UK 601XL flight testing started
aerobat
PostPosted: Mon Jul 20, 2009 6:22 am    Post subject: UK 601XL flight testing started Reply with quote
The LAA have started flight testing a 601XL modified with internal aileron mass balances and beefed up spar carry through.
It is fitted with two accelerometers on each wingtip and a gps gizmo data logger installed.
A series of flights have been carried out over two days and after each flight, data from the logger was downloaded to a laptop for analysis.
One more days flying should hopefully complete the programe, possibly later this week.
Photo of wingtip as attachement.
 Filesize:  1019.13 KB
 Viewed:  7229 Time(s)
Jeyoung65(at)aol.com
PostPosted: Mon Jul 20, 2009 6:34 am    Post subject: UK 601XL flight testing started Reply with quote
Do you have anymore information on the aileron changes? The picture looks like there are two ailerons. Jerry of GA DO NOT ARCHIVE
In a message dated 7/20/2009 9:23:43 A.M. Eastern Standard Time, rhood2000(at)HOTMAIL.COM writes:
http://forums.matronics.com//files/img_0025_158.jpg
What's for dinner tonight? Find quick and easy dinner ideas for any occasion.
aerobat
PostPosted: Mon Jul 20, 2009 6:59 am    Post subject: Re: UK 601XL flight testing started Reply with quote
It'a a standard aileron with another rib attached where you can see the double row of rivets as extra support for the arm which protrudes forward into the wing with a balance weight on the end. Very neat and unobtrusive.
Terry Phillips
PostPosted: Mon Jul 20, 2009 8:06 am    Post subject: UK 601XL flight testing started Reply with quote
I believe that the counterbalance design being used by the LAA is very similar to the design shown in Fig. 24 of Prof. Weltin's GVT report.
http://www.zenairulm.com/FAQ/pdfdocs/CH601XL-GVT-June6.pdf
Terry Phillips ZBAGer
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons are done; waiting on the wings
http://www.mykitlog.com/N47TP/ [quote][b]
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings.
aerobat
PostPosted: Tue Jul 21, 2009 1:51 pm    Post subject: Re: UK 601XL flight testing started Reply with quote
From the LAA website
http://www.lightaircraftassociation.co.uk/engineering/engineering_updates.html
