com/Pictures/Relays/Relay_with_Arc_Suppression_s.jpg I had thought the capacitor was 10 or 20 times bigger!
| Quote: | I think we'll offer LED indicators, miniature switches,
control module and the 704-1 style relay. |
Sounds good. I'll wait for the announcements, or contact you if I haven't heard anything when I'm ready to install.
Thanks again,
Dan
Posted: Sat Aug 01, 2009 6:53 am Post subject: AEC9011 |
At 11:41 PM 7/31/2009, you wrote:
Yes
| Quote: | > This will merge nicely with all the existing PM alternator Z-figures.
How so?
Because the present design philosophy for controlling
the PM alternator is to ENERGIZE the alternator disconnect
relay to bring the alternator on line. This would remain
the same. The ground side of the alternator disconnect
relay would be controlled by the OV/LV module.
As a general rule, the alternator failure warnings
integral to voltage regulators are indicative of
gross alternator failure and may not be sensitive
to simple reductions in voltage due to regulator
control failure and/or alternator over-loading.
Legacy design goals for TC aircraft call for LV/OV
monitoring and control to be independent systems
not electrically connected with the regulator.
It is my recommendation that the "LV warning"
built into the regulator be ignored and that
all LV/OV related functions be handled by the
AEC9011-10
| Quote: | This makes me ask, is a test/reset switch of great value for the OV
Connected to the answer above. First, you'd like to
be able to pre-flight the LV/OV monitoring and
control system. The LV light begins to flash as
soon as you turn the master switch ON. After
engine start, RPMs high enough to bring the
alternator to life should turn the LV warning light
out. After that, a manual TEST trip of the OV system
should bring the LV warning back on. A RESET
should clear the LV condition. It's all a package
designed to address design goals driven by
the legacy failure modes effects analysis
process that has served us well in the TC
aircraft world for decades.
For your application, the only thing you'll leave
off is the second LV warning light.
It doesn't take much. And except for the fact
that we'd like to trip the OV system once per
flight cycle in preflight, the arc suppression
system would probably not add much value. But
when you test a generator or alternator at low
rpm, field currents tend to be high and stored
energy greater than for the average OV trip
condition at cruise. So it's a good thing to
have. But control of the PM alternator doesn't
present these kinds of stresses so the arc
suppression is left off.
messydeer
Posted: Sat Aug 01, 2009 9:19 am Post subject: Re: AEC9011 |
Hey, Bob
| Quote: | For your application, the only thing you'll leave
off is the second LV warning light. |
So I would still get the S704-1 separately and the only moving parts in the 9011 would be the OV test/reset switch?
It would look similar to the drawing on page 4 of 9011-700-1C, except everything inside the dotted lines would be replaced by my PM alternator and my S704-1. The inductor for my S704-1 would be wired into the OV WARN light somehow.
| Quote: | The ground side of the alternator disconnect
relay... |
You mean the wire from the ground side of the inductor S704-1 that is grounded to the firewall?
| Quote: | | ...would be controlled by the OV/LV module. |
The OV/LV module is the 9011, 9011-10 in my case. From Z-20, I thought the 'ground side of the alternator disconnect relay' was normally controlled by the crowbar OVM via tripping the ALT 5A circuit breaker. You're not saying the crowbar OVM and ALT circuit breaker would be changed, are you?
Finally, From your 2nd reply in this thread:
| Quote: | So all you'll have is the OV test/reset switch and the
LV warning light. |
Which seems different than what you have said now: | Quote: | ...the only thing you'll leave
I feel like I have a progressive transfer switch in my brain. It still isn't in the 'on-on' position for this topic, but you'll help me get it there soon!
Dan
Posted: Sat Aug 01, 2009 12:08 pm Post subject: AEC9011 |
Yes . . .
<snip>
| Quote: | I feel like I have a progressive transfer switch in my brain. It
See wiring diagram posted at:
http://www.aeroelectric.com/temp/9011_PM_OV-LV.pdf
 Download |
| Filename: |
9011_PM_OV-LV.pdf |
60.3 KB |
| Downloaded: |
483 Time(s) |
messydeer
Posted: Sat Aug 01, 2009 1:40 pm Post subject: Re: AEC9011 |
Great
The new diagram shows no crowbar OVM, nor circuit breaker between terminals 2 and 5 in the master switch, so does this mean the 9011 will indeed replace these, taking the overvoltage PM alternator offline?
Posted: Sat Aug 01, 2009 5:02 pm Post subject: AEC9011 |
At 04:40 PM 8/1/2009, you wrote:
Great
that's what it does . . .
