rgf(at)dcn.davis.ca.us Guest
Posted: Fri Jul 24, 2009 9:51 am Post subject: About those stiffening circles around the lightening holes i |
Fellow RVers,
I need to mount some stuff on wing ribs. But, the ribs have holes cut out
for lightening...and around each hole is stamped a modest raised/indented
circle in the sheet metal, for stiffening I suppose.
It is the raised side that causes problems when trying to attach something
flat there. I'd like to somehow squash or flatten a portion of the raised
circle, just enough so that the things I need to mount will fit flush on the
rib. Yes, some things must go onto the rib. No, some of this I cannot mount
on the other side.
What have RVers done to solve this little problem?
Ralph Finch
Davis, California
RV-9A QB-SA
 Download |
| Filename: |
winmail.dat |
8.12 KB |
| Downloaded: |
305 Time(s) |
truflite(at)yahoo.com Guest
Posted: Fri Jul 24, 2009 10:42 am Post subject: About those stiffening circles around the lightening holes i |
What about using spacer plates or washers to move the equipment out away from the flange?
Dave
--- On Fri, 7/24/09, Ralph Finch <rgf(at)dcn.davis.ca.us> wrote:
| Quote: | From: Ralph Finch <rgf(at)dcn.davis.ca.us>
Subject: About those stiffening circles around the lightening holes in wing ribs...
To: rv-list(at)matronics.com, rv9-list(at)matronics.com
Date: Friday, July 24, 2009, 1:48 PM
Fellow RVers,
raised/indented
attach something
fit flush on the
on the other side.
Ralph Finch
Davis, California
RV-9A QB-SA
jim jewell
Joined: 09 Jan 2006 Posts: 82 Location: Kelowna B.C. Canada
Posted: Fri Jul 24, 2009 12:32 pm Post subject: About those stiffening circles around the lightening holes i |
Some have used spacers behind the items they mount on ribs such as you
describe.
Jim in Kelowna
_________________ "I never make mistreaks" |
