Nowegian scenery from May
Clive J
PostPosted: Thu Jul 09, 2009 5:37 am    Post subject: Nowegian scenery from May Reply with quote
I delivered a plane to Norway for a friend in April. I went the long
way round but by the last leg (Sweden Save-Stavanger) got brave enough
to take a short cut across the South of the South of Norway. I regretted
it at the time and the steer about the engine out options have now put a
return trip to Norway bottom of my list. After we landed at Stavanger I
was pleased with my decision to go direct rather than follow any more
coast. The options at times don't actually bear thinking about. The
survival suit is the way to go, should be even when channel crossing but
I suppose you have to do the numbers in your own head to decide.
If I lived and flew in Norway I would need a BRS, same thought as when
in parts of Spain.
Has to be done once though.......
Regards, Clive
 Filesize:  119.09 KB
 Viewed:  1413 Time(s)
 Filesize:  86.25 KB
 Filesize:  92.34 KB
 Filesize:  61.91 KB
 Filesize:  40.85 KB
 Filesize:  30.45 KB
 Filesize:  106.84 KB
 Filesize:  40.16 KB
 Filesize:  52.71 KB
 Filesize:  127.27 KB
 Filesize:  62.12 KB
sidsel.svein(at)oslo.onli
PostPosted: Thu Jul 09, 2009 7:44 am    Post subject: Nowegian scenery from May Reply with quote
I cannot argue with Clive's comments about flying over rough terrain, but
the photo of the snow covered mountain range before approaching the open
fjords east of Stavanger brings one option to mind: There is a Europa mono
builder in Norway installing conventional taildragger undercarriage instead,
with the idea of putting skis on for winter operation. Would this be a
"first" for Europa??
Svein
LN-SKJ
