Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27801 Location: Toledo Washington (KTDO) USA
Posted: Mon Jul 27, 2009 3:26 pm Post subject: Hooker Rotary Harness Installation |
Dear Listers,
I was looking at how the Hooker Harnesses were going to be installed and noticed that the triangle mounting pieces have a small, "bushing" in the hole where the bolt goes. The triangle piece is already about twice the thickness of Vans standard belts and its a tight fit to get them squeezed into the mounting forks. But with the bushing in there it seems impossible. Are you suppose to just remove the bushing, or some how mash it down? I don't get it...
Thanks!
RV-8 #82880 N998RV
398.38 KB |
2597 Time(s) |
_________________ Matt Dralle
mrobert569(at)hotmail.com Guest
Posted: Mon Jul 27, 2009 7:13 pm Post subject: Hooker Rotary Harness Installation |
Matt C
You can take the bushings out of the mount. Just make sure you don't crank down too tight on the bolts. The triangles shoudl pivot freely in the airframe mounts.
Mike Robertson
Das Fed
[quote] Date: Mon C 27 Jul 2009 16:23:46 -0700
To: rv-list(at)matronics.com
Subject: Hooker Rotary Harness Installation
Dear Listers C
I was looking at how the Hooker Harnesses were going to be installed and noticed that the triangle mounting pieces have a small C "bushing" in the hole where the bolt goes. The triangle piece is already about twice the thickness of Vans standard belts and its a tight fit to get them squeezed into the mounting forks. But with the bushing in there it seems impossible. Are you suppose to just remove the bushing C or some how mash it down? I don't get it...
Thanks!
RV-8 #82880 N998RV
NEW mobile Hotmail. Optimized for YOUR phone. Click here.
Michael Wynn
Joined: 10 Jan 2006 Posts: 148 Location: San Ramon, CA
Posted: Tue Jul 28, 2009 4:28 pm Post subject: Hooker Rotary Harness Installation |
Hi Matt,
I just discussed this very subject with the Hooker rep at Osh. He said to use a file or scotchbrite wheel to flatten it as much as necessary to fit in. I haven't really dealt with the issue first hand, but that is what they are telling me.
Michael Wynn
RV 8 Finishing
San Ramon, CA
In a message dated 7/27/2009 3:30:39 P.M. Pacific Standard Time, dralle(at)matronics.com writes:
Dear Listers,
Thanks!
RV-8 #82880 N998RV
A Good Credit Score is 700 or Above. See yours in just 2 easy steps!
_________________ Michael Wynn
RV 8
San Ramon, CA |
Bret Smith
Joined: 09 Jan 2006 Posts: 178 Location: Mineral Bluff, GA
Posted: Tue Jul 28, 2009 6:10 pm Post subject: Hooker Rotary Harness Installation |
Matt,
I just took the bushing to the grinder and ground it down until it fit nice and snug.
Bret Smith
RV-9A N16BL
Blue Ridge, Ga
www.FlightInnovations.com
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tailgummer(at)aol.com
Sent: Tuesday, July 28, 2009 8:50 PM
Subject: Re: Hooker Rotary Harness Installation
Matt,
I removed the existing bushing and replaced it with a flush bushing custom fit to the width of the triangular connector. Left is harness with Hooker factory bushing, center shows custom made bushing to fit into right steel harness connector:
[img]cid:122590202(at)29072009-129E[/img]
This will allow the Hooker steel connector to fit into Van's clevis quite easily.
John D
50.25 KB |
2591 Time(s) |
_________________ Bret Smith
RV-9A (Emp) |
