D.A.R question about fuse access
Goto page 1, 2  Next
vshimsl(at)live.com
PostPosted: Wed Jul 15, 2009 4:27 am    Post subject: D.A.R question about fuse access Reply with quote
In planning the layout of your electrical system C I would suggest you place your fuse blocks where you can answer 'yes' to the following question from a D.A.R:
"Are you able to change fuses for critical instruments in flight?"  (or something similar)
Fortunately one of my fuse blocks C the one with my critical instruments C was within reach (under the panel) while in flight. Changing them in flight would be painful but possible.
Before y'all blast off C realize the D.A.R is inspecting your airplane to see if it complies with Federal Regulations. If he asks you a question it is because he believes he is required to.
And regardless our collective thoughts and feelings about the question C it is being asked.
I have been on this list for years so I guess I should have anticipated this C but I have to admit the question caught me by surprise. I relay this so you are not.
Regards C
Vince_Himsl
RV8 N8432 Flying (10hours)
Lauren found her dream laptop. Find the PC that’s right for you. [quote][b]
mprather(at)spro.net
PostPosted: Wed Jul 15, 2009 5:41 am    Post subject: D.A.R question about fuse access Reply with quote
Why did you design the airplane with any critical instruments? Good panel
design dictates that there aren't any.
It's a trick question.. Most certified single engine airplanes don't have
a backup vacuum source. Nor a backup electrical system.
An EFIS, a separate turn indicator, plus a (at least one of these having
internal/backup/battery power) GPS provide as much (more) useful,
overlapping information so that if any one item fails, you can still
maintain control of the airplane.
Changing fuses while in flight instead of maintaining positive control of
the airplane sounds dangerous.
Matt-
In planning the layout of your electrical system, I would suggest you
something similar)
Fortunately one of my fuse blocks, the one with my critical instruments,
Before y'all blast off, realize the D.A.R is inspecting your airplane to
And regardless our collective thoughts and feelings about the question, it
is being asked.
this, but I have to admit the question caught me by surprise. I relay this
so you are not.
Vince_Himsl
http://www.microsoft.com/windows/choosepc/?ocid=ftp_val_wl_290
PostPosted: Wed Jul 15, 2009 6:52 am    Post subject: D.A.R question about fuse access Reply with quote
At 07:25 AM 7/15/2009, you wrote:
In planning the layout of your electrical system, I would suggest you place your fuse blocks where you can answer 'yes' to the following question from a D.A.R:
This is a recurring concern that is lifted from
the FARS. In 99% of the cases where "critical"
is used in Part 23/25 it's referring to exploring
the limits of some performance characteristics
like load limits, single-engine handling qualities
in a twin engine airplane, c.g. limits, etc. etc.
In terms of criticality of electro-whizzies, the
FARS are not enlightening. I suggest this is because
while things like wing spars, engines and unstable
aerodynamics can get you killed, the manner in which
electrics affect the outcome of flight varies widely
based on mission, weather and pilot skills. The DAY
VFR J-3 has no critical electrics . . . in fact no
electrics at all. The LAIV-P that routinely bores
holes in crummy weather, at night and over mountains
is entirely another matter.
To begin, YOU need to assess criticality
of any particular piece of hardware based on how
YOU are going to use the airplane. Second, be
aware that there are many ways that piece of
equipment can quit working that DO NOT pop fuses
or breakers. The simple logic behind this assertion
suggests that spending any time locating fuses
for easy replacement adds no value to the finished
product. Finally, launching into the blue with
a willingness to become a systems failure diagnostician
and repair technician during a time when you really
NEED some particular piece of stuff to be working
comes with a high order of risk.
The obvious solution is to design the system for
FAILURE TOLERANCE . . . i.e. no matter what
circumstances for which you plan to use the airplane,
no single piece of necessary equipment is not
backed up, i.e. your airplane has no critical
systems.
Fortunately one of my fuse blocks, the one with my critical instruments, was within reach (under the panel) while in flight. Changing them in flight would be painful but possible.
The best fix for this is move it where you
CAN'T reach it. The tendency to think in terms
of in-flight fuse replacement goes away and
thinking about failure tolerance replaces it.
. . . A good thing.
Before y'all blast off, realize the D.A.R is inspecting your airplane to see if it complies with Federal Regulations. If he asks you a question it is because he believes he is required to.
If your talking about an owner built and maintained
airplane, there are no regulations that affect
configuration of the project. The only regulations
that apply to OBAM aircraft are OPERATIONAL concerns
rightfully levied because you must play
in the same sandbox with the big guys. While
operating in that environment, it should be
transparent to everyone else that you're in an
OBAM aircraft. You're behaviors and capabilities
need to be the same as everyone else while
seamlessly sharing the airspace.
And regardless our collective thoughts and feelings about the question, it is being asked.
I have been on this list for years so I guess I should have anticipated this, but I have to admit the question caught me by surprise. I relay this so you are not.
The answer for anyone who might exercise a
regulatory authority over your project is to
explain why none of the equipment items in your
airplane are ever "critical" to continued
flight or comfortable termination of flight.
This might be because for every situation in which
you use the airplane, it matters not if ANY electrical
item on the panel is working. Better yet, it
might be the case because you have a plan-b in
the hip pocket to deal with any failure of necessary
equipment.
Think of it like this: I've never owned an
airplane with an electrical system in it (Our
J-3 at 1K1 was not so blessed). Every time
I go fly, it's in a rented airplane. As I walk
up to that airplane, should I be ruminating on
service history for the alternator? Should I
check the logs for service difficulties? Do
I want to check the warranty date sticker on
the battery? With a rented airplane, there are
MANY issues that are out of my direct supervision
and control. THIS is why I have to rely on the
integrity and skill of the airplane's owner
to keep things up to snuff under the FARS. At
the same time, I always fly with this stuff
in my flight bag:
http://aeroelectric.com/Pictures/Misc/Vacination_for_Dark_Panel_Syndrom.pdf
So my personal assessment of criticality combined
with the manner in which I use airplanes allows
me to launch without concern for ANYTHING working
on the panel. It's my plan-B, plan-C, etc to
comfortably terminate the flight at airport of
intended destination irrespective of
whether or not the master switch is even turned
on. I don't care if it's a C150 or an A36. I'm
comfortable with NOT knowing if the electrical
systems is 100% to my satisfaction.
The mind set you need to adopt when dealing with
the "learned elite" of aviation is NOT to argue
with the applicability of any particular directives
handed down from on high. Smile and explain that
you've carefully thought through your system
configuration. It's designed with your skill
set and mission requirements in mind such that
no single piece of equipment is "critical". All
installed electro-whizzies are either (1) not necessary
for comfortable termination of any anticipated flight
or (2) backed up with totally independent capabilities.
If YOU understand what you've achieved based on your
planning and workmanship, then explaining it to
a skeptical/un-informed inquisitor is easier.
It's your confidence built upon understanding and
planning that drives risk down for YOUR use of THAT
airplane . . . NOT mindless adherence to vague, broad
brush directives from a policy and procedures manual
that doesn't apply to you anyhow.
See chapter 17 of the 'Connection and any number of
fuse/breaker/failure-tolerance discussions on the
List archives and on http://aeroelectric.com.
Understanding starts there. Confidence will follow.
Bob . . . [quote][b]
longg(at)pjm.com
PostPosted: Wed Jul 15, 2009 7:14 am    Post subject: D.A.R question about fuse access Reply with quote
Matt,
Ok, I have 3 EFIS displays, two alternators, two batteries & two
internal batteries within the EFIS's, a drop down panel to access all
fuses (within easy reach of the pilot) and a compliment of spare LED
fuses. I'm thinking of adding a PEZ like dispenser for fuses below my
seat with lighted push buttons with numbers so I can pop them on demand
like a soda machine.
So how should I respond to the DAR?
I totally agree, with one caveat - if you need to change fuses in
flight, be sure you have the autopilot turned on with the traffic alerts
turned on. If you're flying IFR you already have someone watching your
back for the 1 minute it takes. If you can't find the problem in 1
minute and it's not critical, fix it on the ground. Better yet, fly with
a buddy and make him/her perform the swap.
Glenn
Bret Smith
PostPosted: Wed Jul 15, 2009 7:39 am    Post subject: D.A.R question about fuse access Reply with quote
Well said!
Bret Smith
Bret Smith
RV-9A (Emp)
PostPosted: Wed Jul 15, 2009 7:59 am    Post subject: D.A.R question about fuse access Reply with quote
Depending on how the circuits are designed, it sounds like you're set for
most ops..
I like the AP idea. Arguably, an AP should be on any airplane used for
IFR. They are relatively cheap nowadays. What's the procedure if you
suspect the fuse for the AP blew?
What happens if you accidentally pull the wrong fuse? Do you lose another
piece of 'critical equipment'?
Matt-
Matt,
Glenn
Bob Collins
PostPosted: Wed Jul 15, 2009 9:13 am    Post subject: D.A.R question about fuse access Reply with quote
I wonder how a DAR would look upon Vertical Power. No fuses. You have a control box in the panel that you can reset a "failed" circuit, but that's it. There's no ability to "change fuses in flight".
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III
Sent: Wednesday, July 15, 2009 9:51 AM
Subject: Re: D.A.R question about fuse access
systems.
. . . A good thing.
equipment.
in my flight bag:
Bob . . . [quote]
Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/
longg(at)pjm.com
PostPosted: Wed Jul 15, 2009 9:56 am    Post subject: D.A.R question about fuse access Reply with quote
Matt,
However silly it may appear I like the led approach to avoid choosing an
un-blown/wrong fuse. On my fuse buses, each fuse is additionally labeled
to assist in locating the right fuse. To me pulling the wrong fuse is no
worse than pulling a breaker accidentally. Turn off the affected device,
plug the fuse back in and re-start the device - don't do that again. I
have dual ignition with one side slaved to the second battery. The
engine will keep running no matter what breaker is pulled.
Since my AP is internal to the Dynon and runs on the Dynon network, it
will fly on battery for about an hour, thus giving me enough warning to
get down. If one has lots of blown fuses and has trouble picking the
right one, you either have a bigger issue or you're just really ignorant
about maintenance. Assuming only one is blown, let's fix it and maybe
avoid lots of headaches.
The nice thing about having internal batteries within the EFIS is that
nothing changes while you scurry to either change the fuse or land and
repair - even for the AP. If I couldn't isolate the problem by replacing
the fuse - I'd just land. Kind-o-like the ole' circuit breaker theory -
if it blows once you reset it. If it blows twice, you leave it.
Glenn
PostPosted: Wed Jul 15, 2009 10:45 am    Post subject: D.A.R question about fuse access Reply with quote
Certainly there are situations where I might mess around with diagnostics
while in flight. Many a flight there's nothing better to do besides drone
on. Especially if it's severe-clear for the length of the mission. If
it's dark and/or stormy, I'd be much more reluctant to do anything besides
hunker down and continue the flight with what's left. In my limited
experience on the needles, distraction is something I don't need..
Out of curiosity, is the AP servo powered by the instrument or does it
have a separate power source?
Matt-
Matt,
Glenn
sarg314(at)gmail.com
PostPosted: Wed Jul 15, 2009 11:22 am    Post subject: D.A.R question about fuse access Reply with quote
I'm confused by this thread.  Are you telling me that the D.A.R. is going to REQUIRE that my fuse block be accessible in flight? (Mine isn't.) Or are you just telling me I need to have a rap prepared to respond to the question.
Tom Sargent
frank.hinde(at)hp.com
PostPosted: Wed Jul 15, 2009 11:39 am    Post subject: D.A.R question about fuse access Reply with quote
DAR's sometimes have an "its my way or the highway" approach..But this is very rare.
You just need to tell him there is no one fuse that will take out your ability to fly or navigate..And you have no intention of changing fuses in flight.
None of my 3 fuse boxes are accesible and the idea of changing a fuse while being bounced around in IMC is ludicrous in my mind.
Frank RV7a IFR, elctric fuel pumps only, totally electrically dependant.
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of thomas sargent
Sent: Wednesday, July 15, 2009 12:19 PM
Tom Sargent
ist">http://www.matronics.com/Navigator?AeroElectric-List
ics.com
.matronics.com/contribution
PostPosted: Wed Jul 15, 2009 12:20 pm    Post subject: D.A.R question about fuse access Reply with quote
I like this answer. I suspect that many DAR's will be happy that you have
a rational answer to such a question - indicating that you have considered
and understand the issues involved.
Matt-
very rare.
flight.
sargent
question.
Tom Sargent
PostPosted: Wed Jul 15, 2009 12:50 pm    Post subject: D.A.R question about fuse access Reply with quote
. . . but you can 'reset' a tripped circuit under software
control. One of the BIG arguments for breakers over fuses
was the ease of resetting and low risk for dropping a fuse
holder's cap . . .
[img]cid:.0[/img]
. . . not to mention relief from having to carry
spare fuses. The advantages are inarguable. Over the past
20+ years we've developed various tools for fault current
protection including remotely controlled circuit breakers
and sundry electronic fault detection and reaction systems.
The Eclipse 500 had no breakers in the cockpit but pilots
had access to LOTS of breakers via flat screens and
software.
But getting back to simple ideas: Fuses/breakers/other are
intended to protect the airframe from hard faults that put
other systems if not the entire airframe at risk. Once
that fault occurs, the system is out of business. It's
a good idea to make the event known to the crew . . . but
resetting is 99.99% never useful or a good idea. It was
reported that repeated resets of the cabin heater breaker
on an airplane carrying Ricky Nelson may have figured in
the fire that brought the airplane down.
The prudent rule for tripped breakers and fuses (that are
sized to avoid nuisance trips) is leave them alone until on
the ground. Should it be that said breaker powers something
you really need . . . then so much for failure tolerance
(or perhaps even the decision to launch).
From my personal sense of elegant solutions, the idea
that replacing a perfectly good 25 cent fuse with hardware
that is larger, more expensive, higher parts count, and
perhaps driven by software does not make the airplane
cost less, assemble faster or perform better . . .
nor is it a positive return on investment.
( -Thomas Paine 1776- )
 Filesize:  32.95 KB
 Viewed:  7762 Time(s)
phil(at)petrasoft.net
PostPosted: Wed Jul 15, 2009 12:55 pm    Post subject: D.A.R question about fuse access Reply with quote
I can't reach any of my fuses in flight. I did this by design. I don't want to be tempted to fiddle with them. There isn't anything in my panel (VFR day/night) that will kill me if it fails, but fiddling with fuses when I should be flying the airplane can kill me.
My DAR didn't ask. Some might. Just answer that there isn't any electrical circuit in your airplane that you can't LIVE without. If he/she has a problem with that answer then make sure and warn your fellow builders about that DAR so that he/she may be avoided.
Phil Birkelbach
Houston RV7 - 727WB
phil(at)petrasoft.net (phil(at)petrasoft.net)
http://www.myrv7.com/
Tom Sargent
longg(at)pjm.com
PostPosted: Wed Jul 15, 2009 1:42 pm    Post subject: D.A.R question about fuse access Reply with quote
Tom,
Absolutely not. You will find 100’s of units with fuse blocks in very un-reachable positions. Do a little searching on Google. Remember, we are experimental – use poly fuses, fuse links or whatever you like. What folks are saying is that should any individual component be lost, be sure you can do without it (yes, Mr./Ms. DAR I can do without that). Period. Most prefer not trying to fix the broken thingy in flight, but rather get it down and tend to it on the ground. As Bob indicated failed items most often have nothing to do with the fuse/breaker.
Stick and rudder folks know you really only need an airspeed indicator to get down safely in VFR. Make it a good one.
Fuses are great and certainly reduce the owner’s cost. I do like having breakers on my alternators to kill them if necessary. There again if the alternator breaker is popping for any reason than the occasional power surge, just leave it out and get down until fixed.
Glenn
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Phil Birkelbach
Sent: Wednesday, July 15, 2009 4:54 PM
Phil Birkelbach
Houston RV7 - 727WB
Tom Sargent
href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/contribution
5
6
7
8
9
BobsV35B(at)aol.com
PostPosted: Wed Jul 15, 2009 2:41 pm    Post subject: D.A.R question about fuse access Reply with quote
Good Evening Glenn,
My primary instructor kept the airspeed covered up most of the time. I learned to control airspeed via the sound and by the feel of the controls.
Who needs an airspeed indicator?<G>
I may not be able to hold it dead on a specific number, but I can sure stay fast enough to avoid a stall and slow enough to get it stopped in a reasonable distance!
Happy Skies,
Old Bob
In a message dated 7/15/2009 4:43:18 P.M. Central Daylight Time, longg(at)pjm.com writes:
Can love help you live longer? Find out now.
PostPosted: Thu Jul 16, 2009 7:18 am    Post subject: D.A.R question about fuse access Reply with quote
At 05:25 PM 7/15/2009, you wrote:
Good Evening Glenn,
Only those not skilled in doing without them. When I
checked out new renters in our 150's I used to demonstrate
that "sticking the upper edge of the cowl on the
horizon" got you an 80 mph climb. I further demonstrated
that if the horizon is visible over the nose, you cannot
be too slow. After that, paying attention to power settings
pretty much covers the bases for not having an unhappy day
in the pattern.
I found this necessary/useful when new renters were
transitioning to an uncontrolled field sharing a 5
mile radius with 5 other uncontrolled fields. It was
a good idea to keep your eyes on the surrounding
environment as opposed to sticking the needles on some
finely tuned value for speeds and power.
longg(at)pjm.com
PostPosted: Thu Jul 16, 2009 9:04 am    Post subject: D.A.R question about fuse access Reply with quote
Too funny! So true – I have had the same experience in the Pitts – you can feel when it’s right. The Pitts will let you know when it’s not. In a Lanciar, I find it behaves best when flown by the numbers. I should throw in a caveat of “the last standing instrument I’d enjoy having” Remember, flying is easy – the plane will always go where you point it, except when you are too slow. Don’t do that.
Have a great day.
Sent: Thursday, July 16, 2009 11:16 AM
Good Evening Glenn,
in the pattern.
echristley(at)nc.rr.com
PostPosted: Thu Jul 16, 2009 10:53 am    Post subject: D.A.R question about fuse access Reply with quote
> Good Evening Glenn,
> controls.
in the pattern.
That instrument only works for people of the same height. It has to be
recalibrated for some of us 8*)
http://www.ernest.isa-geek.org
longg(at)pjm.com
PostPosted: Fri Jul 17, 2009 10:41 am    Post subject: D.A.R question about fuse access Reply with quote
Ernest, you are definitely a geek. Why not try an electric engine?
Goto page 1, 2  Next
Page 1 of 2
