jeff(at)rmmm.net Guest
Posted: Fri Jul 24, 2009 10:26 am Post subject: Fuel Tanks Repaired ;o) |
For those of you that we're wanting to hear the out come of this
subject below is a picture of the repair. I drilled the ends of the
crack. Then rubbed pro-seal into the crack as much as I could. No way
of telling how much if any went in. I then covered the area with the
gooey stuff. "Yuck what a mess". After shaping it for the angle of the
tunnel, I then placed a patch of old tank John Lawton sent me over the
crack with pro-seal on it as well. I kept pressure on it for 2 days as
it set up. Then I sanded the area with 80 grit and laid up a 6 inch, 3
layer patch of bid over the whole thing. Probably over kill but I now
have the piece of mind of knowing If the pro seal ever gave out
(Unheard of) the bid would hold till another repair or a replacement of
the tank. To hopefully help this from happening again I placed two 1
inch foam pads under the tank between the floor and the tank on both
sides. I guess as long as the tank is glassed in it can still happen
but oh well.
Anyway one other quick question to anyone. My 912-S has been,
apparently running a little rich. The mixture screw on the carbs has
been at the 1.5 reverse turn recommended by rotax since new. Can anyone
share where there mixture/screw works best. Or is it just a setting we
should do at balancing the carbs? Any help would be appreciated for
this non mechanical type person. ;o)
Best Regards,
Jeff R.
A258 - N128LJ / Gold Rush - Tanks Repaired and holding gas again.
79.59 KB |
5755 Time(s) |
94.05 KB |
5755 Time(s) |
mikenjulie.parkin(at)btin Guest
Posted: Fri Jul 24, 2009 12:44 pm Post subject: Fuel Tanks Repaired ;o) |
Jeff,
My compliments on a really nice job. A fix worth remembering.
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of JEFF ROBERTS
Sent: 24 July 2009 19:25
Subject: Fuel Tanks Repaired ;o)
For those of you that we're wanting to hear the out come of this subject below is a picture of the repair. I drilled the ends of the crack. Then rubbed pro-seal into the crack as much as I could. No way of telling how much if any went in. I then covered the area with the gooey stuff. "Yuck what a mess". After shaping it for the angle of the tunnel, I then placed a patch of old tank John Lawton sent me over the crack with pro-seal on it as well. I kept pressure on it for 2 days as it set up. Then I sanded the area with 80 grit and laid up a 6 inch, 3 layer patch of bid over the whole thing. Probably over kill but I now have the piece of mind of knowing If the pro seal ever gave out (Unheard of) the bid would hold till another repair or a replacement of the tank. To hopefully help this from happening again I placed two 1 inch foam pads under the tank between the floor and the tank on both sides. I guess as long as the tank is glassed in it can still happen but oh well.
kheindl(at)msn.com Guest
Posted: Fri Jul 24, 2009 1:53 pm Post subject: Fuel Tanks Repaired ;o) |
Hi Jeff C
from the pictures i am trying to figure out how you accessed the tank. Did you make a large opening in the bottom of the fuselage ? Normally C there are only two round access holes.
Karl
Subject: Europa-List: Fuel Tanks Repaired ;o)
Date: Fri C 24 Jul 2009 13:24:32 -0500
.ExternalClass .EC_EmailQuote {margin-left:1pt;padding-left:4pt;border-left:#800000 2px solid;} For those of you that we're wanting to hear the out come of this subject below is a picture of the repair. I drilled the ends of the crack. Then rubbed pro-seal into the crack as much as I could. No way of telling how much if any went in. I then covered the area with the gooey stuff. "Yuck what a mess". After shaping it for the angle of the tunnel C I then placed a patch of old tank John Lawton sent me over the crack with pro-seal on it as well. I kept pressure on it for 2 days as it set up. Then I sanded the area with 80 grit and laid up a 6 inch C 3 layer patch of bid over the whole thing. Probably over kill but I now have the piece of mind of knowing If the pro seal ever gave out (Unheard of) the bid would hold till another repair or a replacement of the tank. To hopefully help this from happening again I placed two 1 inch foam pads under the tank between the floor and the tank on both sides. I guess as long as the tank is glassed in it can still happen but oh well.
Anyway one other quick question to anyone. My 912-S has been C apparently running a little rich. The mixture screw on the carbs has been at the 1.5 reverse turn recommended by rotax since new. Can anyone share where there mixture/screw works best. Or is it just a setting we should do at balancing the carbs? Any help would be appreciated for this non mechanical type person. ;o)
Best Regards C
Jeff R.
Posted: Fri Jul 24, 2009 3:18 pm Post subject: Fuel Tanks Repaired ;o) |
Karl,
During the build which I started at Flight Crafters in 2003 we did an
oval access hole instead of the two as per the plans. Its about 12
inches across. Didn't know at the time I would ever need it but man am
I glad I did. I would think anyone at any time could make that change
fairly easily.
Jeff R.
On Jul 24, 2009, at 4:40 PM, Karl Heindl wrote:
Hi Jeff,
Normally, there are only two round access holes.
Karl
Date: Fri, 24 Jul 2009 13:24:32 -0500
Best Regards,
Jeff R.
JEFF ROBERTS wrote:
| Quote: | . Then I sanded the area with 80 grit and laid up a 6 inch, 3 layer
Jeff R.
Jeff
did you lay up the BID with ProSeal? I don't know if ProSeal is
available this side of the Pond. I haven't heard of it before. (learn
something every day!)
Graham
Hope you don't have any more leaks! .
Posted: Fri Jul 24, 2009 3:48 pm Post subject: Fuel Tanks Repaired ;o) |
Grahm,
The pro-seal can be found on this page.
http://www.aircraftspruce.com/search/search.php
No I laid up the bid ontop of the pro-seal patch after it was cured. It
is used to seal fuel tanks of any kind.
Jeff R.
On Jul 24, 2009, at 6:16 PM, Graham Singleton wrote:
<grahamsingleton(at)btinternet.com>
> tank.
> Jeff R.
Jeff
Graham
Posted: Fri Jul 24, 2009 5:23 pm Post subject: Fuel Tanks Repaired ;o) |
Jeff C
I thought that is what you did C and i wish this would be an approved mod. my only concern would be: does it not weaken the fuselage ? i would love to have a similar hatch at the tail.
Karl
| Quote: | From: jeff(at)rmmm.net
Subject: Re: Fuel Tanks Repaired ;o)
Date: Fri C 24 Jul 2009 17:18:11 -0500
--> Europa-List message posted by: JEFF ROBERTS <jeff(at)rmmm.net>
Karl C
fairly easily.
Regards C
Jeff R.
On Jul 24 C 2009 C at 4:40 PM C Karl Heindl wrote:
> Hi Jeff C
> Karl
> To: europa-list(at)matronics.com
> Best Regards C
> Jeff R.
&g=======
Posted: Fri Jul 24, 2009 8:15 pm Post subject: Fuel Tanks Repaired ;o) |
On Jul 24, 2009, at 8:21 PM, Karl Heindl wrote:
Jeff,
I thought that is what you did, and i wish this would be an approved
Karl,
Im not an engineer but I fly off a grass strip thats not so smooth and
I guess my bird is still strong. Maybe thats why the tank was stressed
but until now my Tri-Gear has been great on all the bumps. I would say
the larger hole is fine.
I believe most of the planes that we're started at the build center at
the time / "Flight Crafters" we're done this way but I'm not sure.
Jeff R
> Date: Fri, 24 Jul 2009 17:18:11 -0500
> Karl,
am
> fairly easily.
> Regards,
> Jeff R.
> > Hi Jeff,
> > Karl
way
the
over
a 6
gave
again I
the
can
has
> > Best Regards,
> > Jeff R.
&g=======
rampil
Posted: Sun Jul 26, 2009 5:00 am Post subject: Re: Fuel Tanks Repaired ;o) |
Jeff,
I am very glad you literally got the fix in!
I also have the larger fuel system access hatch thanks to Russell.
But all you guys on this thread are still quoting up a storm.
Please be considerate and stop this practice. In this day and age,
Nobody needs massive, or even ANY quoting!
Quoting is just a total was of bandwidth
Just use the Matronics forum web site and forget the crappy old
EMail interface
forums.matronics.com
Ira
(Flying in AZ, not WI this week)
Posted: Sun Jul 26, 2009 3:46 pm Post subject: Fuel Tanks Repaired ;o) |
JEFF ROBERTS wrote:
Grahm,
It is used to seal fuel tanks of any kind.
Jeff R.
thanks Jeff
Graham
