luigi
Posted: Mon Jul 27, 2009 12:27 pm Post subject: Icom 200 |
have this scheme.
It allows to comunicate between the two positions without doing anything.
Unfortunely the instruction is in italian, but you do not need it.
The circuit is with 4 relay Finder 30.22 or similar plus 7 wago connectors . Nothing more
I assure is very easy to built and very, very cheap. Not more than 20 USd
When you push the PTT from one position you connect the radio to the pin J and, very important isolate through the pin 11 the ground from F to the other PTT.So the copilot doesn't talk with outside.
And viceversa.
I realized it and works fine.
For any info I am here.
Greetings from Italy
Luigi
--- Dada Music Movement, tutta la musica che vuoi! ---
luigi
Posted: Mon Jul 27, 2009 9:23 pm Post subject: Icom 200 |
--- Messaggio originale --- --> AeroElectric-List message posted by: luigit(at)freemail.it have this scheme.
And viceversa.
Luigi
 Download |
| Filename: |
Circuito_di_gestione_di_due_cuffie_2.doc |
95 KB |
| Downloaded: |
449 Time(s) |
