jeff(at)rmmm.net Guest
topglock(at)cox.net Guest
paul.the.aviator(at)gmail Guest
Posted: Mon Jul 13, 2009 5:14 pm Post subject: Fuel Tank Leak |
Gee Jeff,
All I can say is that really sucks. I and hundreds of others out there sure hope we don't have it happen to us.
Paul
On Mon, Jul 13, 2009 at 4:31 PM, JEFF ROBERTS <jeff(at)rmmm.net (jeff(at)rmmm.net)> wrote:
[quote]We'll after seeing my fuel run onto the floor today after I added 5 gallons I started to search for a leak.
Jeff R[b]
rlborger(at)mac.com Guest
Posted: Mon Jul 13, 2009 6:13 pm Post subject: Fuel Tank Leak |
Jeff,
Geeezzz. That's awful Really sorry to hear that.
Keep us posted on your efforts and any gotcha's you find.
I hope you can be back in the air by Rough River.
Take care,
Bob Borger
Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
http://www.europaowners.org/N914XL
Aircraft Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
On Jul 13, 2009, at 17:31, JEFF ROBERTS wrote:
| Quote: | We'll after seeing my fuel run onto the floor today after I added 5
gallons I started to search for a leak. I'm now becoming painfully
aware of the fact that it looks like my tank has ruptured somewhere.
It's looking like around where the tank was glassed onto the cockpit
module in the port rear inside portion of the tunnel. I can't
remember where the seams of the tank are but there must be one back
there. Has anyone else experienced this leak there?
I remember some talk of someone making an aluminum version. Has that
been done anywhere that one might buy a duplicate?
Looks like some major surgery coming up. (
If anyone has a tank in the states I may be interested.
Jeff R.
A258 - N128LJ / Gold Rush 191 hours and now going to be down for
surgery.
Posted: Mon Jul 13, 2009 6:36 pm Post subject: Fuel Tank Leak |
Okay, After some closer inspection it appears the fuel may be coming
out of the side of the tunnel area about 4 inches from the bottom of
the tank right where I bonded a nylon tab with the old re-dux during
the build to hold a cable. Is it possible that could have weakened the
tank in that spot and it's taken a few years for it to come thru.
Graham... maybe there was something in the molding of the tank like you
said that created a spot leak.
I will check it tomorrow with about 5 psi of air pressure and some soap
water on the spot, but here is a question.
If it is a spot leak and I can patch it what would be the best patch to
use?
Any thoughts would be appreciated. I don't want to gut her if I don't
have to!!!! ;o((
Jeff R.
A258 - N128LJ / Gold Rush 191 hours and climbing slowly.
On Jul 13, 2009, at 5:52 PM, Jeff B wrote:
Dude! What a drag! And I thought I had problems with instrumentation
and Auto Pilots. WOW! Ok, gut her and get her fixed. You got about
nine weeks...
Jeff - Baby Blue
> Jeff R.
> surgery.
> size color="#000000" face="courier new,courier">
> href="http://www.matronics.com/Navigator?Europa-List">http://
> href="http://www.matronics.com/contribution">http://
> Checked by AVG - www.avg.com
hagargs(at)earthlink.net Guest
Posted: Mon Jul 13, 2009 8:11 pm Post subject: Fuel Tank Leak |
Jeff:;
My tank split in underneath the saddle area at an interface where I had a
fiberglass strap bonded in place. Take note when pulling the tank out you
will have most likely to cut it and take it out piece by piece. You will
also get an idea of how much these tanks bulge warp and other wise move
around. Which is why they get cracks in them. Kit car tank manufacturers
have known about this for decades and will not warrentee anything if it
is fiberglassed in!
| Quote: | [Original Message]
To: <europa-list(at)matronics.com>
Date: 7/13/2009 3:41:59 PM
Subject: Fuel Tank Leak
module in the port rear inside portion of the tunnel. I can't remember
where the seams of the tank are but there must be one back there. Has
Jeff R.
surgery.
64.59 KB |
9772 Time(s) |
77.92 KB |
9772 Time(s) |
70.43 KB |
9772 Time(s) |
gregoryf.flyboy(at)comcas Guest
Posted: Mon Jul 13, 2009 10:34 pm Post subject: Fuel Tank Leak |
Hi Jeff,
Sorry to hear of your tank problems.
Tap plastics has a glue called 'TAP Poly-Weld Adhesive'
Unfortunately, it requires an open flame to use it. See their usage video,
link included below. Any use on a gas tank would have to be EXTREMELY well
thought out, and that is IF you can get a flame to the area to be repaired.
Windows media:
http://www.tapplastics.com/info/video_detail.php?vid 1&format=windowsmedia&
Greg Fuchs XS TRI
_____________________________________
use?
have to!!!! ;o((
Jeff R.
Posted: Mon Jul 13, 2009 11:22 pm Post subject: Fuel Tank Leak |
JEFF ROBERTS wrote:
you said that created a spot leak.
soap water on the spot, but here is a question.
to use?
have to!!!! ;o((
Jeff R.
Jeff
I would start by trying a weld. Use a warm soldering iron or similar.
You need some scrap polyethylene for welding rod , not so easy unless
you have any bits you cut from the tank? Practice on a piece of scrap
first of course is a good plan.
Anyone have a disc they cut out of the top for a fuel gauge?
I don't know anything that would bond to polyethylene. Do you know of
anything Bud? Some car maintenance people used to weld damaged car
bumpers, you could ask their advice if you can find one. Not quite the
same material though.
Graham
acrojim7534(at)YAHOO.COM Guest
Posted: Tue Jul 14, 2009 4:11 am Post subject: Fuel Tank Leak |
Jeff
I repaired a small crack in the original tank in our monowheel when it developed a small crack on the back side of the tank.
You need to make sure that the area is cleaned and sanded with 80 grit.Then I cleaned the spot on the tank with acetone, I used pro seal and covered the crack (which was about 1/2 inch long) with the pro seal. Then I took a piece of rubber sheet about two inches in diameter and 1/8 inches thick)slathered pro seal on the rubber and put over the crack. I then slathered the pro seal over the whole patch.
Again make sure the tank is cleaned with acetone befor you start.
Walk away let cure couple days, then put gas in tank and check for leaks..
Jim Brown
--- On Tue, 7/14/09, JEFF ROBERTS <jeff(at)rmmm.net> wrote:
Subject: Re: Fuel Tank Leak
Date: Tuesday, July 14, 2009, 2:27 AM
--> Europa-List message posted by: JEFF ROBERTS <jeff(at)rmmm.net (jeff(at)rmmm.net)>
Okay, After some closer inspection it appears the fuel may be coming out of the side of the tunnel area about 4 inches from the bottom of the tank right where I bonded a nylon tab with the old re-dux during the build to hold a cable. Is it possible that could have weakened the tank in that spot and it's taken a few years for it to come thru.
Graham... maybe there was something in the molding of the tank like you said that created a spot leak.
I will check it tomorrow with about 5 psi of air pressure and some soap water on the spot, but here is a question.
If it is a spot leak and I can patch it what would be the best patch to use?
Any thoughts would be appreciated. I don't want to gut her if I don't have to!!!! ;o((
Jeff R.
| Quote: | --> Europa-List message posted by: Jeff B <topglock(at)cox.net (topglock(at)cox.net)>
Dude! What a drag! And I thought I had problems with instrumentation and Auto Pilots. WOW! Ok, gut her and get her fixed. You got about nine weeks...
Jeff - Baby Blue
JEFF ROBERTS wrote:
> We'll after seeing my fuel run onto the floor today after I added 5 gallons I started to search for a leak. I'm now becoming painfully aware of the fact that it looks like my tank has ruptured somewhere. It's looking like around where the tank was glassed onto the cockpit module in the port rear inside portion of the tunnel. I can't remember where the seams of the tank are but there must be one back there. Has anyone else experienced this leak there?
> I remember some talk of someone making an aluminum version. Has that been done anywhere that one might buy a duplicate?
> Jeff R.
> A258 - N128LJ / Gold Rush 191 hours and now going to be down for surgery.
> size=2 color="#000000" face="courier new,courier">
> href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List href="http://www.matronics.com/contribution">http://www.matronics.com/contribution ------------------------------------------------------------------------
> Checkeailable via the Web nbsp; -Matt matronics.com/contribution" target=_blank>http://www.matronics.com/contri================
kheindl(at)msn.com Guest
Posted: Tue Jul 14, 2009 4:43 am Post subject: Fuel Tank Leak |
Jim C can you tell us more about this pro seal ? Who sells it C i.e. website info.
Thank you C Karl
Date: Tue C 14 Jul 2009 05:00:13 -0700
Jeff
You need to make sure that the area is cleaned and sanded with 80 grit..Then I cleaned the spot on the tank with acetone C I used pro seal and covered the crack (which was about 1/2 inch long) with the pro seal. Then I took a piece of rubber sheet about two inches in diameter and 1/8 inches thick)slathered pro seal on the rubber and put over the crack. I then slathered the pro seal over the whole patch.
Walk away let cure couple days C then put gas in tank and check for leaks.
Posted: Tue Jul 14, 2009 11:10 am Post subject: Fuel Tank Leak |
Karl
Pro seal is like a 2 part epoxy. Mix togather and apply.. It forms a rubber compound when cured. It is used in the a/c industry to install windshields, patch fuel cells.Etc. Van's recommends that Pro Seal be used when building and sealing the fuel tanks in their line of R V's. Aircraft Spruce has it...Almost all the suppliers of aircraft parts, should have it.
Jim Brown
--- On Tue, 7/14/09, Karl Heindl <kheindl(at)msn.com> wrote:
Subject: RE: Fuel Tank Leak
Date: Tuesday, July 14, 2009, 12:37 PM
#yiv1694235164 .hmmessage P { margin:0px;padding:0px;} #yiv1694235164 { font-size:10pt;font-family:Verdana;} Jim, can you tell us more about this pro seal ? Who sells it, i.e. website info.
Thank you, Karl
Date: Tue, 14 Jul 2009 05:00:13 -0700
Jeff
You need to make sure that the area is cleaned and sanded with 80 grit..Then I cleaned the spot on the tank with acetone, I used pro seal and covered the crack (which was about 1/2 inch long) with the pro seal. Then I took a piece of rubber sheet about two inches in diameter and 1/8 inches thick)slathered pro seal on the rubber and put over the crack. I then slathered the pro seal over the whole patch.
Jim Brown
--- On Tue, 7/14/09, JEFF ROBERTS <jeff(at)rmmm..net> wrote:
--> Europa-List message posted by: JEFF ROBERTS <jeff(at)rmmm.net>
Jeff R.
| Quote: | --> Europa-List message posted by: Jeff B <topglock(at)cox.net>
Jeff - Baby Blue
> Jeff R.
| Quote: | http://www.matronics.com/Navigator?Europa-List
ronics.com
arget=_blank rel=nofollow>http://www.matronics.com/Navigator?Europa-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
rparigor(at)suffolk.lib.n Guest
Posted: Tue Jul 14, 2009 12:46 pm Post subject: Fuel Tank Leak |
Hi JimHow long have you been using Proseal on your tank?Do you use 100LL or Mogas?Is it OK for additives and ethenol in Mogas?Thx.Ron Paerigoris "> Pro seal is like a 2 part epoxy. Mix togather and apply.. It forms a > rubber compound when cured. It is used in the a/c industry to install > windshields, patch fuel cells.Etc. Van's recommends that Pro Seal be used > when building and sealing the fuel tanks in their line of R V's. Aircraft > Spruce has it...Almost all the suppliers of aircraft parts, should have > it." [quote][b]
bberube(at)tampabay.rr.co Guest
Posted: Tue Jul 14, 2009 2:13 pm Post subject: Fuel Tank Leak |
Jeff,
I agree with Graham that heat welding is the best but a fuel tank sealant
such as Pro Seal does stick to the plastic material. It is best to put it
on the inside but that does require access causing a potential for another
leak. I would try everything before pulling the tank, not a lot of fun.
Flight Crafters
erichdtrombley(at)juno.co Guest
Posted: Wed Jul 15, 2009 1:15 pm Post subject: Fuel Tank Leak |
Jeff,
The Tap plastics Polyweld looks like a very permanent solution. Regarding your inquiry about ensuring no fuel vapors are present when flame treating the tank you may want to consider filling the tank with water, after disconnecting the fuel lines and isolating the tank of course. During the construction of N28ET I used water for the calibration of the sight gage. I used 1 gallon milk jugs to fill the tank thus allowing me to tick off the sight gage in gallon increments. When finished I simply drained the tank. Keep the tank open for a couple of days and any residual water will evaporate. Also, you mentioned that you might have to open up another hole to allow access for the torch. Have you considered using one of those small pencil torches. You don't require significant heat for the task and the exposure is only for a couple of seconds. Good luck and keep us posted.
Erich Trombley
N28ET Classic Mono 914
OSH bound in a week.
____________________________________________________________
[url=_blank]The easiest way to create a blog. Click now![/url]
