Fuseblock drawings
Sam
PostPosted: Fri Jul 17, 2009 10:52 am    Post subject: Fuseblock drawings Reply with quote
Is there a .dwg file of the fuseblocks, besides the isometric view?  I am looking for a 2-D version that I can use to label for easy I.D. of the fuse size, and the wire that attaches to it.
Thanks.
Sam Hoskins
www.samhoskins.blogspot.com
Sam Hoskins
jaybannist(at)cs.com
PostPosted: Fri Jul 17, 2009 12:15 pm    Post subject: Fuseblock drawings Reply with quote
Sam,
Here is a dwg file and a pdf drawing of the 8-fuse block that is in my airplane.
Jay Bannister
Fuse_Block.pdf
 Filename:  Fuse_Block.pdf
 Filesize:  12.59 KB
 Downloaded:  355 Time(s)
Fuse_Block.dwg
 Filename:  Fuse_Block.dwg
 Filesize:  241.81 KB
 Downloaded:  351 Time(s)
Sam
PostPosted: Fri Jul 17, 2009 1:14 pm    Post subject: Fuseblock drawings Reply with quote
Great, Jay!  Saved me a bunch of time!
Sam
On Fri, Jul 17, 2009 at 3:12 PM, <jaybannist(at)cs.com (jaybannist(at)cs.com)> wrote:
[quote] Sam,
Jay Bannister
Sam Hoskins
retasker(at)optonline.net
PostPosted: Fri Jul 17, 2009 2:11 pm    Post subject: Fuseblock drawings Reply with quote
Here are the two sizes that I use in AutoCAD ver14 dwg format.
If you need them in another format, let me know.
Dick Tasker
Thanks.
Sam Hoskins
www.samhoskins.blogspot.com <http://www.samhoskins.blogspot.com>
Twenty_Position_Fuseblock.dwg
 Filename:  Twenty_Position_Fuseblock.dwg
 Filesize:  26.95 KB
 Downloaded:  338 Time(s)
Ten_Position_Fuseblock.dwg
 Filename:  Ten_Position_Fuseblock.dwg
 Filesize:  25.27 KB
 Downloaded:  328 Time(s)
Sam
PostPosted: Sat Jul 18, 2009 4:04 am    Post subject: Fuseblock drawings Reply with quote
Thank you, Dick.  I can modify them to suit.
Sam
On Fri, Jul 17, 2009 at 4:59 PM, Richard Tasker <retasker(at)optonline.net (retasker(at)optonline.net)> wrote:
[quote]Here are the two sizes that I use in AutoCAD ver14 dwg format.
Dick Tasker
Thanks.
Sam Hoskins
Sam Hoskins
