cristalclear13
Joined: 19 Sep 2007 Posts: 363 Location: Southeast Georgia
Posted: Thu Jul 16, 2009 7:11 pm Post subject: EGT quirk |
Has anyone ever had an EGT gauge not register anything until up and cruising?
Could it be a loose wire? a faulty probe? a bad gauge?
_________________ Cristal Waters
Private Pilot Aug 2008
Rotax 2 stroke maintenance April 2009 |
rowedenny
Posted: Fri Jul 17, 2009 2:37 am Post subject: EGT quirk |
rowedenny
Cristal,
The answer to all your questions is yes.
Denny
cristalclear13
Posted: Fri Jul 17, 2009 4:44 am Post subject: Re: EGT quirk |
| rowedenny wrote: | Cristal,
Denny
So this has happened to you? What did you do to fix it? I've checked my connections and that looks ok, but those wires ARE tiny and it's not easy to crimp the connectors on...maybe I didn't get it on good but if that were the case it seems like the gauge would work sporadically (on and off anytime) instead of only at cruise. I hate to buy a new probe or gauge if there's something else I can try that I haven't thought of.
We did put a lighter to the probes and didn't get any response on the gauge. But last time I flew (and that's been a while cause I've been fixin' on things) one EGT worked fine and the other was doing what I said above.
Dana
Posted: Fri Jul 17, 2009 6:13 am Post subject: EGT quirk |
At 08:44 AM 7/17/2009, cristalclear13 wrote:
| Quote: | We did put a lighter to the probes and didn't get any response on the
above.
You have two separate gauges? Good. Next step is to swap the wires at the
gauge. If the problem moves to the other gauge the problem isn't the
gauge. Then swap the wires at the sender, to see if he problem is in the
sender or the connecting wire. Now you'll have it narrowed down to the
faulty component.
-Dana
Blow your mind, smoke gunpowder.
Tom Jones
Posted: Fri Jul 17, 2009 2:35 pm Post subject: Re: EGT quirk |
When troubleshooting the EGT gauges I use a heat gun on the probe to test it. Lots easier than installing the probe in the manifold and starting the engine. You can heat the probe and wiggle the wires to help find a loose connection.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
by0ung(at)brigham.net Guest
Posted: Fri Jul 17, 2009 3:24 pm Post subject: EGT quirk |
Sounds like a loose wire,, something that changes with vibration or heat.
| Quote: | >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>...
cruising?
Cristal Waters
Ralph B
Posted: Fri Jul 17, 2009 4:08 pm Post subject: Re: EGT quirk |
Cristal, I had an EGT problem as you described. On takeoff, it was reading zero and as I backed off the throttle, it read a normal again. It was the EGT sender probe in the manifold. I replaced it and all was normal.
Ralph B
_________________ Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
The BaronVonEvil
Joined: 23 Jun 2006 Posts: 76 Location: Walla Walla, WA.
Posted: Fri Jul 17, 2009 8:39 pm Post subject: EGT quirk |
Hi Cristal,
I have experienced this same issue with a friend's Challenger II. It was the
gauge itself that was the problem (Westach). It was a dual EGT gauge and one
side would was fine while the other side wouldn't register until cruise and
sometime you had to tap the gauge with your finger for it to start working.
The Gauge is due for replacement as soon as time allows.
Carlos G
AKA
BaronVonEvil
cristalclear13
Posted: Sat Aug 01, 2009 6:44 pm Post subject: Re: EGT quirk |
Thanks for everyone's advice. Thought I'd give an update.
I always had a little trouble with my front carb. The spark plug would always come out black and the EGT when it was working good seemed low (both indicating I was running rich). That is also the side that my exhaust leak is (still happening even though I replaced the gaskets). I had my engine/carbs inspected/serviced last year sometime and he updated the needles and jets. I synced my carbs on the last inspection so I couldn't figure out why one would be running so much richer than the other when they were both set up the same. The back spark plug was always the nice brown sandy color it is supposed to be.
I took the one carb apart and thought I had a broken needle clip. I ordered new clips and saw that the new ones have a small slit in them too, so it wasn't broken. But then I noticed the new one looked like it had a new design to it. I put the new one on and cleaned off my exhaust probe some (it was pretty black and wet too).
After doing all that, I flew, and the EGT's were registering almost the same temps. So I can't help but think that the new clip helped in some way. A friend of mine said he remembered reading somewhere where there was an advisory of some type to replace that clip. Apparently cleaning the probe helped the EGT gauge work better too. The one side still isn't registering during taxi, but I may not have cleaned the probe enough.
I suppose when I check the spark plugs again after flying some more hours, it'll tell me more.
aslsa.rng(at)gmail.com Guest
Posted: Sat Aug 01, 2009 7:09 pm Post subject: EGT quirk |
Cristal, The concern with needle clips is that they be so tight on the needle that the needle will not turn in the clip. Engine vibration will cause the needle to turn in the clip and will gradually turn down the needle until it wears through. Another update to prevent this is a small o-ring that sits on top of the clip and under the spring cup. I'm sure you already know this, but you didn't mention it so......
Rick Girard
On Sat, Aug 1, 2009 at 9:44 PM, cristalclear13 <cristalclearwaters(at)gmail.com (cristalclearwaters(at)gmail.com)> wrote:
[quote]--> Kolb-List message posted by: "cristalclear13" <cristalclearwaters(at)gmail.com (cristalclearwaters(at)gmail.com)>
Cristal Waters
Kolb Mark II Twinstar
Rotax 503 DCSI
http://forums.matronics.com/viewtopic.php?p=255592#255592
le, List Admin.
zeprep251(at)aol.com Guest
Posted: Sat Aug 01, 2009 7:51 pm Post subject: EGT quirk |
Christal
Remember that there are 4 gaskets on the 503 exhaust.2 under the tin shroud to the block and 2 on top of the shroud to the manifold.JBM makes a tough gasket for all the Rotax engines at a better price.Any leak there will change the tuning of the engine.You may not have a carb problem.
G.Aman
cristalclear13
Posted: Sun Aug 02, 2009 5:24 am Post subject: Re: EGT quirk |
| aslsa.rng(at)gmail.com wrote: | Cristal, The concern with needle clips is that they be so tight on the needle that the needle will not turn in the clip. Engine vibration will cause the needle to turn in the clip and will gradually turn down the needle until it wears through. Another update to prevent this is a small o-ring that sits on top of the clip and under the spring cup. I'm sure you already know this, but you didn't mention it so......
Rick Girard |
The small o-ring was mentioned/required by my DAR when I got my airworthiness certificate two years ago November, but thanks for mentioning.
The new needle clip seemed more sturdy of a design. I didn't see any wear on the needle itself.
| zeprep251(at)aol.com wrote: | Christal
G.Aman
I replaced all four gaskets. The leak was less after changing them but still there. Maybe I'll try the ones from JBM. Not looking forward to the operation though. That was really a pain changing out those inside gaskets (as mentioned in a previous thread).
Posted: Sun Aug 02, 2009 5:49 am Post subject: EGT quirk |
Cristal Waters
Rotax two strokes, in my day, were notorious for leaking/oozing a black gook
between the exhaust manifold and the cylinder.
If it was mine, and there was no actual "exhaust gas leak", I'd wipe it down
once in a while, and keep on flying. I doubt that is going to change the
tuning.
However, if it was bad enough to leak exhaust gas, then I'd go to the
trouble of replacing gaskets.
Seems as though there could have been a better system than sandwiching the
cooling tin between the manifold and the cylinder, but no one ever came up
with a better way.
_________________ John Hauck
Titus, Alabama |
beauford
Posted: Sun Aug 02, 2009 7:04 am Post subject: EGT quirk |
Miss Cristal:
One other thing you might consider checking on the carb which is
running rich is the enrichment or
"choke" piston. If this little piston is not fully seating due to
misadjusted cable, crud in
the seat, or deteriorated rubber seal in the base of the piston, it
can easily produce the
symptoms you describe. A small leak in the enrichment circuit can
produce substantial effects.
Worth what ye paid fer it...
beauford
FF-076
Brandon, FL
Posted: Sun Aug 02, 2009 2:48 pm Post subject: EGT quirk |
It will make the replacement a bit tougher, but it will stop small leaks. Coat the gaskets with copper RTV, the ultra high temp stuff, and allow to cure before firing up the engine.Before the experts start hollering, this is a standard fix for Harley Shovelhead owners. The exhaust system is held on with a single bolt and weight keeps it seated. Been working for 15 plus years now even with the weight of a Supertrapp 2 into 1. Just so I'm not accused of theorizing.
Rick Girard
On Sun, Aug 2, 2009 at 10:05 AM, Beauford T <beauford173(at)verizon.net (beauford173(at)verizon.net)> wrote:
[quote]--> Kolb-List message posted by: "Beauford T" <beauford173(at)verizon.net (beauford173(at)verizon.net)>
Miss Cristal:
beauford
FF-076
Brandon, FL
cristalclear13
Posted: Thu Sep 03, 2009 6:42 pm Post subject: Re: EGT quirk |
| beauford wrote: | Miss Cristal:
beauford
FF-076
Brandon, FL
Beauford, This advice was worth MUCH more than what I paid fer it! Thank you! I also thank Ronnie Smith at MSLA because as soon as I told him my most recent symptoms (advancing the throttle and no or very poor response), he mentioned it seemed to be running too rich for the altitude. He first suggested changing the idle jet. So I was actually taking my carbs off to see what size jets I had when I discovered that choke seal on my front carb was totally deteriorated. See the pics.
11.81 KB |
13577 Time(s) |
18.22 KB |
13577 Time(s) |
