Auto Power
Goto page 1, 2  Next
pdwalter(at)bigpond.net.a
PostPosted: Wed Jul 29, 2009 6:49 pm    Post subject: Auto Power Reply with quote
Hello to the group,
I came across an aluminum block V8 powered RV 10 on utube recently. It was still a way off flying but had the engine running. I was wondering if anyone in the U.S. actually has a flying example of this type of engine installation and if so how the performance numbers stack up compared to a Lycoming etc.
Paul
~ [quote][b]
pascal(at)rv10builder.net
PostPosted: Wed Jul 29, 2009 7:21 pm    Post subject: Auto Power Reply with quote
sore subject right now [img]cid:E018908B69B644D381CE49B16EF9E4BD(at)dell[/img]
Below is the report I pulled from VAF- http://www.vansairforce.com/community/showthread.php?t=38462&page=10
gipsowh vbmenu_register("postmenu_343301", true);
Gear Collapse Incident
Yes, its true, N730WL was damaged Thursday afternoon during a test flight and subsequent emergency landing. Pilot, Bud Warren and I were taking the 10 for a flight around the airport to check out a high operating temperature problem. We took off after a long taxi and climbed normally, however the engine temperature kept climbing even after leveling off. For unknown reasons the engine seemed to quit making power. Bud skillfully banked back toward the runways. Not a good situation. A discussion with Bud today leads me to believe that the high engine temperature may have exceeded an operating parameter in the ECM and the engine reverted to a low power setting. This has yet to be confirmed but obviously needs to be addressed if this is indeed the problem.
Bud managed to get the airplane back to the airport sacrificing altitude and speed without stalling. Incredible job by Bud to get us back to the runway. However, once over the runway, we were too slow and the plane mushed onto the runway rather hard. We bounced and skidded to a stop on the collapsed main gear. Fortunately, there was no fire and Bud and I were able to get out of the 10 without any injuries, Thank God.
Unfortunately, there was considerable damage to the main landing gear and the prop was destroyed. The steps kept the bottom of the fuselage off the runway while we skidded, so no noticeable damage to the fuselage skin or tail. The wings didn't hit the ground but there is some minor damage from the gear folding up. I haven't looked at the landing gear mounts yet or the spar. So I don't know at this ten seconds the full extent of the damage.
This project has been five years in the making and this is a tough pill for me to swallow. I really appreciate the concerns voiced. Will try and keep you posted on any new developments or findings.
__________________
Bill Gipson
N730WL
LS1 Geareddrives powered RV-10
Conroe, Texas
Sent: Wednesday, July 29, 2009 7:45 PM
Subject: Auto Power
Hello to the group,
Paul
 Filesize:  1.31 KB
 Viewed:  15724 Time(s)
 Filesize:  1 KB
 Filesize:  1013 Bytes
 Filesize:  1.03 KB
ricksked(at)embarqmail.co
Yeah there's one in Texas.....it dead sticked in and folded the gear about two weeks ago......We just got back from Osh via Texas to Las Vegas....all Lycoming powered. Never missed a beat....
Sent via BlackBerry by AT&T
robin1(at)mrmoisture.com
PostPosted: Wed Jul 29, 2009 9:49 pm    Post subject: Auto Power Reply with quote
Paul is asking about the real performance numbers. Here they are Paul.
Alternative Engine Up Front Savings $15,000
Additional R&D       1,000 hours Since we work for nothing-additional cost = $0.00
Cost to build Alt. Engine RV-10   $160,000-$225,000
Resale Value of Alt. Engine RV-10   $80,000 (plus Liability Waver Signed, Witnessed & Notarized, twice)
Paul, everyone wants and hopes for a viable alternative engine RV or for that matter just about any experimental airplane to be successful using readily available automotive type engines. Unfortunately the category has been littered with planes that never flew and even worse ones that did fly. Some even making it all the way back to the airport.
My advice is that unless you are an aeronautical engineer that prefers building to flying construct a plans built aircraft. Saving $ on an alternative engine will be the most expensive path you can take.
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pascal
Sent: Wednesday, July 29, 2009 8:20 PM
Subject: Re: Auto Power
sore subject right now [img]cid:image001.gif(at)01CA109C.F363FF80[/img]
gipsowh [img]cid:image002.gif(at)01CA109C.F363FF80[/img]
[img]cid:image004.gif(at)01CA109C.F363FF80[/img]Gear Collapse Incident
__________________
Bill Gipson
N730WL
Conroe, Texas
Subject: Auto Power
Hello to the group,
Paul
href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c
 Filesize:  1.31 KB
 Viewed:  15721 Time(s)
 Filesize:  1 KB
 Filesize:  1.03 KB
deej(at)deej.net
PostPosted: Thu Jul 30, 2009 6:22 am    Post subject: Auto Power Reply with quote
<snipped>
I get a chuckle every time I read posts like this. I can just
picture a few years back people saying something along the lines of "You
mean those two Wright brothers are going to make an airplane out of
bicycle parts, and they've designed their own engine to run it? They
must be crazy!"
Randy Crothers, like the Wright brothers, has had his share of
heartache getting a good system working, but back in March he posted on
VAF some performance numbers for his Subaru STi powered RV7A. Here is
part of his post:
"I kept dialing the boost back down and lowering the RPMs to try to stay
right at the RV7A VNE speed of 200 Knots TAS. I found I could maintain
this speed with the following settings:
4600 RPMs, 42.6" MAP, Fuel flow showed 11.2 GPH with an A/F mixture of
about 12.3:1, I was keeping it pretty rich to to make sure I had
detonation margin. OAT was 28F, Oil T 200F, PSRU T 165F, Coolant T 196F,
Intake Air T 99F. Altitude 8800'. I estimate I kept these settings in
place for a good 40 minutes and finally had to back out of it to descend
down below the clouds and duck under the class B airspace I have to deal
with. I stayed out on the West side of Puget Sound and turned to the
East down toward Olympia WA.
I guess this engine could make pretty good use of a faster airframe like
a Lancair, or maybe a Glasair etc.
So there you have it, I can cruise at VNE for extended periods of time
at 4600 RPMs and 43" MAP."
It may have cost him more than a straight Lycoming installation
since he has done a bunch of experimenting with various parts, however,
someone could come along and duplicate his working setup for far less
money. We don't have much of a resale market history for RV-10s, but on
average other aircraft do not seem to sell for any less due to different
engines being installed (Glastar, Zenith 601, for example). In fact,
for some airframes, an auto engine is actually preferred (KR2s,
Hummelbird, Sonerai, Sonex, etc).
An auto engine is certainly not for everyone, but IMHO it is not the
doom and gloom that Robin describes in his message. You definitely want
to do your research before going down that path, though.
"Two roads diverged in a wood, and I, I took the one less traveled by,
and that has made all the difference." --Robert Frost
-Dj
johngoodman
PostPosted: Thu Jul 30, 2009 6:39 am    Post subject: Re: Auto Power Reply with quote
[quote="pdwalter(at)bigpond.net.a"]Hello to the group,
Paul
Paul,
The youtube video you mentioned is probably one of two. Todd Swezey out of Savannah with an LS2, or Bill Gipson out of Texas with an LS1. They both have run-up videos on youtube.
This is probably not the best forum to ask that question - most of the guys here are married to their Lycosaurs. I would suggest you go to www.vansairforce.com and visit the Alternative Engines Forum.
PostPosted: Thu Jul 30, 2009 7:44 am    Post subject: Auto Power Reply with quote
DJ,
My posts usually have a large component of tongue in cheek and this one was no different however my main point is not that it is impossible to develop a successful alternative engine for the -10 but more that it is very expensive and time consuming beyond compare. I say this as one of the first to make a simple modification by adding the James Plenum & Cowl. This seemingly simple change has probably cost us 500+ hours of development and we are still dealing with the ramifications of this small variant. I think I was clear that one needs real knowledge & skill to take that leap and even if you were to develop a successful platform your resale value may be significantly lower.
In reading a Wright Brothers biography I remember a favorite quote of Wilbur Wright the original alternative engine builder: “I don’t have time for a wife and an airplane.”
Robin
deej(at)deej.net
PostPosted: Thu Jul 30, 2009 7:54 am    Post subject: Auto Power Reply with quote
Good one! Another favorite: "My Ex-Wife told me it was her or the
airplane. I sure do miss her!" *grin*
-Dj
msausen
PostPosted: Thu Jul 30, 2009 8:46 am    Post subject: Auto Power Reply with quote
Ah yes, that always lurking disease, Aviation Induced Divorce Syndrome. That one can sneak up on you fast, especially for the dedicated builder. Very Happy
msausen
Hmm, I disagree that this isn't a good forum to discuss this. While many of us have chosen the path of least resistance, this is still a worthwhile discussion. I look at it this way, the experimental category has basically branched unofficially into two sub categories which are "homebuilt" and "experimental". Most of us in the RV-10 world fall into the homebuilt category and yes, this list is geared primarily to that crowd.
Many people think I am anti-auto conversion but that couldn't be farther from the truth. I looked very closely at Egg's offering but came to the conclusion it wasn't ready for primetime without a lot of after the fact engineering on my part. Anyone who can confidently standup and claim it is a true bolt on, firewall forward package for the RV-10 is really just trying to justify their decision. I also have personal feelings on the type of person Egg is and, in my opinion, I wouldn't want to do business with someone of his questionable ethics.
I saw the geared drives package run last year at OSH, and they are there again this year, and was really impressed with the direction it was going. It appears to be a well thought out design with lots of potential. The failure of what I would call the proof of concept -10 in the last couple weeks sounds to me like an ECU problem vs a fundamental design flaw and I think they can bounce back from it fairly quickly should that prove to have been the problem. I also think this package has the most potential to be the first, real, FWF package in the -10 that isn't a Lyc. I hope they do get there.
I also feel the rotary's have a lot of potential and hopefully Mistral will get there one of these days. But what all three of these have shown is that it is not a simple task to move an engine that was designed for auto use into an airplane. Most of the truly successful conversions are of the air cooled, low RPM type as used in many of the aircraft cited previously. Yes, Egg has had a measure of success in the smaller RV series, but most people that have used his FWF package will tell you they were putting in extensive time and effort to get through various issues in order to get a fully functional power plant that could rival a Lyc. And if you look at the amount of $time$ and extra dollars put in, odds are that savings in fuel and maint will be greatly reduced.
Yes there will always be the homebuilders that see the experimental category as a way to get what they want at a reduced cost and potentially have a hoot building at the same time, but the experimental side needs to exist also in order to keep pushing the envelope. I ultimately made the decision to go with a "standard" IO-540 because I decided I didn't want to be in the experimental group with my family on board. This doesn't make it a right or wrong decision, just my decision and everyone needs to come to their own decision without worrying about the background noise out there. We all need to remember these are certified as an "experimental" for a reason. If you are worried that one of these experimenters are going to screw with your homebuilt resale value or increase your insurance premiums, I would suggest you reevaluate whether you made the right decision to build your own aircraft. I knew the experimental part of the group would be there and it was something I took into account when I made the decision to build. If other people out there didn't, it is certainly not the experimenters fault and you should just suck it up at this point as it is what you have made the decision to be a part of.
Michael
deej(at)deej.net
PostPosted: Thu Jul 30, 2009 9:19 am    Post subject: Auto Power Reply with quote
And as with any engine package, if we learn from those that went
before us, we can cut that $time$ and extra dollars down considerably.
Installations today take much less time than those done previously,
because we can duplicate the successful installations of those that
spent that time in the past doing the experimentation. There is a
"recipe for success" that has been worked out over the years so that
builders doing installations today have significantly higher chances of
a non-issue installation compared to installations even as recent as a
couple of years ago. It is not quite as turnkey as a typical Lyc
installation, but the gap has narrowed considerably, and is getting
narrower every year.
-Dj
orchidman
PostPosted: Thu Jul 30, 2009 9:45 am    Post subject: Re: Auto Power Reply with quote
-Dj
Or the tee shirt I saw at Osh Tuesday
"Got a plane for my wife.
Best trade I ever made"
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
Kelly McMullen
PostPosted: Thu Jul 30, 2009 2:10 pm    Post subject: Auto Power Reply with quote
Besides the hassle of engineering a different engine package, and
making a cowl for it, even if it is "turn-key" there isn't anyone
besides Continental that has an engine in the horsepower range with
anywhere near as good fuel consumption specifics at total installed wt
even close. TCM is a little better on fuel and smoothness, at a cost
of at least 60lbs heavier. For all the hand wringing about old
technology, you simply are not gaining much with an auto engine in
technology. Yes automatic ignition advance. Liquid cooling has been
around aircraft engines since before WWII and generally rejected for
weight and space and leakage issues. Timed fuel injection is a very
minuscule gain over continuous mechanical. Most German cars still use
So don't be fooled by the siren song of newer technology...most of it
has been tried and rejected on reliability, weight or cost
effectiveness.
While on engines, how many have considered the negatives of going with
a brand new untested engine at the same time as a brand new untested
airframe? Because of breakin issues, you don't have luxury of any taxi
testing, nor much prop testing etc. To avoid cylinder glazing you need
to get in the air quickly with minimal ground runs to check for leaks
first.
With a used certified engine, you don't have to worry about break-in
or infant mortality, and can focus on testing your airframe. Just a
thought.
-Dj
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
vhicy(at)bigpond.com
PostPosted: Thu Jul 30, 2009 2:11 pm    Post subject: Auto Power Reply with quote
No ofence but we have heard it all before. Not the place where you want to
go experimental with wife and kids on board.
Search the archives on every RV forum
regards Chris
deej(at)deej.net
PostPosted: Thu Jul 30, 2009 2:53 pm    Post subject: Auto Power Reply with quote
to go experimental with wife and kids on board.
Hi Chris, no offense taken, and none intended. There are thousands of
experimental aircraft flying with auto engines, taking their wife, kids,
and best friends along with no more fears than with the Lycoming
engines. Different strokes for different folks, but not as doom and
gloom as you indicate.
Take some time to Google Sonex, KR2, Soneraii, Hummelbird, etc and
Corvair, Subaru EA-81, and VW engines conversions. You will find lots
of successful auto conversions. You will also finds not so successful
ones, along with not so successful Lycoming installations as well. In
particular, look for things within the last 2 years and compare to the
old days to see the differences.
-Dj
deej(at)deej.net
Hi Kelly,
I think you missed the point of my post that you replied to. If you
are duplicating someone else's setup that seems to be working, you
aren't doing any engineering of your own. You are just assembling the
same as with a Lycoming and copying the engineering that someone else
has already done. Pre-made cowls are available for purchase if you do
not want to take the time to make the modifications to the stock
cowling. These were not available a few years ago, but they are today.
Things have progressed a long ways since the "old days".
even close.
I bet Randy Crothers would beg to differ with you with his Subaru STi
installation.
effectiveness.
I'm sure some experimentation has shown that some technologies don't
work, and they phase out. The engine systems in cars of today aren't
even the same as they were 5 years ago in some cases. Progress is being
made all the time, and new technology replacing old. Who would consider
buying a car that uses magnetos these days? Things change, technology
improves, old stuff is phased out. Even Lycoming has their new FADEC
system, and magnetos and carbs of today will be phased out over time as
new technology replaces them. It is inevitable.
first.
Not necessary with today's auto engines.
thought.
No worries about break in with a modern car engine, either. Things
have changed from the days of old.
-Dj
johngoodman
PostPosted: Thu Jul 30, 2009 3:13 pm    Post subject: Re: Auto Power Reply with quote
Kelly,
Not to be nosy, but don't you work for, or represent, an engine manufacturer? If I am mistaken, I apologize.
effectiveness.
first.
thought.
> FWF package will tell you they were putting in extensive time and effort to get through various issues in order to get a fully functional power plant that could rival a Lyc. �And if you look at the amount of $time$ and extra dollars put in, odds are that savings in fuel and maint will be greatly reduced.
� �And as with any engine package, if we learn from those that went
spent that time in the past doing the experimentation. �There is a
couple of years ago. �It is not quite as turnkey as a typical Lyc
-Dj
Kelly McMullen
PostPosted: Thu Jul 30, 2009 3:37 pm    Post subject: Auto Power Reply with quote
It is a bit of a sore subject here, as one RV-10 builder with
Eggenfeller engine augered in just hours before he planned to take
family on a trip in it. Some his fault, some engine's fault, as it was
a botched deadstick landing after loss of power. Only speculative what
caused loss of power. None-the-less, another experimental pilot
deceased, loss of a friend, with impacts on our insurance.
-Dj
Kelly McMullen
KCHD
DJ that may be the case in the US but diferent here with RV's . The resale
here is shocking with anything other than Lyco etc
As you say each to there own
Chris
Kelly McMullen
PostPosted: Thu Jul 30, 2009 3:55 pm    Post subject: Auto Power Reply with quote
On Thu, Jul 30, 2009 at 5:28 PM, Dj Merrill<deej(at)deej.net> wrote:
Show me a pre-molded cowling for RV-10 for any alternative
engine..haven't seen any.
installation.
Show me the data, reliable, .041 lb/hp./hr or better, 2000 hr TBO. No
one has yet.
Right. Magnetos need no external power and are totally reliable with
reasonable maintenance intervals. There is no other system that
provides that. EMag and Pmag are less than perfect in reliability and
unavailable for 6 cyl. Electronic ignition and FADEC die without
power. Even the Diamond diesel crashed with loss of power taking out
FADEC.
No FADEC provides optimum fuel mixture management. They are designed
for lazy pilots. No one is talking carburetor. No FADEC does any
better than available fuel injection properly managed. None of what
you are citing is NEW. It just combines systems designed over 50 years
ago. Fuel injection and turbocharging were all available by 1960 in GA
engines. Nothing since adds 5% to power, economy or reliability.
You simply aren't telling us anything we haven't seen before.
Kelly
A&P/IA
EAA Tech Counselor
Kelly McMullen
KCHD
Goto page 1, 2  Next
Page 1 of 2
