Kreem Problem Follow Up
paul perry
PostPosted: Sun Jul 19, 2009 5:31 pm    Post subject: Kreem Problem Follow Up Reply with quote
Again, thanks to everyone who responded to my orig post about the Kreem Prob, and I thought I would add some more info on what prompted me to look into the fuel tanks for a problem as well as post pics I took of the inside of the tanks with a mini webcam. I purchased the plane from the orig builder about a year ago, and started using unleaded gas either 89 or 93 oct (912ul 80hp) around Sept.(engine time around 100hrs). Within a couple of months I started having problems every once in a while when starting the engine it would run extremely rough initially, but after shutting down, turning prop by hand, it would start and run fine. I could note when it started but running rough, that I would have a cold cylinder (usually #1 or #2) . These symptoms gradually got worse until recently, after engine was shut down and cooled off (a few hours), I would have no compression at all and have to turn prop over by hand or crank with starter, then wait, then do it some more to finally start getting compression..i.e. sticking valves. Time on engine is now about 130hrs. I talked to a rotax repairman in Arlington,TN (Rodney Hardin) and he told me he had seen this happen on 912's and had found fiberglass fuel tanks being "dissolved" by the ethanol in the auto gas and the resulting contamination was causing the stuck valve problem. When looking thru the fuel tank filler opening I could see significant areas of exposed fiberglass and the flaking Kreem, so following his suggestion: I drained the fuel system and disconnected fuel lines, hooked up a temp fuel tank, and added a fuel system/valve cleaner additive, I removed the valve covers one at a time and sprayed a small amount of carb cleaner on valve stems and turned prop by hand until I got enough compression to start the engine and ground ran for about 45 minutes on Friday. On Saturday when I first turned the prop by hand I did not have the normal full compression(like I feel when shutting down engine) , but enough to start engine and it ran normally (no roughness) and so I ground ran for another 20 minutes. On Sunday I turned prop over by hand and it had what I believe to be "full compression" on all cylinders like it used to before this scenario started. Mr Hardin said he had seen fiberglass tanks (not kitfox ones) that were deteriorated so bad they were not structurally sound and attributed this to the ethanol in the gas. At this point I can only say that I believe something in the unleaded gas reacted with either the fiberglass resin, or the Kreem, or the mil-h-6000 fuel hose and caused the sticking valve problem. My plan now is to remove wings and use MEK to remove the Kreem and then re-slosh with Kreem per several replies to my original post. I am also going to change the fuel lines to one of the types recommended on this or the rotax forum. Sorry for the length of this post, but maybe someone else may benefit from my experience.
Thanks again, Paul Perry KFIV 912ul
Inside rt fuel tank showing the flaking of the Kreem the exposed fiberglass area is probably about 6"x8" just in this one spot
 Filesize:  45.95 KB
 Viewed:  19930 Time(s)
Roger Lee
PostPosted: Mon Jul 20, 2009 1:26 pm    Post subject: Re: Kreem Problem Follow Up Reply with quote
WOW, that picture is unbelievable.
If Kreem is done right the ethanol can't hurt it. This was either done very wrong or it is not really Kreem.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
brianm(at)snolab.ca
PostPosted: Mon Jul 20, 2009 2:38 pm    Post subject: Kreem Problem Follow Up Reply with quote
Hi
Does anyone know where Kreem can be purchased in Canada. I can't seem to
find it.
Brian
paul perry
PostPosted: Mon Jul 20, 2009 4:08 pm    Post subject: Re: Kreem Problem Follow Up Reply with quote
I'm assuming that the Kreem was coming off for sometime probably due to the inadequate cleaning of the release agent from the mold process by the manufacturer (Skystar?) as stated on this forum by several others. Sorry, I'm not familiar with what's available in Canada, but it can be purchased from JC Whitney online, and you might check with motorcycle parts suppliers. Paul P.
Ken Potter
PostPosted: Tue Jul 21, 2009 2:36 pm    Post subject: Re: Kreem Problem Follow Up Reply with quote
Brian;
Kreem is available from JC Whitney online and they do ship to Canada.
Cheers
Ken
Ken Potter
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario
brianm(at)snolab.ca
PostPosted: Tue Jul 21, 2009 6:42 pm    Post subject: Kreem Problem Follow Up Reply with quote
Hi Ken
I found it today locally here in Sudbury at a business called the "Shop"
705-682-4463. They bring it in at $48.95 for a one liter kit.
Brian
dave
PostPosted: Tue Jul 28, 2009 6:18 pm    Post subject: Re: Kreem Problem Follow Up Reply with quote
Is there anyone actually having ethanol tanks fall apart yet ?
Mine have no Kreem coating and I must just be lucky to not have leaks ?
After seeing those flakes of Kreem above, I think I would have to see a tank fall apart before I put that stuff in my tanks.
I am looking at adding tanks to 2 Kitfoxs both Model 2 s with no wing tanks. Wingtanks.com plastic tanks seem to fit the bill. Has anyone used these ?
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
Roger Lee
PostPosted: Tue Jul 28, 2009 6:58 pm    Post subject: Re: Kreem Problem Follow Up Reply with quote
Hi Dave,
Looking at those tanks, I don't think the Kreem coating was done right from the start. Ethanol doesn't effect Kreem like that unless it was done wrong and got up under the coating and loosened it. Something was definitely wrong.
Roger Lee
Tucson, Az.
Cell 520-349-7056
occom
PostPosted: Wed Jul 29, 2009 2:35 am    Post subject: Kreem Problem Follow Up Reply with quote
Hi Dave, have a closer look at the web site, those tanks are intended to
retrofit inside the glass tanks from Kitfox. So unless you want to adapt
something it may be more trouble than just ordering the new ones from
Kitfox. as I understand it the new ones use a more resistant resin.
dave
PostPosted: Wed Jul 29, 2009 4:28 am    Post subject: Re: Kreem Problem Follow Up Reply with quote
I talked to Them and they said you can mount them alone and not in an existing tank as well. Web site is kind of vague I agree. But the tanks are not like fiberglass tanks that are resistant but are ethanol proof.
Alot of others use this style of tank as well. RAns, Highlander, Beavers, Chinnooks etc....... I think they are far superior to glass tanks. Some say that the fiberglass tanks are a structural part of the Kitfox wing. I am not sure but if so then then that means if the tank fails ore weakens due to it being resistant than the structural integrity would be compromised. So if you tanks leak then it not safe to fly ?
lcfitt(at)sbcglobal.net
PostPosted: Wed Jul 29, 2009 6:46 am    Post subject: Kreem Problem Follow Up Reply with quote
Dave,
I think the great unknown is the wing bracing. In the manual, with the
original panel tank, there were drag - antidrag tubes mounted in the wing
tank area. Then with the optional 6 gallon and 13 gallon tanks with the
option of substituting wing lockers, etc. there are several optional drag -
antidrag configurations offered. For my money, and I am talking potential
liability if I was doing the installation for others in the course of a
business, I would not take the word of the tank manufacturer for what can be
done or not done. Of course if the tank guys would send documentation that
would indemnify you in the event of a claim - go for it. Yea right!
The talk here in the list is that if you cut the top off the original tanks,
leaving their structure in the wing for bracing, the tanks could then be
installed within the old tanks. With that being said, If the tanks serve
well alone, why were they designed to conveniently fit within the old tanks.
Not a grand coincidence I would think.
Lowell
scottsr1100rt(at)yahoo.co
PostPosted: Wed Jul 29, 2009 9:24 am    Post subject: Kreem Problem Follow Up Reply with quote
For what it's worth, I looked into these replacement tanks after I decided to replace mine, that fell apart. Although I'm sure they would work fine, I decided to take the advice of Kitfox LLC and purchase the tanks from them. Kitfox's concern was lack of testing as the tanks are part of the wing structure.
Scott
--- On Wed, 7/29/09, Lowell Fitt <lcfitt(at)sbcglobal.net> wrote:
Subject: Re: Re: Kreem Problem Follow Up
Date: Wednesday, July 29, 2009, 7:31 AM
--> Kitfox-List message posted by: "Lowell Fitt" <[url=/mc/compose?to=lcfitt(at)sbcglobal.net]lcfitt(at)sbcglobal.net[/url]>
Dave,
I think the great unknown is the wing bracing. In the manual, with the original panel tank, there were drag - antidrag tubes mounted in the wing tank area. Then with the optional 6 gallon and 13 gallon tanks with the option of substituting wing lockers, etc. there are several optional drag - antidrag configurations offered. For my money, and I am talking potential liability if I was doing the installation for others in the course of a business, I would not take the word of the tank manufacturer for what can be done or not done. Of course if the tank guys would send documentation that would indemnify you in the event of a claim - go for it. Yea right!
The talk here in the list is that if you cut the top off the original tanks, leaving their structure in the wing for bracing, the tanks could then be installed within the old tanks. With that being said, If the tanks serve well alone, why were they designed to conveniently fit within the old tanks. Not a grand coincidence I would think.
Lowell
pwmac(at)sisna.com
PostPosted: Wed Jul 29, 2009 11:18 am    Post subject: Kreem Problem Follow Up Reply with quote
Lowell,
Good point. I would think a structural engineer blessed by kitfox
llc would be in order regardless of what the tank builder says. The
drag/anti are not put in just to add weight.
PW
At 08:31 AM 7/29/2009, you wrote:
Dave,
Lowell
Lynn Matteson
PostPosted: Thu Jul 30, 2009 5:14 am    Post subject: Kreem Problem Follow Up Reply with quote
I agree.....I used Kreem in my never-before-used fuel tanks, and
haven't had a bit of problem in over three years of use. The trick is
to follow the instructions...this is NOT an area in which to
*experiment*. Of course, I fly an airplane, and use airplane fuel,
not fuel meant for an automobile.
Lynn Matteson
Jabiru 2200, #2062, 712 hrs
Sensenich 62"x46" Wood prop
Status: flying
On Jul 28, 2009, at 10:58 PM, Roger Lee wrote:
Hi Dave,
Roger Lee
Tucson, Az.
Light Sport Repairman - Maintenance Rated
Rotax Service Center
520-574-1080
http://forums.matronics.com/viewtopic.php?p 55066#255066
Lynn
Kitfox IV-Jabiru 2200
N369LM
ltaylor02(at)Chartermi.ne
PostPosted: Fri Jul 31, 2009 3:50 am    Post subject: Kreem Problem Follow Up Reply with quote
Hello Lynn, I tried to catch you while at Oshkosh. I had a chance to see
your plane and Stan's. Stan was very helpful. I'm just beginning a Kitfox
IV-1200 build. The plane was purchased in 1993 from Skystar. Approximately
5% of the build was completed before the owner died. It's been sitting
stored since 2001. It comes with a new grey head 582. I'm trying to decide
what to do with the engine which requires complete disassembly, inspection,
and rebuild if I'm going to use it. So the question is: How do you like
your Jabiru 2200? Would you install the same engine with the experience
that you've gained with this engine? Where did you get your engine mount?
Would you be willing the send me pictures of your installation? And,
lastly, if I choose the 2200, would you consider mentoring my installation?
The totally install price (nearly $25K), of the 912, which I had in a Pulsar
XP, is just getting ridiculous.
Beautiful plane by the way and I got to see you depart.
Best Regards,
Lane
Long EZ, 213EZ
and now Kitfox Model IV owner/builder and hope to be flyer...
Lynn Matteson
PostPosted: Fri Jul 31, 2009 7:14 am    Post subject: Kreem Problem Follow Up Reply with quote
I'd be glad to help, Lane. Sorry I missed you at Osh.
Other than a couple of minor problems and one major (a broken timing
gear that caused a forced landing), I'm very happy with the engine.
The broken gear was apparently a very rare occurrence, and I haven't
heard of others having the same problem. That aside, I would
definitely go with another Jabiru, even if this went went "south"
again. I just like the simplicity of installation, the air-cooling,
and the direct drive. A Rotax will climb out better due to its
reduction drive and ability to swing a longer prop, but climbing is
only part of the flight. I got my engine mount from Pete Krotje at
Jabiru USA, in Tennessee. I will send you pictures later on
today....if I forget, just remind me via my personal email address:
lynnmatt(at)jps.net
Lynn Matteson
Jabiru 2200, #2062, 720 hrs
Soon to have Rotec TBI-40 injection
Status: flying
to see your plane and Stan's. Stan was very helpful. I'm just
beginning a Kitfox IV-1200 build. The plane was purchased in 1993
from Skystar. Approximately 5% of the build was completed before
the owner died. It's been sitting stored since 2001. It comes
with a new grey head 582. I'm trying to decide what to do with the
engine which requires complete disassembly, inspection, and rebuild
if I'm going to use it. So the question is: How do you like your
mount? Would you be willing the send me pictures of your
installation? And, lastly, if I choose the 2200, would you
a Pulsar XP, is just getting ridiculous.
Best Regards,
Lane
Long EZ, 213EZ
Lynn
N369LM
Glenn Horne
PostPosted: Fri Jul 31, 2009 12:53 pm    Post subject: Kreem Problem Follow Up Reply with quote
I bought a kit (model II) from a guy in 2002 and it had a 582 gray head
engine. I
built the Model II and installed the engine and never did anything
to it. when I was ready to fly (2005)crank the engine and it ran perfect.
Did the break in procedure
and flew the aircraft. I sold the model II to a guy in Edna TX. and he now
has over 200 hr. on the 582.
I would do the same with yours if it was mine, but if you don't think is
safe don't do it.
This is for information only
Kitfox Model II
patreilly43(at)hotmail.co
PostPosted: Fri Jul 31, 2009 3:46 pm    Post subject: Kreem Problem Follow Up Reply with quote
Lynn C When you going to have that TBI installed? Do Not Archive.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
[quote] From: lynnmatt(at)jps.net
Date: Fri C 31 Jul 2009 11:11:25 -0400
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
I'd be glad to help C Lane. Sorry I missed you at Osh.
gear that caused a forced landing) C I'm very happy with the engine.
The broken gear was apparently a very rare occurrence C and I haven't
heard of others having the same problem. That aside C I would
definitely go with another Jabiru C even if this went went "south"
again. I just like the simplicity of installation C the air-cooling C
reduction drive and ability to swing a longer prop C but climbing is
Jabiru USA C in Tennessee. I will send you pictures later on
today....if I forget C just remind me via my personal email address:
lynnmatt(at)jps.net
Lynn Matteson
Kitfox IV Speedster C taildragger
Jabiru 2200 C #2062 C 720 hrs
Status: flying
On Jul 31 C 2009 C at 7:40 AM C lst wrote:
> --> Kitfox-List message posted by: "lst" <ltaylor02(at)chartermi.net>
> Hello Lynn C I tried to catch you while at Oshkosh. I had a chance
> engine which requires complete disassembly C inspection C and rebuild
> installation? And C lastly C if I choose the 2200 C would you
> The totally install price (nearly $25K) C of the 912 C which I had in
> a Pulsar XP C is just getting ridiculous.
> Best Regards C
> Lane
> Long EZ C 213EZ
Lynn Matteson
PostPosted: Fri Jul 31, 2009 5:41 pm    Post subject: Kreem Problem Follow Up Reply with quote
I'm working on it now, Pat. Should be a few days at most. Rather than
wait for a new cable to arrive, and have to negotiate a curve in it,
I am going with a bellcrank device, but having second thoughts about
it after working all day on it. Gonna sleep on it and see how I feel
about the method in the morning.
Lynn Matteson
Status: flying
On Jul 31, 2009, at 7:34 PM, patrick reilly wrote:
[quote] Lynn, When you going to have that TBI installed? Do Not Archive.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
> Date: Fri, 31 Jul 2009 11:11:25 -0400
> To: kitfox-list(at)matronics.com
> lynnmatt(at)jps.net
> Lynn Matteson
> Kitfox IV Speedster, taildragger
> Electroair direct-fire ignition system
> Status: flying
rebuild
had in
> > Best Regards,
> > Lane
> > Long EZ, 213EZ
Lynn
N369LM
PostPosted: Fri Jul 31, 2009 7:37 pm    Post subject: Kreem Problem Follow Up Reply with quote
Lynn C The original builder of my plane's strong suit wasn't electrical. He for sure wasn't using the shielding going to the strobes. He had it tied in with the wire's main element out at the wing tip C and I tried for a while to figure any logical reason in running from the buss to the switch and then to the fuse.
Our EAA Chapter is planning to hold a fall cup race. The spring one had a 1/2 hour course for your type plane. There were 2 582 powered Avid flyers entered. If you want to come out for the race C you can stay with me. Haven't got the date yet. I'll post it here when we have the date.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Subject: Re: Kitfox-List: Re: Kreem Problem Follow Up
Date: Fri C 31 Jul 2009 21:31:29 -0400
I'm working on it now C Pat. Should be a few days at most. Rather than
wait for a new cable to arrive C and have to negotiate a curve in it C
I am going with a bellcrank device C but having second thoughts about
Lynn Matteson
Status: flying
> Pat Reilly
> Mod 3 582 Rebuild
> Rockford C IL
> > lynnmatt(at)jps.net
> > Lynn Matteson
> > Status: flying
> rebuild
> had in
> > > Best Regards C
> > > Lane
> > > Long EZ C 213EZ
