Nav antenna location
Goto page 1, 2  Next
billz
PostPosted: Wed Jul 08, 2009 5:43 am    Post subject: Nav antenna location Reply with quote
I'm planning to install a traditional (V type) nav antenna and am wondering if anyone has installed one at the top of the vertical Stab? I'm getting ready to rivet the skin on and would like to make sure I don't make a BIG mistake this early in the build. I've seen it located on the bottom of the tail on many aircraft, but am concerned about damage to the antenna, over time.
What are your thoughts.
Thanks!
Tim Olson
PostPosted: Wed Jul 08, 2009 6:16 am    Post subject: Nav antenna location Reply with quote
There are definitely some who've put it on top, under the
front fairing on the tip of the vertical stab. It
should work great there. Under the tail is working
well for me. It gives maybe 25% better range than
my wingtip Archer NAV, and that is facing the station.
If you face the wingtip away from the station it
can be much worse. I think the lower location may
be great for VOR signals since they'll be ground
based, but VS tip shouldn't be much different. It's
nice to get near 360 line of sight.
The Horizontal stab protects the antenna very well.
Other than crawling under for maintenance, there
really isn't any big stuff to worry about. I have
tables on the sides of my t-hangar and I just have to make
sure I push it back straight so I don't snag anything, but
I haven't in over 500 hours.
Tim Olson - RV-10 N104CD
Thanks!
http://forums.matronics.com/viewtopic.php?p 52094#252094
Albert Gardner
PostPosted: Wed Jul 08, 2009 8:17 am    Post subject: Nav antenna location Reply with quote
I've put my Comant Nav/VOR/GS V antennas there on both my RV-9A and my
RV-10. Seems to work great and no danger of running into the tips. I used
nutplates to make it easily removable.
Albert Gardner
Yuma, AZ
N991RV
RV-9A N872RV
RV-10 N991RV
billz
PostPosted: Wed Jul 08, 2009 9:19 am    Post subject: Re: Nav antenna location Reply with quote
Thank you for the quick replies.
I can see that the antenna will be protected by the horizontal stab and get better coverage (looking down) for the ground based signals. Sounds like the way to go. I saw an RV-10 in Memphis with the bottom mount. It looks like he just used bolts into nut plates on a reinforcing plate inside the fuselage. Is that how you've done it? I'll attach the pictures.
This plane also had two bent whip com antennas located between the main landing gear. What are your thoughts on that location??
 Filesize:  114.65 KB
 Viewed:  13542 Time(s)
 Filesize:  95.05 KB
jump2(at)sbcglobal.net
PostPosted: Wed Jul 08, 2009 9:19 am    Post subject: Nav antenna location Reply with quote
One of the things I found out with the antenna on bottom is you can get shadowing if flying dirrectly to the station and Not very high (3000ft and below). So I'm in the mist of installing antenna on the VS. As the Comat man said, the bottom mount was the second best location.
Patrick Thyssen
N15PT
--- On Wed, 7/8/09, Tim Olson <Tim(at)MyRV10.com> wrote:
Subject: Re: RV10-List: Nav antenna location
Date: Wednesday, July 8, 2009, 9:13 AM
--> RV10-List message posted by: Tim Olson <[url=/mc/compose?to=Tim(at)myrv10.com]Tim(at)myrv10.com[/url]>
billz wrote:
--> RV10-List message posted by: "billz" <[url=/mc/compose?to=billz(at)roadrunner.com]billz(at)roadrunner.com[/url]>
Thanks!
http://forums.matronics.com/viewtopic.php?p=252094#252094
http://www.matronics.com/Navigator?RV10-List --> http://www.matronics.c===================
drfred(at)suddenlinkmail.
PostPosted: Wed Jul 08, 2009 10:05 am    Post subject: Nav antenna location Reply with quote
I've got the dual com antennae on the belly and have no problems. Work
well. I can get your some pics of the doublers if you desire. I put
one of the Bob Archer VOR ant in the wingtip. I didn't want another
outside antennae. My main reason was that I didn't plan on using VOR
navigation that much. It is a good back up and cross reference, but
most of the time the GPS (496 and 430 ) are the primary nav sources. I
know it all depends on your panel preferences, your experience and
usage. Just my 0.02 cents.
Dr Fred
N515FW.
http://forums.matronics.com/viewtopic.php?p 52137#252137
http://forums.matronics.com//files/img_1058_774.jpg
http://forums.matronics.com//files/img_1060_721.jpg
gengrumpy(at)aol.com
PostPosted: Wed Jul 08, 2009 10:13 am    Post subject: Nav antenna location Reply with quote
Mine is located on bottom of fuselage mounted just fwd of leading edge
of vert stab. Put in a doubler plate if you mount it there as the
skin is too thin to support (had to reinforce mine after 50 hrs).
Otherwise, I'm happy with it there and it's pretty much hidden
underneath the horizontals.
grumpy
N184JM
Thanks!
rene(at)felker.com
PostPosted: Wed Jul 08, 2009 11:50 am    Post subject: Nav antenna location Reply with quote
I had....dual antennae on the bottom, but moved one to the top during my
condition inspection. I found that when I was talking on 118.3 & 118.1,
that it really did not work. Both at Boise (118.1) and Salt Lake City
(118.3), I had transmission problems. I could hear them, but they could not
always hear me. Could have been installation problems, but I appeared to
have good grounding.......
Both the SL30 and the 430 had problems......
Rene' Felker
RV-10 N423CF Flying
801-721-6080
flysrv10(at)gmail.com
PostPosted: Wed Jul 08, 2009 12:26 pm    Post subject: Nav antenna location Reply with quote
The only drawback to the nav antenna on the vertical stab is that birds love perching on them on the ramp and birds do what they do best while at rest.
do not archive.
On Jul 8, 2009, at 1:18 PM, Patrick Thyssen wrote:
[quote] One of the things I found out with the antenna on bottom is you can get shadowing if flying dirrectly to the station and Not very high (3000ft and below). So I'm in the mist of installing antenna on the VS. As the Comat man said, the bottom mount was the second best location.
Patrick Thyssen
N15PT
--- On Wed, 7/8/09, Tim Olson <Tim(at)MyRV10.com (Tim(at)MyRV10.com)> wrote:
From: Tim Olson <Tim(at)MyRV10.com (Tim(at)MyRV10.com)>
Subject: Re: Nav antenna location
Thanks!
[/url]
[url=http://forums.matronics.com]
wayne.e(at)grandecom.net
PostPosted: Thu Jul 09, 2009 3:08 am    Post subject: Nav antenna location Reply with quote
Hi Bill,
Yes I put mine there and it works just fine. I considered putting it down on the bottom like many others have done but had concerns about reception but also my grandkids running around the hangar and getting impaled on it down there. My plane is white in that section and the antenna is white so it's really not that noticeable and I'm used to seeing it there from my other certified planes.
I don't think you need them but if you would want any photos of the mount location let me know.
Wayne Edgerton
N602WT
"billz" <billz(at)roadrunner.com (billz(at)roadrunner.com)>
Thanks!
jkreidler
PostPosted: Thu Jul 09, 2009 3:39 am    Post subject: Re: Nav antenna location Reply with quote
We put ours on top of the VS, we also added an LED beacon up there. See attached...
Jason Kreidler - 4 Partner Build
N44YH - Flying - #40617
Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elsner, & Jason Kreidler
 Filesize:  43.31 KB
 Viewed:  13556 Time(s)
Kelly McMullen
PostPosted: Thu Jul 09, 2009 4:37 am    Post subject: Nav antenna location Reply with quote
Any one consider blade antennas rather than the eye poking V? Lots of Bonanzas have gone to them, mounted under the V.
On Thu, Jul 9, 2009 at 4:06 AM, Wayne Edgerton <wayne.e(at)grandecom.net (wayne.e(at)grandecom.net)> wrote:
[quote] Hi Bill,
Wayne Edgerton
N602WT
      Thanks!
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
jcumins(at)jcis.net
PostPosted: Thu Jul 09, 2009 9:13 am    Post subject: Nav antenna location Reply with quote
Jason
I am going to do the same thing and will add the LED beacon. I was
wondering why you have the Antenna pointed forward. I would think going aft
would relieve a lot of stress on the antenna mount.
I am also going to place the Nav antenna on top of the VS they really work
best up there.
John G. Cumins
40864 EMP
dlm46007(at)cox.net
PostPosted: Thu Jul 09, 2009 9:46 am    Post subject: Nav antenna location Reply with quote
The lobes of sensitivity lie along the sides of the V. pointed forward. More
sensitivity forward.
Albert Gardner
PostPosted: Thu Jul 09, 2009 9:54 am    Post subject: Nav antenna location Reply with quote
If you point them aft the rudder counter-balance will hit them.
Albert Gardner
Yuma, AZ
RV-9A N872RV
RV-10 N991RV
jcumins(at)jcis.net
PostPosted: Thu Jul 09, 2009 10:35 am    Post subject: Nav antenna location Reply with quote
If that's the case then why does everyone point them aft.
John G. Cumins
President
JC'S Interactive Systems
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
dlm46007(at)cox.net
PostPosted: Thu Jul 09, 2009 11:35 am    Post subject: Nav antenna location Reply with quote
Marketing I assume. Swept back is cool. A lot of serious IFR aircraft have
them swept forward to more accurately know where one is going rather than
where one has been. IFR magazine had an article of an aircraft in IMC that
hit a mountain while traveling between Port Angeles and Seattle along an
airway. The cause was determined to be a bent VOR signal and the sensitivity
of the antennas. I don't recall the particulars but do know that the
sensitivity is in the direction of the elements of the V.
Kelly McMullen
PostPosted: Thu Jul 09, 2009 11:52 am    Post subject: Nav antenna location Reply with quote
If that were much of an issue, why not go with the more sensitive and balanced blade antennas? Most new production aircraft use them. IIRC they were designed to optimize VOR/DME RNAV performance.
On Thu, Jul 9, 2009 at 12:32 PM, David McNeill <dlm46007(at)cox.net (dlm46007(at)cox.net)> wrote:
[quote] --> RV10-List message posted by: "David McNeill" <dlm46007(at)cox.net (dlm46007(at)cox.net)>
Kelly McMullen
KCHD
Tim Olson
PostPosted: Thu Jul 09, 2009 12:18 pm    Post subject: Nav antenna location Reply with quote
Aren't they way way more expensive? I remember flying along just over
100nm away from a station in front of me, receiving it with my
backwards mounted (V facing forward) NAV antenna, mounted under
the tail. Now, it may be more sensitive mounted facing forward,
and it may work better mounted on the top of the VS, but I
was pretty happy with it, considering it's generally used as
backup navigation for me. My Archer nav doesn't perform nearly
as well and not nearly as well from any direction. Blade
antennas might work great, but last I saw they were very
expensive, too. I guess everyone has their tradeoff as to
what they are both wanting and willing to accept. I can only
speak for what I installed, and note that it's working plenty
well for me. The V's might be more sensitive in the forward
direction, but really, VOR's should be well received in all
directions or they aren't as useful as they should be.
Kelly McMullen wrote:
[quote] If that were much of an issue, why not go with the more sensitive and
aircraft have
than
IMC that
sensitivity
AV8ORJWC
PostPosted: Thu Jul 09, 2009 12:22 pm    Post subject: Nav antenna location Reply with quote
Looks (aesthetics) often override antennae ground plane theory. No one
should casually dismiss correct orientation solely on appearance.
Builders should consider manufacturer avionics and their best antennae
selection choice long before the aircraft is entering finish. But alas,
all too often the thought doesn't enter early enough into radiation
patterns, placement, interference, ground plane (signal propagation),
coaxial run lengths or aesthetics until much too late to be as
effective.
"That is the case." Now....tradeoffs, that is more to the reality of
choice during the long build process.
You can always look to the over 214 flying RV-10s and follow the
leaders.
John Cox
W7COX
#40600
Goto page 1, 2  Next
Page 1 of 2
